s13 chipped ecu with s14 maf bin needed.
maik21
Post by maik21 » Thu May 08, 2014 9:16 pm
hello again.
i want to know if somebody can helpme.
im running a s13 chipped ecu in a s14 98 car. i swap maf s14 vq table to s13 chipped ecm. car starts with a lot of fuel. i use nissan datascan and remove 25% of fuel an car idles better but its at 10.5 afr at working temperature.
i want to know if there is an available s13bin with s14maf so i can take a look and copy values to s13 bin. im not 100% sure but i think injectors are same value. all guides i found only talk about changing k value when you swap injectors but i dont found anything about maf swap.
thankyou very much for your time and help.
maik21
Re: s13 chipped ecu with s14 maf bin needed.
Post by maik21 » Sat May 10, 2014 11:50 pm
after 5 times of burning chips, finally car idles at 15.5 afr and cold start is great.
only problem was transmission didnt work great. only 1st and 2nd gear were available and tranny shift at 2500 rpms. i cant get to work od flash procedure. i try to do this procedure to see error code in od. light but i cant.
i only notice after restart engine, overdrive light flashes 16 times and all flashes were same long.
some hours ago, i remove my chipped s13 ecm and obd2 to obd1 jumper and put his obd2 ecm and i say bye bye.
robertsr20
Post by robertsr20 » Thu May 15, 2014 1:54 pm
Hi,here is my tuned bin, have an S14 with chipped S13 ECU and S14 maf, I hope can help you.
Regards
S13_KA24DE_S14MAF_LC.rar
(19.81 KiB) Downloaded 66 times
