Pics of the 40oz.
- 1wheelwonder
Pics of the 40oz.
I figured one cannot be a member forever without posting a few pics of his or her junk (My car not Privates)
Yes I suck at the Camera.
- 1wheelwonder
Sorry Brad got ahead of myself
Arias +20 pistons, Ams rods, new crank, fully balanced rotating assembly on Clevitte 77s
Arp Head, Main and rods Bolts
Block Decked, bored, honed, hot tanked......
Head Resurfaced, new oem valvetrain, 248/248cams(waiting on Crower 264s)
Street port and polish, 3 angle valve job, all new oem timing junk, ditched leaky Cometic for Felpro Permatorque
Custom built by me intake manifold, intercooler piping (powder coated) and Log manifold (FTL) because I became frustrated with the RamHorn mani I partially constructed, full 3inch downpipe to Ebay special 3 inch exhaust.
T3/T61 aka Blowzilla .63 a/r stageV (looking for Ptrim upgrade), Tial 38mm gate
740cc Deatschwerk injectors, Sard fpr, Walbro pump, 300zx filter, blow-through z32 maf
Enthalpy Ecu, SafcII, Plx m300, Msd 6al, 2step, blaster coil, Aurora wires, Ngk plugs,
Clutchmaster stage 5 6puck unsprung on a fidanza flywheel, real B&M shifter
Jgs solid motor mounts, Peak performance tranny mount
Ole ass GR2 struts on Tein springs, subframe collars, cpillar bar and trunk brace
*And Newb purchased 5zigens with terrible offsets that are ghetto corrected with H&R spacers
Still need
Crower 264's
Meth injection
Still need
Crower 264's
Meth injection
- 1wheelwonder
Really like the intake mani....
Good looking car....
-PSi
-PSi
1983 280ZXT
1989 240sx KA24DET
1987 RX7 Lima 2.3t (project)
+1 for the clean coupe, that thing is sharp...
if you dont mind me asking how did you set up the 2step?
built motor, custom bottom mount, t67, midmount i/c, blowthru z32, tial w/g, hks ssqv, d/w 740's, l/w flywheel, comp 4 puck, b&m shifter, no p/s, no a/c, no emissions
<b>Under Construction</b>
spun a rod bearing
be back in no time
spun a rod bearing
be back in no time
- 1wheelwonder
I'm using a MSD 2step set at 5800rpm which connects to the 6al box.jwrose wrote:+1 for the clean coupe, that thing is sharp...
And to activate it I have one of those trans brake mushroom switches, just hold the botton down, push pedal to the floor, drop clutch and release the botton, simply and fun.
- 1wheelwonder
4inch turbo inlet from racecarparts.com I believe?Ihiryu wrote:that's one giant piece of pipe for your turbo, what is the OD for that piece of pipe?
Did you steal it from the underground fuel line from alaska? Sheesh.
Anyway looks nice, no offense, i'm not diggin the holes, but very nice setup!
I have been kicking around the idea of ditching the holes and cutting a section out like Nissanfanatic, Kingsblend.......
1wheelwonder wrote:4inch turbo inlet from racecarparts.com I believe?Ihiryu wrote:that's one giant piece of pipe for your turbo, what is the OD for that piece of pipe?
just cut the whole front part off. thats all, no funky holes, lots of fresh air to the core.
BTW, adding a koyo rad would finish off the engine bay real nice.
-Chris
T25 @ 8 psi
T25 @ 8 psi
- 1wheelwonder
Koyo or Mishimoto (sp)? is in the future, my car hates this Alabama airZenkiS13 wrote:1wheelwonder wrote:4inch turbo inlet from racecarparts.com I believe?Ihiryu wrote:that's one giant piece of pipe for your turbo, what is the OD for that piece of pipe?
I thought the current brass Koyo would suffice my NA needs years ago, I really didn't I needed anything more, but I was wrong.
- 1wheelwonder
Basically a blow-through style setup allows you to run a non-recirculated bov without stalling, whereas a pull through style setup may stall when the bov open to release positive pressure during shifts.Crash33 wrote:Really clean setup man love it but I too was wondering how you you did the whole blow through z32 maf because like they said before I don't see one could you please explain and again love'n it.
The maf is moved after the bov in my case after the intercooler and before the throttle body on the cold pipe.
Having driven both ways I decided to stick with blow-through because the car seems to idle better and such.
Some say you can damage a maf this way but I will believe it when I see it, 350z's run this way all the time.
are those 5zigen's 17's or 18's ?
93 240sx SE fastback
Garrett T25
370cc injectors
silvia smic
Calum Daughterboard
www.cardomain.com/id/collk
Garrett T25
370cc injectors
silvia smic
Calum Daughterboard
- 1wheelwonder
1wheelwonder wrote:Basically a blow-through style setup allows you to run a non-recirculated bov without stalling, whereas a pull through style setup may stall when the bov open to release positive pressure during shifts.Crash33 wrote:Really clean setup man love it but I too was wondering how you you did the whole blow through z32 maf because like they said before I don't see one could you please explain and again love'n it.
with your setup? i'd suggest koyo, cuz its a good radiator, but i hear mishimoto is decent for the price. i'd just buy a koyo and protect your investment.
-Chris
T25 @ 8 psi
T25 @ 8 psi
- Kfred
i got a two row aluminum radiator off of ebay, $145 dollars shipped, and it kept my temperatures steady on the dyno with 112degree ambient temps.
Dropped right in the mounts with no problems and i love it. Kind of like an ebay intercooler. Works 90% as efficient as name brand for 40% the cost.
Got it from ebay store oscarsradiators if anyone is interested.
Just run no bumber, Ultimate air flow. jk
I'll admit i'm jealous of your coupe if you show some more pics of the intake mani.
RIP Nate(480sx)...
- michael_barrientos
- 1wheelwonder
