ok guys im hoping to get a answer from u all last few posts no ones replyed ****..
so I have 15x8s weld for the rear and 15x3.5 in front. I mounted up my z32 30mm calipers up front to test fit the 15x3.5 skin up front for clearance. well it doesn't clear and I don't think I can add spacers cause there no room to mount the wheel after I add a spacer unless im wrong?
someone fill me on how to run 300zx 30mm calipers on my s14?
weld and z32 brakes?
- Greaser
- Master of Knowledge
Re: weld and z32 brakes?
ours are 15x5 with a 2.5" backspace. we run a 14mm spacer with extended studs.
see the car in the video section where i recently posted a video.
