AEM FIC or F/IC MAF Clamp
Has anyone with a AEM F/IC data logged their MAF voltage on a stock NA 240? I need a MAF voltage map of idle to WOT in third or fourth gear to clamp the voltages at lower rpms. Thanks.
Re: AEM FIC or F/IC MAF Clamp
OK well here is what I came up with. Since I already have my turbo installed I could not get the NA voltages. So here is what worked for me. Maf clamped at 4v. Then I reduced the clamp on the MAF voltage map one step every rpm below 3000.
