AEM EMS - fixing idle..timing sync done, car dies at a stop
well ive got my car running fine off my old tune, but from where i had to reset the timing sync, it threw my idle off. Now whenever I'm driving and come to a stop, my idle drops down and the car dies..it never catches itself at 750rpm like it did before on THE SAME TUNE. what should i tinker with in the AEM to get the rpm's to rest at the normal 750rpm idle when i'm letting off the gas coming to a stop? this is annoying as hell because i have to use the brakes to come to almost a stop then switch to the e-brake while keeping my foot on the gas to keep the car from dieing out. Thanks in advance guys!!
98 240sx
06 Lamborghini Gallardo
02 Mitsubishi Montero Sport
99 Infiniti QX-4
07 Suzuki gsxr-600
99 Infiniti QX-4
07 Suzuki gsxr-600
Try setting your idle a little higher, I use 900rpm. And in the idle section set the hi idle rpm to 100rpm and the time to 0.5seconds so when you clutch in it will hold the rpm a little higher so it dosnt stall out. Set up yoour idle% graph first as thats the most important one. Try to get the idle% as close to 0 as possible. If its lean whenit stalls, then close the motor more int he lower rpm, if its rich as hell, open it some more.
2JZGE NA-T -SOLD
10.3@131 27psi
i use 900 too. but if you changed your timing and it changed you idle then change your timing to what it was reading before. should be around 15-20 degrees at idle, well i think thats what mine is. when idling what is your idle learned value? i think the table to adjust is called idle % vs target table. pretty much what kinds blend said.
