Enthalpy tune for 50lb Injectors
antigravity
Post by antigravity »
Can I use a 550cc injectors instead?
2hunglow1standhi
Re: Enthalpy tune for 50lb Injectors
Post by 2hunglow1standhi »
If you really don't want to re-flash, get a AFC of some sort with a wideband, and correct it from there.... really tho, RS Enthalpy Martin, can re-flash it for a risk free plug and play install. His service is the best out there for tunes, and for the people that wish to not tune it themselves.
If you need new replacement 50lbs contact five-o-motorsports, they have many options as well as a Import Machining service to fit domestic injectors in a import rail. (CHEAP!)
Saving KA24's... One at a time...
8-bit
Post by 8-bit »
Your injectors will probably have a different latency.
If the tune wasn't originally made for you (like you bought it or something), you need to have it retuned by Enthalpy for the new conditions you have. Anything otherwise would be completely foolish.
http://www.areasoundmusic.com
