Electric Fan through Calum RT
I know this has been covered but I spent 3 hours yesterday searching everywhere for the answer.
I need to know how to control when the Electric Fan turns on in my S13.
I have a KA24de from a 95 in my 92 S13. Have Calum RT installed from my sentra and have the stock BIn file loaded.
What XDF do I need to alter the Stock Bin to allow me to change the temp of when the electric fan turns on?
Hope this is simple.
- Nomad
Re: Electric Fan through Calum RT
The "S13KA revised.xdf" has fan temp entries but the xdf header info says "XDF for 1991 to 1993 B13 SR20DE or S13 KA24DE", so it may not be applicable to a 1995.
Here are the entries:
250C - Fan Temp #1A
2534 - Fan Temp #1B
2514 - Fan Temp #2A
2538 - Fan Temp #2B
251C - Fan Temp #3A
253C - Fan Temp #3B
2524 - Fan Temp #4A
2540 - Fan Temp #4B
250C - Fan Temp #1A
2534 - Fan Temp #1B
2514 - Fan Temp #2A
2538 - Fan Temp #2B
251C - Fan Temp #3A
253C - Fan Temp #3B
2524 - Fan Temp #4A
2540 - Fan Temp #4B
1995 D21 Navara Dual Cab
Socketed U12 ECU
Tuned ROM/NVSRAM
Socketed U12 ECU
Tuned ROM/NVSRAM
got your pm. it works on an s14. a member on here made a little program that you enter the desired temps and it saves the changes to the bin. pm me your email and ill see if i can send it to you.
erich wrote:Here is a link to the last version of the app that I built.
www3.telus.net/kreen/fantemp.exe
Let me know if it works for you.
- Kfred
What ECU are you running? Bluebird 91-94?
If this is a sentra ecu you should have satisfactory fan control built in from the factory.
RIP Nate(480sx)...
Bluebird ECU that has Calum RT.
I found it on google drive by just googling fantemp.exe. lolsdaigle240 wrote:erich wrote:Here is a link to the last version of the app that I built.
Downloaded and altered the BIN. The bin was still at normal temps. 212 for 4th. I have it way down like 122F lol Always on!!!
I will put into my ECU and let you guys know.
Thanks again.
- Kfred
After some research I have found that the manual transmission FWD ecus have two, single speed fans and a single relay. Because they don't have a manual clutch fan, I figured they would have had factory two speed fan control, but I was wrong.
Basically, the fan system is exactly the same as an S13 (single relay, 1 fan speed). All the wiring lines out as well. Any xdf/bin that works for S13 fan control should work with the bluebird ecu.
Let us know if it works!
RIP Nate(480sx)...
Will do.
Waiting for the car to come back from the muffler shop.
Well, the fan never turned on.
Here is the settings as follows.
Hysteresis Value = 3
First Trigger = 30
Second Trigger = 40
Third = 50
Fourth = 60
Am I doing something wrong?
First Trigger = 30
Second Trigger = 40
Third = 50
Fourth = 60
are you opening fantemp.exe making the changes, saving the bin then re loading the bin to the ECU? that lil program is not RT so you have to upload the changes.
i set my hys. to 1 and the rest of the values the same. should obviously still work with your settings though.
So you set your Hysteresis to 1 and the rest like mine?
Looked up hysteresis and all i got out of it was something about a loop... Looks more like something an engineer would know.
I will set mine to 1 and see what happens.
Also, just changed out the S14 intake temp sensors to s13, so now my car is reading correctly on the dash and ECU, hopefully...
Yes, I know how I have to upload the BIN files to the ECU. Just not sure how to get real time feedback wile the care is running. I would love to have that.
BOBCAT wrote:So you set your Hysteresis to 1 and the rest like mine?
well sir, lucky you, im an engineer lol. Hystersis is how many degrees it will allow it to deviate before turning the fans back on. 1c is in the ballpark of 2f, so i wouldnt go making it like 5c, but my 1c is probably unnecessary.
my values are more like
1
78
78
78
78
download calumsult for real time feedback. it wont maptrace but it will show you gauges and data log.
BOBCAT wrote:I have it way down like 122F lol Always on!!!
I can't figure out why you would always want it on. If you want it always on, you might as well just hook it directly to a +12V source that's on when the car is on. But doing that puts unnecessary stress on your alternator. I'd rather have it come on only when it gets above a certain temp. That's pretty much the point of being able to control the temp via the ECU or an aftermarket fan controller.
Mine comes on at 195 and goes off at 175. With a 180 degree thermostat, it operates just like I want it to.
Is their a guide for the wiringg this ? I know the ecu can control this but how to wire it would be nice...
Yeah um..... so so who cares if my cars not the fastest...its sure the hell not the slowest!
Goal for spring of 11 is 12.9sec 1/4 for less then 1500$!!! i think i can do it !!!!
isis 3360
sti injectors
z32
egay manifold
greddy fmic
ecu...working on that
isis 3360
sti injectors
z32
egay manifold
greddy fmic
its stock. its the AC fan plug for a stock rig. loose the shroud, mechanical fan, a/c fan and an altima fan will plug right in. or an fan just minus the oem connector.
Hey all,
Oddly enough I still have the source code sitting around for the fan temp twiddler. I no longer have any windows machines around to build it on but if any one wants the source I'll gladly give it away.
