Rosado Racing is back!! 9.90 @ 144mph
All about KA-T Drag Racing. Bragging, Timeslips, Results, Questions, Whatever
RosadoRacing
Post by RosadoRacing » Mon Jul 30, 2018 12:00 am
Haven't been on the site for a min seems like the forum is dead!! But for the rest of the ka community that's Still around I ran 9.90 @ 144 on 30lbs of boost shifting at 7500rpm. I didn't didn't do a great burn out so the car had traction issues really bad it was all over the track. Goal is for low 9s. This was my 3rd legit pass in the car which is my new project.
s14fiend
Re: Rosado Racing is back!! 9.90 @ 144mph
Post by s14fiend » Mon Jul 30, 2018 5:50 pm
Nice man ... congrats.... "for those 10 seconds or less....." is it still the same turbo kit and the like as previous? Most people with KA-T are on instagram... one just featured in a recent 1320 video of SCT north carolina. https://youtu.be/Xkv_SrCQAi4 if you go to his insta its kaboosthoe or something like that and he links to like 4 other nice street/drag type prepped ka24 240sx..... there is another guy that made over ~580whp on an enthalpy rom/dyno tune. So to answer your question there are some.... but I think a lot of people just sandbagging/lurking cause they wanna be sleeper or something... not to long ago there was guys in Arizona with stroker kit etc etc and then we stop hearing from them..... it's also an expensive hobby and easy to burn up an engine with bad fuel oiling etc.
RosadoRacing
Post by RosadoRacing » Tue Jul 31, 2018 5:22 pm
I hear u man. I figured id post just to keep the forum alive and keep supporting the ka-t community. I'm racing this Sunday so I'll repost What it does I'm aiming for low 9s. Car was all over the track and I have another 5psi in my map sensor left and another 300rpm to shift so a 9.0-9.2 pass is very possible if I can nail a 1.2-1.3 60ft
s14fiend
Post by s14fiend » Wed Aug 01, 2018 10:56 pm
RosadoRacing wrote:I hear u man. I figured id post just to keep the forum alive and keep supporting the ka-t community. I'm racing this Sunday so I'll repost What it does I'm aiming for low 9s. Car was all over the track and I have another 5psi in my map sensor left and another 300rpm to shift so a 9.0-9.2 pass is very possible if I can nail a 1.2-1.3 60ft
Damn but is all that on stock transmission? What ECU? Do you self tune? DO you recommend the AEM V2 PNP?
Post by adamky » Thu Aug 02, 2018 9:08 pm
Good to see you still kicking ass with the ka-t!! What's the suspension setup?
tuzzio
Post by tuzzio » Fri Aug 03, 2018 9:27 am
Awesome. IN for suspension / drivetrain info.
s14fiend
Post by s14fiend » Sun Aug 05, 2018 4:40 pm
I'm Pretty sure it looks like a stock transmission, stock suspension, stock intake manifold .... A lot of people overthink a lot on builds and go with what the industry is convincing them that they need. A lot of it has to do with the driver and probably running the right type of soft tires/air pressure and slipping the clutch correctly off the line, timing the tree right and basically leaving like EVO guys leave avoiding breaking their transfer case at the drag strip and there people running low 10s with stock transmission just like I said most guys on insta and don't post on here that much. Plus shops and tuning being so readily available people just don't DIY like that anymore to the point where they posting their whole build for the world to know.... this ain't the "car domain" "street fire" 100+++ page forum build days anymore.... Just saying.
RosadoRacing
Post by RosadoRacing » Sun Aug 05, 2018 11:35 pm
Def not stock trans i broke that years ago running 11.6 on 8 inch slicks im running a jdm 98 z32 spec trans. Kyb struts set to 3. And im popping the clutch on the launch.
s14fiend
Post by s14fiend » Tue Aug 14, 2018 6:34 pm
Nice... I'm still stock transmission been wanting to upgrade that and from stock size 10mm ARP but not sure if I need it.
RosadoRacing
Post by RosadoRacing » Thu Aug 16, 2018 8:55 pm
I lifted the head with the 10mm studs at 665whp im using rb26 12mm studs torqued to 105 ft lbs from what i remember the head will never lift now. Im shooting for 35psi this sunday and 1.3 60ft well see how it goes im hoping for 9.2-9.5s at 155mph.
s14fiend
Post by s14fiend » Fri Aug 17, 2018 3:53 pm
Did you ever use the "duncan method" of viewtopic.php?f=2&t=62827&p=533108&hili ... ds#p533108 with ARP washers?
RosadoRacing
Post by RosadoRacing » Sun Aug 19, 2018 12:45 am
No just went directly from 10mm to 12mm studs
240sx-venezuela
Post by 240sx-venezuela » Fri Nov 09, 2018 8:33 pm
RosadoRacing wrote:I lifted the head with the 10mm studs at 665whp im using rb26 12mm studs torqued to 105 ft lbs from what i remember the head will never lift now. Im shooting for 35psi this sunday and 1.3 60ft well see how it goes im hoping for 9.2-9.5s at 155mph.
How did you do to make the rb26 headstuds work in the ka? I toke my block and head to a machine shop and they did the threads easily in the block, then they drilled the head to 1/2 inch I think, and they grinded the rb26 arp nuts so they could pass trought the lifters walls.
I would like to know if you went different route to make them work
