S13 ecu in a 95 altima?
Does anyone know how to make an ecu out of an s13 240sx work with the stock altima harness? Im desperate for an answer. If theres a jumper harness of some kind can u please post the link. Thank you
GXE with SE conversion
will not work 95 altima is obd2 and uses a white plug, s13 uses a blue plug and is obd1. i currently have a s13 ecu running my 2000 turbo altima right now. im going to start making conversion harnesses for 00-01 altima's to run obd1 ecu's. why dont you get in contact with JWT they make a ecu specifically for a 95 so no mod will be needed. unless you want to use a s13 ecu?
Not entirely true. There was a fine line cut off between OBD1 and 2 on the 1995 Altima. I lucked out and got my hands on a 1995 OBD1 5 speed. No emissions testing, horray! Regardless I'm not entirely sure on the real life application of such a swap. I just thought I'd put my two cents in. I suppose the easiest way to find out would be, can you pass emissions with a CEL/MIL throne.
