Cut Bumper with Oil and Power Steering Coolers( Suck it 56K)
Lance
Post by Lance » Sat Jun 23, 2007 4:12 pm
Here's my latest finished projects. Due to my coolant temps with no oil cooler at my last lapping day, a change was needed if I wanted to beat on the car all day and have peace of mind.
First the coolers
For oil I decided to use a stock FC RX-7 oil cooler because of the size and wide use by many other road racers and it was available from a local junkyard. From some measuring it comes out to be 202ci, which is pretty big in comparison to other stock coolers and most aftermarket ones.
All fitting are Russell and lines are -10 stainless
Time to cut and fit the oil cooler. The best place to mount it would be directly behind the bumper support above my intercooler. I wanted to keep the bumper support because the car is still daily driven and wanted to cut it in a way to serve as ducting.
Now the oil cooler in place
top view
My two longest lines, third short line was already in place
Relocation placement
Lines to block adaptor
I decided to use a Hayden four row transmission cooler for my power steering
Here it is in placed infront of the radiator
Since I have a JGS kit and no PS relocation bracket I had the resivour ziptied to my intercooler pipe and 2in from the compressor housing = not good. So I went ahead and moved it to the corner of the engine bay by the clutch master cylinder.
The cut bumper with everything done
Completed
We are having a track day on the 30th and hopefull my temps will be more stable then the last event.
Enjoy
Post by Justin L » Sat Jun 23, 2007 7:10 pm
that looks really good man. I love your set up.
dopeassjackson
Post by dopeassjackson » Sat Jun 23, 2007 7:13 pm
all this to an automatic? wheres your clutch MC? you should renforce your bumper support. looks like it will work flawlessly tho.
KA24ET RB20 turbo, 460cc
Sidewayzzz
Post by Sidewayzzz » Sat Jun 23, 2007 8:44 pm
dopeassjackson wrote:all this to an automatic? wheres your clutch MC?
If you look really hard, you can see the top of the cap, he took a weird angle photo but its a manual and if you read the text he says "Next to the clutch MC"
Lance
Post by Lance » Sun Jun 24, 2007 9:38 am
Yeah it's a manual, just a weird angle picture but you can see the cap and the hardline too. I planned on reinforcing the support but I'm not sure how much longer this will be a daily driver. Once it isn't she's getting completely gutted.
8-bit
Post by 8-bit » Sun Jun 24, 2007 11:03 am
looks great man! just don't run straight into anything or your IC/Cooler/Radiator are gonna eat the blow for sure....
Thanks for the FC oil cooler idea.
jrivera
Post by jrivera » Mon Jun 25, 2007 8:41 am
Looks good.
"All I have in this world is my balls and my word, and I don't break 'em for no one..."
nlzmo400r
Post by nlzmo400r » Tue Jun 26, 2007 2:07 pm
Lance wrote:Yeah it's a manual, just a weird angle picture but you can see the cap and the hardline too. I planned on reinforcing the support but I'm not sure how much longer this will be a daily driver. Once it isn't she's getting completely gutted.
join the club, gut dat bi*ch! I like your relocating power steering idea alot, I may have to do the same if this setup works well this weekend.
'my drinking team has a racing problem'
13.213 @ 108.72mph gt32- .6bar/ 13.81@ 102.5mph stock z33
Lance
Post by Lance » Wed Jun 27, 2007 10:49 am
Just to show a front view
