OBD1 KA24DET TUNES HOSTED AND POSTED!
8-bit
Post by 8-bit »
sdaigle240 wrote:oh nifty! 0psi tpx2 = ~ 1 bar. pretty cool and isnt to far off what i ended with. another good one that PPCTX and i have noticed is ~2.5TP=1PSI
PS last addition to the tunes was nov 6th 09!!!!!!!! c'mon ppl, share!!! ill be adding mine after one more street tune to 16psi, prolly add some overboost protection then street tune done. dyno tune to follow.
remember that TP is produced relative to the K value.... and so it may not relate to a given amount of load if the k is far different from when you made a conclusion. (if i'm getting you right, you're saying a TP of 2.5 = 1.psi.. or that, say 25 would be 10psi from absolute... etc. if so, that's only a safe conclusion for your own tune, but not as a universal application to all tunes. you gotta re-determine what certain amounts of air correlate to to in TP when your K is different)
ppctx
Post by ppctx »
I dont know how you retain it all being so far out of it (still loving your clean overflow tank)
Recently went to e85 and had to increase K by 15% which required 15% increase in TP values (fuel pressure increased for the other 15% fuel needed). No logs yet, but I dont think there is any way the old tp/psi numbers will hold.
I bet that the various K values is what email tunes use to base tp for timing/fuel maps. It'd be a nice side topic if people included 0psi and XXpsi @ XX TP values. Almost guaranty there would be a liner correlation between K and TP/psi.
Probably not going to materialize but, it would be super cool and beneficial to each person that tunes to input this data.
8-bit
Post by 8-bit »
I have seen an excel file that predicted **** based on the assumed calculations that the ECU does with the K to produce TP numbers.... anyone got it? I'm looking at DeviousKA...... ;) you got it?
96NismoZ
Post by 96NismoZ »
I try to read this, and follow it.. but nothing sticks! :shock:
emo_tactical9
Post by emo_tactical9 »
8-bit wrote:I have seen an excel file that predicted **** based on the assumed calculations that the ECU does with the K to produce TP numbers.... anyone got it? I'm looking at DeviousKA...... ;) you got it?
I have one, I think its the one you're talking about. You put what size injectors and it spits out a K and a TP scale. Let me look.
Oh yeah, I'm back!
sicks13
Post by sicks13 »
Sent you a base tune for a Mustang Cobra Mafs and 850cc side feeds.
8-bit
Post by 8-bit »
sicks13 wrote:Sent you a base tune for a Mustang Cobra Mafs and 850cc side feeds.
I got it posted. I want to assume its for S13. Let me know if it isn't.
sicks13
Post by sicks13 »
it is for an S13
trevor34
Post by trevor34 »
Does anyone have a tune close to what i have........
E-Manage Ultimate
8:5:1 pistons
Stock MAF
370cc top feed injectors
91 Octane
Thanks,,,
emo_tactical9
trevor34 wrote:Does anyone have a tune close to what i have........
E-Manage Ultimate
8:5:1 pistons
Stock MAF
91 Octane
Thanks,,,
I think emanage uses different kinds of files to save the "tune."
trevor34
Post by trevor34 »
O I'm sure they are different I just want to look at someones tune so I can get started in the right direction I really just want the emanage blue tune that comes with the greddy Turbo kit but I can't find it.....
emo_tactical9
trevor34 wrote:O I'm sure they are different I just want to look at someones tune so I can get started in the right direction I really just want the emanage blue tune that comes with the greddy Turbo kit but I can't find it.....
Your setup is pretty basic, you could probably start just as easy by doing some math to get you close, then tune from there.
trevor34
Post by trevor34 »
Not to be an ass or anything i know what i can do its what i have time to do is my problem...i figured id post what i have and see if anyone had something similarso i could just get a quick view and save some time....thats all! :D
emo_tactical9
I just don't see how its going to help. You're still going to need to do some math.
How will you translate the TP into whatever load value emanage uses?
Same for K Value and whatever they use for fuel maps.
I'm just trying to help here. It really only takes a few minutes.
8-bit
Post by 8-bit »
E-Manage Ultimate
8:5:1 pistons
Stock MAF
91 Octane
Thanks,,,
This thread is for rom tunes, not emanage. Contact emanage or greddy support to get the tune.
trevor34
Post by trevor34 »
well guess the title should be changed to "obd1 rom tunes only" :dunno: also i have contacted greddy they are useless thats why im here....
jmac636
Post by jmac636 »
I would like to see some E85 tunes posted. That would be nice for comparison.
viewtopic.php?t=48692
andrecorreia
Post by andrecorreia »
Hello anyone can tell me what eprom has the ka24e have?
The ka24e ecu is 8 bit obd1 right.
I have remaped some vw obd2 16bit ecu's but never a 8bit obd1 .
Anyone have a bin for a ka24e with 450cc injectors and t2 turbo?
In my contry we run 98 octane fuel :D
Thanks
Kfred
Post by Kfred »
andrecorreia wrote:Hello anyone can tell me what eprom has the ka24e have?
Thanks
Yes it is 8bit and obd1.
You will want one of these chips: SST 27SF512 or AT29C256 (if you can find one)
If you can get your hands on a stanza ecu, go that route.
Check out eccs.hybridka.com for anything you would possibly want to know about tuning the 8 bit ecus.
RIP Nate(480sx)...
andrecorreia
Ok thanks i have some 27c256 eproms should be fine right? :lol:
Jay240
Post by Jay240 »
Anyone have a tune for 1000cc id injectors, z32 maf, t3t4, stock cams. I'm using nistune.
Unbound Yuurei
Post by Unbound Yuurei »
Does anyone have a Tune for a stock ka24de S13 Manual:
- Optimum Performance (stock)
- Emissions Friendly
If not that's coo
eazye2000
Post by eazye2000 »
Unbound Yuurei wrote:Does anyone have a Tune for a stock ka24de S13 Manual:
If not that's coo
I think I have one. You will have to look at it though and see what you think. It was on a car that had the hot cam swap, and a custom intake manifold. Butt dyno approved. I think it has launch control on it too...
PM me.
Unbound Yuurei
Does anyone have this Bin for Nistune?
- He341 (hy35)
- Cobra Maf
- 1001cc (95lbs)
- 10PSI - 12PSI Boost
- 91 Octane
I Found the hx35_CobraMafs_850CC_Base.bin but i wanted to see if anyone have used 1001cc's
Post by sdaigle240 »
Should add this to first post, fan control.
erich wrote:Here is a link to the last version of the app that I built.
www3.telus.net/kreen/fantemp.exe
Let me know if it works for you.
Works perfectly
Hubie
Lean idle/ a bit rich up top
Post by Hubie »
8bit, I'm using your tune as a basis. I'm running Z32 MAF/DW 740cc/T3T4 .63 50 trim and boostin around 10psi. It's runs well but at idle it's leaning out. I try adjusting the k-val so it idles around 14.7-15.0 but then it will run pig rich while driving and at full boost.
I tried playing with the low MAF voltage enrichment but then it'll make it idle rich.
Thanks for any help.
Post by supakat »
Use maptrace with NDS and adjust the fuel region that is running rich or lean...
u gotta do the back and forth thing with the latency and the k.
tune lat at idle
tune k at cruise
retune lat at idle
redo k at cruise
takes 2 or 3 times.
then modulate ur throttle such that it slowly goes to redline w/o making boost. thats ur 0 psi TP (friend looking at calumsult or u datalogging)
so now u have a good idea of where the boost region starts, and you can adjust the fuel. u wont have to adjust the idel and cruise regions much b/c its working off O2 feedback.
u def wanna run low boost and not go all out, get a feel for what TP in boost and adjust the timing
keep confirming timings checking out via calumsult. or if your logging.
Hubie
Post by Hubie »
Thanks for the advice. I'm waiting for my new consult cable. I'll update when I get some data in. I highly suspect that my supposed used 740cc DW injectors are not 740cc at all. When I downloaded 8-bit's tune it was running so lean that I have a miss at idle. I had to bump the k val up a little bit.
Don't b skerd, u got to move them a bit. If u still can't get good boost n idle then I'd suspect them and try scaling everything down to 550cc
