What did you do to your 240 today? [POST PICS!!!!]
- nelson240sx
re-made my IC pipes. Moved the BOV to the cold side under the battery try to help clean things up a little bit. Still have to make a new intake pipe for the z32 mafs. I am also looking at running my pcv through the bov recir line to help clean up the intake even more.....should work
i just realized i got 2 of these so i looked at one and drove the other .i looked at the blue one like this ,and looked at the white one like this ,then i got in it and drove it to work.
currently n/a.
currently n/a.
wiped the bird s**t off my car, lol..
ka-t greddy 20g, enthalpy ecu, 440 injectors, ngk plugs and wires, bc v2 cams, megan catback, custom downpipe, godspeed fmic, safc 2, koyo rad, nismo thermostat, aem wideband, autometer phantom boost gauge, fidanza flywheel, spec stage 3+ clutch,j30 diff,n60 maf running 8psi!!
- Forum Moderator
turned the boost up to 18 psi and did some low throttle tuning .... waitin on cams
- nelson240sx
Made some oil catch cans today for the pcv setup....only have 20$ invested in them and they actually work unlike the ones on egay
- Forum Moderator
wanna send one my way??nelson240sx wrote:Made some oil catch cans today for the pcv setup....only have 20$ invested in them and they actually work unlike the ones on egay
- nelson240sx
i actually bought too much pvc pipe so i could make two more if i pick up some caps....check out my build thread in the pic section(pics of them). Probably be easier to make them yourself but, if you want i could make a couple more.
- ppctx
Thought about starting an Original Owner Club – 93 O.O.C. Other than that, just trying to figure out how to tune this bi*ch with all a Calum ECU, and all current available XDFs, have to offer. A friggen cold has me from getting out in the car…
S14 ka-t
I installed my Sr t25 set up over the holidays. Running great only on 6 psi.
Here's the list:
Sr t25 Garrett turbo stk wastegate at 6psi
xs manifold and dump (welded egr pipe to the dump)
3" down pipe with flex (I welded a nut for the downstream o2 sensor and added 1.5" of 3" exhaust pipe to fit the S14.
xs fmic kit sr s13 kit
Jwt ecu-setup for 370cc, stk maf and t25
apexi safc2 using the decel function
370 cc injectors from rb25det
walbro 255 fuel pump
greddy rs bov (not reciculated yet making car backfire on deceleration intermittenly)
Aem uego wideband
Autometer boost gauge
oil sandwhich block for oil feed, stainless -4an with a .063 restrictor fitting
coolant lines ran to the 5/16" elbow hose on the throttle body (S14 only). Feed and return.
S13 enjuku hotpipe
I built my setup in stages. Installed everything I could that would let me still drive it NA. The only problems I have had is my original boost gauge was showing me going into overboost. I installed the autometer t'd in with the Stewart Warner boost gauge and I was only boosting 6 psi. My car backfires on decel sometimes which is because the bov is not recirculated. I have my safc handling the decel so it doesn't stall. My wideband is showing the cat to be running 11 or so on the wideband in boost and in high boost i'm at 10 (rich). Cruising is between 14 and 15.5. I see alot of fluctuation in idling 14-16.5.
Here's the list:
Aem uego wideband
S13 enjuku hotpipe
- all shal perrish
looked around for a new diff..
possibly found one.,. .
and installed 25mm spacers.
www.autovaughnperformance.com
if you have some, pm me
Installed the brake and clutch cylinders with a RHD brake booster in my shell. Had a welder stitch some of the engine bay where the seam sealer was removed
Finally 300hp
Finally 300hp
- ppctx
Gazed upon the engine and said to my self "self, what is and why in the hell is it making that noise. i wonder if this is going to be another one of those minor things or is this going to be an expensive PITA problem"
Besides that, drove it to work to help put some break-in miles on the new clutch and noted how much more streetable it's becoming.
- Markdawg20
- nelson240sx
Found a killer deal on some 1000cc injectors, hoping to pick them up later this week. I might have some 1000cc injectors for sale later this weekend
- Walperstyle
- ppctx
found out that my wierd noise is probably just an exhaust leak at the mani or more likely the wastegate. I guess that goes in the win column as a cheap/PITA fix.
- all shal perrish
bought some s13 vlsd Axle shafts..
and though..
what the hell am i going to do abou tthis leak
and though..
