need help fast!!
All about KA-T Drag Racing. Bragging, Timeslips, Results, Questions, Whatever
RosadoRacing
need help fast!!
Post by RosadoRacing »
I'm racing this weekend at spring nationals. I got my vss working. My question is idk if I should set it to v speed on, v speed off or switch always on/off. I'm using a aem. I really dialed in the 2 step sounds amazing! 10lbs @ 5500. I'm doing 10.5 index so I want to use the speed sensor instead of a button for a more consistent launch and easier staging.
ka240de
Re: need help fast!!
Post by ka240de »
Post an updated video of the pass, havent dealt with that stuff yet sorry bro
1991 sil-eighty se sold
1995 bmw 540i written off
1995 pathfinder se, sold
1995 Altima gxe, sold
i_slide
Post by i_slide »
whats up bro... Did you ever figure out the VSS? Do you remember when my AEM wasnt reading my VSS? I'm trying to solve that problem and iI'm thinking maybe I just need to run a wire straight from the VSS to the correct AEM pin. The only question is: Isnt the VSS a 2 wire?
RosadoRacing
yes i got it work. the fuse box has 2 plugs which one of the two plugs goes to the trans. I found the 2 wires by searching online and wired them up. the one from the ems goes to the dash and from the dash it runs to the fuse box which goes to the trans. I'm pretty sure thats how it goes. I would have to double check since its been about 2 months. The wire is green and yellow and im using a auto lower harness
i_slide
Post by i_slide »
Alright thanks man. I will have to re-read that like 5X before I can sort of get a mental sketch of it. I'm heading out to Island tomorrow (7/9/14) with the new setup to see what it runs. I'm hoping I can wire up the VSS by then.
RosadoRacing
what did u run?
i_slide
Post by i_slide »
Island was closed and I still cant figure out the VSS deal. I was going to go tomorrow to Island but I broke an axle last night. I'm going out to find some j30 axles tomorrow in the pick and pulls. Im willing to take any year because i have both types of half shafts and I do think both types of j30 axles are the same diameter not just the 5 bolt.
RosadoRacing
what rear do u have? im assuming pre 95 j30? I have a z32 lsd with 5 bolt axles i am selling
i_slide
Post by i_slide »
How much are you letting them go for?
RosadoRacing
I paid $100 for each axle I can do $300 for the whole rear sry not parting out the axles. Only reason I am selling it is cuz I found a 97 j30 diff which is 30 spline and im a buy dss axles.
i_slide
Post by i_slide »
Alright I'll hold off for a bit, thanks though. Did you ever get around to confirming the wiring for the vss so my 2step reads my vehicle speed accurately? I tried to shoot you a text the other day but I'm not sure if you have the same number.
RosadoRacing
Pm me your number I'll call or text you
