Anyone ever heard of this ? S13 or s14 , ka-t ?
Im currently going under for a 5 lug setup with s14 subframe and just curious if anyones ever managed to get the wheels off the ground. Stiffer suspension countered with wider slicks ?ill be running those agx adjustable shocks .
whats it take to do a wheelie (ka-t)
1991 sil-eighty se sold
1995 bmw 540i written off
1995 pathfinder se, sold
1995 Altima gxe, sold
Re: whats it take to do a wheelie (ka-t)
If you check out my Video I almost got the wheels off the ground. Maybe if I had coilovers up front it would have lifted. I have kyb gr2 up front and the spring opened up. I seen a sr20 in a white coupe do a wheelie might have been ladder bar or dialed in suspension. 240s are too long to lift
so you want stiffer in the front ? how do you usually have it set up ?
Yeah that's the idea. Soft rear to squat but not to soft cuz negative camber comes into play. Stiff front so the spring don't open. Some wide sticky slicks
how wide are yours? and yeah my s14 subframe swap should help the rear
26x8.5x15 mt et slicks
pretty standard it seems
i still cant get over how your head has held down at those levels. ive been basing alot of my decisions lately on aiming for 500-550 . maybe i can hit 600
You won't get head lift under 600whp using arp. Torque them to 70
Sweet man. Im also curious what you use for tuning.Ill be using aem ems and street tuning it
