Deka 80lb injectors
Iwannadrivemycar
Deka 80lb injectors
Post by Iwannadrivemycar »
If anybody here has used Siemens/Deka 80lb High impedence injectors P/N 110324 would you happen to have the Battery Offset settings for an AEM EMS 4 or Version 2?
Gavinh
Re: Deka 80lb injectors
Post by Gavinh »
Iwannadrivemycar wrote:If anybody here has used Siemens/Deka 80lb High impedence injectors P/N 110324 would you happen to have the Battery Offset settings for an AEM EMS 4 or Version 2?
I also need help with the same. Help is highly appreciated.
Thanks in advance,
Regads,
Gavin
OnTheChip
Post by OnTheChip »
