Megasquirt pnp 95 ka24de batch fire jumper settings.
550cc SINGLE CAM injectors
KA24DE
TD06 20G
DIY trigger wheel
Megasquirt pnp 9501A version 1.2 red board
I jumpered my ecu in sequential mode and later found out my map sensor was shorted. DIY replaces the map sensor and now I'm trying to run it in batch fire. I could not get it started in sequential mode. The jumpers for that are J10 and J8 to the number 4 spot for sequential. Where do the jumpers need to be for batch fire? I Matt said all that was needed was to change the setting on tuner studio to "unlimited injection." For some reason it doesn't seem to fire all the cylinders. I still think my jumpers maybe wrong. If not it maybe the ecu. Can someone running the red board version 1.2 tell me where the jumpers need to be for batch so that I can verify. Pictures are always nice. Trigger wheel is installed in the correct orientation. I got it to run once but it seemed like it wasn't running on all cylinders. I can't get it to idle to even time the trigger angle. Excuse me freaking when I got it running that one time. It would only stay running if I played with the throttle. I'm so frustrated. The car runs fine on Nistune. My setting match my friends pnp and he got his started. Even if it was to rich or to lean it should still run. Frustrated!!!
KA24DE
TD06 20G
DIY trigger wheel
- BigLoukaT
Re: Megasquirt pnp 95 ka24de batch fire jumper settings.
Did you see the reply in the diyautotune forum? With the jumpers in the sequential locations, change injector drivers from standard to additional. That should enable all processor outputs to run 4 individual injectors.
Selecting standard injector drivers is only telling the processor to output two injector driver signals, so you would only be running on 2 cyls
Ok so if I change the injector driver from standard to additional, would I still be running unlimited injection or semi/sequential?
On a side note, flooded the crap out of my cylinders. Lmao
http://s114.photobucket.com/user/671_is ... A.mp4.html
When you have it idling, change the values on the VE table one. VE Live will not do anything good for you since it will be out of the o2 range most likely. Did you change the additional option like BigLou said? It sounds like you did cuz my motor was missing when I switched.
I am unsure about the 1st pic since I am batch. But second with Use Table is corrected. Was this set when you made the video?
Ok. So when jumpers are in 4 = outermost, Sequential / Semi-Sequential, and Additional Injectors. Try turning on and see what happens.
Nothing no start. For batch do the jumpers just have to be in the "2" slot?
Yes put back in two and change ecu settings.
You guys are my hero. It runs. Unlimited injection with additional drivers in j8 and j10 in the outer most 4 position.
- BigLoukaT
Hell yea, good job. Now time to enjoy tuning (it really is nice with megasquirt and tuner studio)
- BigLoukaT
Also, it will be easier to try out sequential and injection timing when the engine is running steady, so just worry about getting good running at operating temp (verify timing, adjust ve) and go from there
