The Slowest Ka-T Build
My car is a '89 Sil80 and I'm getting ready for an engine swap, but the new engine need the emission stuff removed and the timing is off. So I'm debating on installing motor and getting it running or slapping the turbo on and installing it after.
But I plan on using a JGS mani and running a stock sr setup (injectors, 8lbs.)
But I have tein basics, one piece alumanium drive shaft, tie rods and misc suspension parts.
not diggin the pink wheels!!!!
currently n/a.
currently n/a.
Re: The Slowest Ka-T Build
Sr injectors won't work on the SOHC engineFatboi303 wrote: But I plan on using a JGS mani and running a stock sr setup (injectors, 8lbs.)
Well ****! Well then I will use Rx7 injectors and up the boostkingkong8247 wrote:Sr injectors won't work on the SOHC engineFatboi303 wrote: But I plan on using a JGS mani and running a stock sr setup (injectors, 8lbs.)
Ans the rims were a last minute idea, but I get tons of attention for it so its worth it.
And my quarter panel are nothing but bondo, and its falling off and chipping bad.
Sleeper here I come
overfenders maybe? its a quick "fix". i am all about having a good looking body and that bondo would drive me nuts. it would be a shame to have a $600 frontend conversion and $300 taillights only to have flaking bondo in between. while your painting your overfenders you can remove the stock wing and rid yourself of that cancer causer and fix the scuffs on your rear bumper. so right now you're asking yourself "why haven't i done that already?"Fatboi303 wrote:And my quarter panel are nothing but bondo, and its falling off and chipping bad.
your car is hot.
