What did you do to your 240 today? [POST PICS!!!!]
- hiimthehandyman
my buddy helping me trim my bumper a bit
test fit
still gotta put the piping and turbo in, but she looks pretty badass regardless
build thread: viewtopic.php?t=49596
[quote="Liteemup39496"][img]http://i130.photobucket.com/albums/p252 ... G_1312.jpg[/img]
[img]http://i130.photobucket.com/albums/p252 ... G_1310.jpg[/img]
guess those seats.... comfy as hell[/quote]
Nissan Sentra SE-R B13 91-94, direct bolt in or did you make custom rails? P11 G20 seats would look nice too
redrilled s13 rails to fit b13 seats then dropped right insignals13 wrote: Nissan Sentra SE-R B13 91-94, direct bolt in or did you make custom rails? P11 G20 seats would look nice too
Single Jingle love
Single Jingle love
things done
I installed a log type manifold installed HE351 on said manifold, took out brake pedal and master cylinder and clutch and cylinder. Waiting to gather enough funds too buy either wilwood pedals or the badass tilton pedal setup i have always wanteed to install aftermarket pedals in my 240sx. Installed intercooler and piping and oilpan with -10AN bung welded on i will try to get pics...
I was a moron and I got banned!
Did a compression test and found out that #2 and #3 are low. Soo...... I started to tear it down today. Overall not a good day, time for a built motor maybe
T2 bottom mount manifold, s14 T28, HKS 10psi Wastegate, HKS SSQ BOV, Innovate LC1 Wideband Kit, Ebay FMIC, Fidanza Flywheel, F1 Stage 3 Clutch, CXRacing Radiator, SS Brake Lines, Z32 MAF, Emance Tune + SAFC2, ARP Head Studs, Q45 Brake Upgrade
I have been wanting to something like this for a while I tried a while back but could not figure out how to git the curve on the side. What type of metal did you use and how did you get the curve for the side?cjr wrote:Made this
thanks
1993 240sx fastback FINALLY TURBOED!!!!
T3\60-1
JGS LOG MANI
740CC INJ.
NISTUNE
T3\60-1
JGS LOG MANI
740CC INJ.
NISTUNE
- street_240sx
- beercandrifter
hit 18 psi, thought the oil leak was coming from the timing cover, did rtv 3 times on the timing cover, found out the cometic headgasket was kinked between the head and the timing cover. started pulling off the turbo manifold/turbo that I just put back on which coincidentally is not easy to take on or off. have I mentioned how much I dislike swapping a head gasket with the turbo on? next motor I put in a car wont have a front timing cover like this.
- 2389cc_S14
- bmitchell_ga
Hooked up my narrow band output from my lc-1 and redid engine grounds. That fixed all my problems. Now its running good as stock, just a hell of alot faster.
97 S14
? @ 18psi (corn)
my build thread
? @ 18psi (corn)
my build thread
- Mark Washington
I have just been daily driving my car. Here's a pic from yesterday.
1995 S14 daily built block nismotronics sr20det Ecu running my ka-t, synergy green S14 5.3l turbo 240sx 1/4 mile traps 135mph on 13psi and dr's.
Holset HE341 Install thread woohoo!!
viewtopic.php?t=48692
http://www.playloudclothing.com/
- Mark Washington
[IMG]http://i945.photobucket.com/albums/ad29 ... _00013.jpg[/IMG]
[IMG]http://i945.photobucket.com/albums/ad29 ... _00041.jpg[/IMG]
Thanks
Thanks
速い速い シルビア ターボターボ
Its not the size of the turbo,Its how you spool it.
- Mark Washington
