wicked LSx S14 launch at LSfest...
200K mile stock struts all the way around. Megan springs on the front. ebay RUCA and toe control on the rear. That's it! Shocked em!!!
Re: wicked LSx S14 launch at LSfest...
Damn. That thing just squats and hooks now that you're back on stock rear suspension. I wish Scott would hurry up and post the video!
I almost went to L's fest.great times,auto or manual car?what tires are those,stock camber and toe alignment in the rear,zero'd out or positive?
Have you been to cincy street wars? Looks familiar but I thought you were on s14 se wheels with some tiny drag radials there.
arob987 wrote:I almost went to L's fest.great times,auto or manual car?what tires are those,stock camber and toe alignment in the rear,zero'd out or positive?
Powerglide, 28x10.5 MT drags tubes and screws on 15x8 5.5BS, ebay RUCA and toe control with all oem 200K mile rear struts. toed in slightly and cambered out. Blew their mind at LSfest when it launched like that and lived. It has a 2000 model Q45 diff with a 3.69 gear(same as J30 and z32 NA diff with 3.69 gear) just a regular R200 vlsd
Wasn't me. I roll raced in Louisville one night but spun bad over a bridge with expansion joints on blitz coilovers and 26x10.5jholman05 wrote:Have you been to cincy street wars? Looks familiar but I thought you were on s14 se wheels with some tiny drag radials there.
any info on the motor mods?
beercandrifter wrote:any info on the motor mods?
stock short block L33 alum 5.3L out of a 2006 Z71. ching chang head studs, felpro permatorque blue gaskets with copper spray, lunati .660 lift dual springs, lunati 216/221 .585 lift cam, manley hardened push rods, stock LS1 intake and fuel rail, built powerglide with 1.80 straight cut gear set and a trans brake, PTC 10" converter, BW S475 75/83 turbo on 19-20psi on E85. Magnafuel 4303 pump with FIC 95lb injectors. Tuned on HPtuner by ShorTuning.
sr20drag wrote:beercandrifter wrote:any info on the motor mods?
lol i just read through that and was like, theres no way that happened on a n/a 5.3. didnt see the turbo in there, good stuff man.
beercandrifter wrote:sr20drag wrote:beercandrifter wrote:any info on the motor mods?
I drove a NA car once. It sucked about like NA beer......
- emo_tactical9
I saw this car leaving town on Sunday. I honked at you. I was in a silver Fit. I didn't even know that was you.
Matt passed away yesterday. He was a great guy and leaves behind a wife and child. RIP Matt. The car scene will miss you.
http://www.kentuckynewera.com/news/acci ... 963f4.html
