jim wolf ecu
jim wolf ecu
hello i was wondering what experience you guys have with the jim wolf ecu and what pro's and con's on it. What features make it so special etc i been running my ka-t with just a apexi afc 2 but retarded ecu would keep pulling timing etc. any help would be apreciated thx
________
Alain Prost
________
Alain Prost
- Forum Moderator
retarding your timing is needed. stock ecu + SAFC will only go so far and you can only retard the base timing so far until driveability nearly sucks. JWT ecu does it all for you so you never have to worry about it. the JWT 50lb/cobra mafs ecu typically runs 10.8:1-11.3:1 afrs straight out of the box where the 72lb/cobra mafs ecu usually runs 11.8:1-12.3:1 afr range.
they also have programs based on Z32 mafs as well and the lightning mafs which will receive feedback soon.
im thinking 50lb with z maf so it changes your on boost timing than right? can mulitple maps be used like the safc2?
________
My Webcams Hookup
________
My Webcams Hookup
who does this ethalpy?Globalsilence wrote:JWT Is a good ECU but also look at enthalpy he does the same as JWT and usually nets more HP.
________
Z4
- Forum Moderator
the ecu has no clue what boost you are running. instead it measures the amount of air entering the motor and adjusts fueling/timing accordingly.ImPLiCiTS14 wrote:im thinking 50lb with z maf so it changes your on boost timing than right? can mulitple maps be used like the safc2?
they can do secondary programs but generally its used for stuff like nitrous or 2 step.
what would u need a second map for?
thats what i was thinking something where i can have a daily driver map and a weekend maximum hp map
________
Extreme vaporizer review
________
