http://www.youtube.com/watch?v=zEqVaebD ... e=youtu.be
I'm the RH lane.... 8.76@156
what is the quickest pass on stock IRS rear?
Re: what is the quickest pass on stock IRS rear?
I'm #1 on drag times with this pass. The RB26 car on there that is 2nd went 8.98@157
I'm assuming the car is a v8 turbo? there's a 2jz white s14 that ran 8.0 it's on YouTube. but you made a great pass much props I'd love to know what trans set up you running
how stock are you saying as stock? still R200?
1993 coupe
KA24DE-T RIP
2jz t67
10.6@134 on pump gas still shifting gears
KA24DE-T RIP
2jz t67
I think he means stock as in no ladder bar or 4 link. flatout what diff and axles are you running? we run similar times
stock r200 with kaaz 2 way...stock axles...pushing them to the limits i would imagine. that why i was curious how far anyone has gone on stock stuffRosadoRacing wrote:I think he means stock as in no ladder bar or 4 link. flatout what diff and axles are you running? we run similar times
1993 coupe
KA24DE-T RIP
2jz t67
KA24DE-T RIP
2jz t67
FlatOut wrote:stock r200 with kaaz 2 way...stock axles...pushing them to the limits i would imagine. that why i was curious how far anyone has gone on stock stuffRosadoRacing wrote:I think he means stock as in no ladder bar or 4 link. flatout what diff and axles are you running? we run similar times
When I say stock I mean 100% stock. I have a 2000 model Q45 3.69 diff and 90-96 Z32 axles with stock vlsd. The ONLY aftermarket parts on my suspension are ebay RUCA and toe control to keep it tracking straight with the wheels up.
This is the quickest and fastest S chassis on stock Nissan rear diff. He has custom afco double adjustables and upgraded axles with R32 4.36 rear diff....
http://www.youtube.com/watch?v=lrie7-q_57I
I have a around $11000 in my ENTIRE build. Every nut and bolt including shell and paint. I have a $550 used alum 5.3L, $500 used BW S475 turbo, $1000 used built powerglide with a 1.80 straight cut gear set, used drag tires for $50, used 216/221 .585 lift cam off LS1tech..... etc, etc.... I made all the mounts myself. The only new parts on my car are converter, fuel injectors, and fuel pump.
My friend duy in his white 2jz s14 just went 8.42 at fl2k not too long ago. Q45 diff z32 and q45 axle .his older car which is the white s14 2jz that went faster on you tube is also his but I can't confirm what that had.
Built ka-t
Arias 8:8:1 .20 over
K1 rods
Arp head,main,rod studs
Kelford 272's,dual valve springs
Precision 6262sp .82a/r, peakboost manifold
Cxracing fmic
Fuel injector development 2000cc
Proefi pro128, e85 flex fuel
Rb25 flywheel, dxd 350z clutch
K1 rods
Cxracing fmic
