Consult cable will not show up on device manager. I have tried 3 different computers and 2 different printer cables. It was working 2 days ago. Not sure why it stopped now.
Nistune consult cable issue
- Nomad
Re: Nistune consult cable issue
Device driver problem?
Maybe uninstall and reinstall the latest FTDI drivers.
Next, check the cables in & out.
Could be a wire has broken. Looking at your picture with the heat shrink around the board but there may not be much supporting the cables?
1995 D21 Navara Dual Cab
Socketed U12 ECU
Tuned ROM/NVSRAM
Socketed U12 ECU
Tuned ROM/NVSRAM
It's a bad consult. I emailed Plms and described everything I've gone through to troubleshoot this. Now just sent it to AUghtovahn to have them look at it. Hopefully they will warranty it.
I've been fighting this same issue with 2 Calumsult RTv2 ECUs I have. I thinks it's a drivers issue in my case but I won't know until one of the local 240 guys has time to scope it out with his known working cable and laptop/drivers. I even went as far as to order a cheap consult cable off ebay. same issue
