Car has been down for quite a while... I winged the timing map and am using live tuning for fuel.
Attachedis my project folder.. Can you guys please comment on my timing table and take a look at the logs? (I'm out of town for work and don't have MegaLogViewer licenced on this computer).
Looking to go rip on the motor this weekend and want to make sure things aren't out of whack.. Car feels like it pulls strong.
Thanks in advance.
Check my tune / logs
- Attachments
- CMJS13.zip
- (5.95 MiB) Downloaded 153 times
Re: Check my tune / logs
What psi did you run? @14psi, you have 14.2* which is safe. With the built bottom end, you can run do a .5:1 reduction. So 14psi * .5 = 7* deducted from 25* WOT to 18*. If cornfed, then that is a different story. .75:1 reduction is fine for E85.
I'm on 93. I believe I'm running between .75/1 deg/psi. I think you're post might have been backwards with corn.
That car absolutely rips on 11-12 psi right now. Feels faster than stock motor on 15 (probably due to cams and real turbo)
I just wanted someone to go through the recent logs and tell me if anything looks dangerous before I take it drifting this weekend.
Yes, you are absolutely correct. Been awhile since I applied this knowledge. The only thing wrong with the log is the TPS. Max is 89%. Try re-calibrating the sensor. AFR's, coolant, MAT's, and timing look good.
That's probably correct. Wasn't doing full pulls. Thanks for taking the time to check it out!
