safc2 tach signal pin 2 or 3?
I got my safc2 up and running jw wonder how youy tell if the tach signal is hooked up right? i have read its either pin 2 or 3 both wires are the same color so does it matter which one? right now i have it hooked up to pin 2 like it says om the ultimate safc2 guide
This will help if you are installing on a 95 ECU.
http://www.240sx.org/faq/articles/95_ecu_pinout.htm
If you are running S13
http://www.s-chassis.com/resources/wiki ... &oldid=139
Yes it matters, just check and double check that you have the correct wire before splicing. It looks to be Pin 3 on an 95 S14, and Pin 2 on 91-94 S13 (KA24DE)
95 240sx KA24DE-T
S15 Injectors
Z32 blow through
S15 Injectors
Z32 blow through
