Fine tuning for faster start up?
Currently running MSPnP2 with latest Tunerstudio software. Does anybody have any general tips, or heck, specific tips on tuning for quicker start ups? It currently takes about 5-6 seconds to fire up, and a little longer when at temp. I know I could just keep trying different things but I don't want to put that much stress on the ignition, battery, starter etc.. I would rather start with some knowledge that would lead me in the right direction more quickly.
- Matt Cramer
- KA-T.org Sponsor
Re: Fine tuning for faster start up?
I've been working on an article like this - check it out, and let me know if there's any other questions it needs to answer.
http://www.diyautotune.com/tech_article ... uning.html
Why don't you explain the conditions during startup that are related to your current output so that we can know what's going on? Telling me the tuning platform doesn't help at all. All that says is that you can adjust fuel and timing. That explains nothing other than to say you have the ability to fix the problem.
Don't send me your tune. I don't have MS or anything like that. What I do have is tuning knowledge that is universal.
http://www.areasoundmusic.com
I thought that saying that it took 5-6 seconds on a cold start to catch and run, and now after a little more tuning about the same when at operating temperature would be enough to explain what is going on. There is nothing that seems abnormal about startup other than the length of time it takes. I know that i could be better, thats all. What Im asking is what general features, ie: cranking pulse, priming pulse, have direct effect on this area and what general direction should I be moving in as far as figures/tables? ie: more fuel? less fuel? And, is there anything on the hardware side that could be effecting this? time to build pressure, ignition system, type of injectors? I assume they could all have a potential to effect cranking efforts to start the motor, Im sorry that my op was not clear enough, I know that is frustrating to those that might try to help me. Thanks guys..
Matt, that was a very helpful article, that is what i was looking for. Im sorry for littering the forum. I have seen that article before when I first bought the ECU from you guys, but when I do all my research it tends to lead me to these forums and not the DIYautotune site.
