IT looks goodmewantkouki wrote:Home Depot Lip = Done
What did you do to your 240 today? [POST PICS!!!!]
- rn240sx
www.shopboldimpressions.com
06 Suzuki Boulevard S40
/\ all still current 8.30.20
- 2389cc_S14
besides tires, there no rubber left on the back half of the car, went poly crazy.
- biggie
Yanked my SAFC2 out (removed all wires from the harness). It had gone bad somehow and was causing the engine to miss at idle.
Removal and now running ok again. Bruise on my leg/ass from laying on the door sill too long.
Both of my S13s running again, world must be ending soon.
'93 Coupe GT32e/'93 Vert/'03 G35C
Always Broke!!!
Always Broke!!!
- Mark Washington
I had an issue with my SAFC-II when I cut battery power all my in out settings go bizerk/default then Throttle position goes backwards(100% off throtle 0% full)
I have my settings all saved on paper So its not too much of a pain.But I thought when you put the pass code in, It
would save, And it saves somtimes. I got sick of resetting it to 4 cyl setting all the %
and all that .So I am in the search for a Nistune standalone on a U12 ECU
So looks like My SAFC is coming out too.
- biggie
I wasn't using my SAFC (yet), have a rom tune, just had the SAFC to fine tune with, but it died, so not sure if I'll get another, maybe just save to build an engine and standalone or Nistune. But that takes money (engine, new injectors, etc, etc).
Did wash my coupe off as well (a lot of mud everywhere). Need to take pics of all 3 cars together while they are driveable.
Always Broke!!!
Always Broke!!!
- redpotatoes
Finished my JDM power folding mirrors installation. Bought them about 2-3 years ago and never took time to finish the wiring part. It's Working great and it is very nice to fold the mirrors wherever I park the car,
KA24DET GT2871R .86 Setup:
viewtopic.php?t=44222
- Forum Moderator
got it running again!! its been a while ....
- Mark Washington
^ oil pan!! I like it. I am looking into a windage tray for the SOHC.
I ended up just goin acusump so far but I am in the works of making the SR sump flange fit my oil pan. Rich's pan is worth it, but I cant justify that on a pan I could make.
Im sue his has baffles or somthing I dont know about nione the less Nice motor.
Perfect size turbo BTW.
速い速い シルビア ターボターボ
Its not the size of the turbo,Its how you spool it.
Take a look at the SOHC oil pan, it's already got one!Mark Washington wrote:^ oil pan!! I like it. I am looking into a windage tray for the SOHC.
Squeaks and squeals is the name of my wheels.
- Kamilitaryman
Rich is the only one that actually make a aftermarket one for the KA and makes it look good for that matter. It has a oil return line bung already on there. It lets you use a SR sump, which has built in baffles. I'm personally going to be using that oil pan on my KA. If I had the tools/skills to fab up my own I definately would. But yea, motor looks good!!!Mark Washington wrote:^ oil pan!! I like it. I am looking into a windage tray for the SOHC.
looks like you might have hood clearance problems cincy, what turbo is that? looks similar to my gt4088.
RIP Nate Moore (480sx)We will never forget you.240drew wrote:will someone go thru and show me how to wipe my ass? I am really confused, does the paper go in? ( I am just kidding) I am a bit bored.
R34SR wrote:save a tree, drag your ass on the grass.
- rn240sx
ahh, good luckCINCYS13 wrote:I think its gonna be about the same height as the valve cover wants its in the car at the slant that they sit at.. Its only a 30r so i dont see why i would have any problems
i threw on my turboxs mbc that ive had sitting around forever and went from 14.7psi to 22psi on my 35r
built motor, custom bottom mount, t67, midmount i/c, blowthru z32, tial w/g, hks ssqv, d/w 740's, l/w flywheel, comp 4 puck, b&m shifter, no p/s, no a/c, no emissions
<b>Under Construction</b>
spun a rod bearing
be back in no time
spun a rod bearing
be back in no time
-Pulled my spare intake mani apart
-removed the butterfly assembly and all that junk (ready to soak it in the vat and then seal up the unnecessary holes)
-discovered my pass qtr window had been leaking for a long time and I now have a structural issue I need to deal with
-removed rear seat and carpet from interior and began stripping the rust I found under the rear seat and in floor pan
-pulled rotating assembly from my spare engine so I can one day take it to the machine shop
-totally demolished my rear dash
-and cooked dinner for my nephew.
