hersheskuirt's build(issue with idle 9-12-13)
The story starts on Dec. 5, 2006 when I joined the site. After I found this site I instantley fell in love with the idea of having a ka-t powered s13. I went down to a salvage yard just ten days later, and picked up an s14 ka. The build is still not finished and I still have a bunch of things to get. The eingine is completely built with forged internals and a fully built head. All I need now are the most important things, all of my turbo stuff and other misc. things. This is the first engine I have ever built and it is actually my first car I have ever owned. And I wanted to do it right the first time so I don't have to do pull it out and do it all over. My goal for the car is to make around 450 whp and maybe close to the same torque. Now on with the list.
Engine
-Eagle H-beam rods
-Arais pistons
-ARP head/main studs
-Clevite bearings
-BC V2 cams
-BC dual valve springs/retainers/seats
-BC valves
-Head and block completley machined
-Fel-pro gaskets
-Head ported and polished
-NGK BKR7E spark plugs
-OEM oil pump
-OEM timing chains/tensioners
-all emissions removed
Fuel
-SS Braided line
-75lb Low Z injectors
-Fuel pressure gauge
-Mitsubishi risitor pack
-Fuel Lab regulator
-Walbro 255lph fuel pump
Things to get (AKA Christmas List)
-Full Race turbo kit
-Gauges
-Wideband
-Ebay FMIC/Piping
-EFI Specialist ECU
-Z32 or Q45 MAF
I am sure that there are more things to get or things that I have gotten and just can't remember. I will add more things as I get them and keep the thread updated with as much as I can. Tell me what you think, and what I might want to rethink of doing.
Engine
-Eagle H-beam rods
-Arais pistons
-Clevite bearings
-BC V2 cams
-BC valves
-Fel-pro gaskets
-OEM oil pump
Fuel
-SS Braided line
-Fuel Lab regulator
-Gauges
-Wideband
-Ebay FMIC/Piping
-EFI Specialist ECU
-Z32 or Q45 MAF
I know it's a pricy set up, but I am looking for the most efficient turbo and manifold I can get. I looked at that manifold on the front page and I do think that it is an awesome looking manifold, but I think that the full race manifold will be the better choice for me.titanoh wrote:the full race twin scroll kit is pricey, but you can make some real nice numbers with it. If your going for like 400-450whp, you might want to think about a GT30 and that manifold on the front page on ka-t.org (scroll to the bottom). It will be quite cheaper and give you the power your looking for.
I got the cams before I knew much about them. Before I got them I did some research but not as much as I should have. After I got them in I found lots of negative things about them. So insted of just selling them I thought that I all ready have them and lets see what I can get out of them. And I do plan on getting the adjustable gear so I can get more power out of them. Once I get the car going and I see what kind of power I am making I am going to get another cam like JWT or PDM cam to compare the difference.Lucient wrote:Make sure you get some Adjustable cam gears to degree those BC cams but good looking build so far
Thanks, I know some people that have unsprung clutchs and they drive the car every day. They just say that there is a trick to drive with them and make it smooth it will just take practice to know how to use it and not look like it is your first time driving the car.sloka-t wrote:****, good luck with that unsprung clutch
Well I got my intake manifold back from my brothers shop. He was removing and cleaning most of the casting marks on it. I thoght it would be a good idea to put my fuel rail and injectors on since I had nothing else to do. Now that my computer is operating correctly I can now post pictures of what I did.
- cesaturn95
Thanks, it looks good but I would like it better if it where a mirror finish if all possible. But I am to lazy to slave away at it any longer then what my brother and I have invested in it. After I get every thing put together and running, then I might have to see what it will cost to get every thing chrome platted(intake mani, valve cover, front timing chain cover, and anything else I can think of). If it's not that much then I think I will have to do it. I think that it would look really nice and clean.cesaturn95 wrote:nice touch! ive never even tought of that before with the intake mani!
Well it has been awhile since I have done an up date on the build. I have purchased a couple new things since I last posted. I bought a trans and 1 peice drive shaft from a member on this site, KA24ETZTM is his name. Then after getting the trans and drive shaft I got 90% of my turbo stuff, from another member on the site, GREASER. I don't have all the specs on the turbo right now. I lost the paper I wrote everything on. But I do know that it is a t4 with a stage 5 turbin. Everything is laid out the way it would be set up in the car.
Replacing polished intake with this one.
Replacing ebay FMIC with a Greddy one.
Think I am going to replace this with my HKS.
And two of my dogs.
And two of my dogs.
- slideways11
- street_240sx
- KA24ETZTM
Hey man nice to see your build coming along. I love the turbo setup. What turbo manifold is that? What are your power goals. Hey when you get the chance take a look at the progress on my build and tell me what you think. Looks good man keep it up.
My Original Build Thread: viewtopic.php?f=5&t=35224
- street_240sx
ihavea treadstone mani which is basicly the same. but what turbo you running to spool so long? on mine with a 50trim i want to spool by 3.5-4kturbo2nr wrote:i have a rev hard manifold and a stock intake manifold so you may spool up a little quicker then me. i start to spool around 3700 and get 11psi by 43-4400 rpms.
i cant wait to see you make over 500whp! your gona like it when it hits ass likes to go sidewayys
03 evo8 gsr: stroker 2.3
- Alonso
with the 50 trim it'll be sooner than that...trust mestreet_240sx wrote:i have a treadstone mani which is basicly the same. but what turbo you running to spool so long? on mine with a 50trim i want to spool by 3.5-4k
AWS D17.1 certified
AWS D17.1 certified
That's about what I thought it would be at. Yeah I can't wait to hit 500WHP!turbo2nr wrote:i have a rev hard manifold and a stock intake manifold so you may spool up a little quicker then me. i start to spool around 3700 and get 11psi by 43-4400 rpms.
The manifold is a custom piece from MRD in Virginia. They made it for their shop car and made 600whp with the turbo setup. My power goals where around 350-400whp but things have changed and now I am looking for about 800-900whp possibliy. Na just kidding I am looking for 450-500whp. I CAN'T WAIT!KA24ETZTM wrote:Hey man nice to see your build coming along. I love the turbo setup. What turbo manifold is that? What are your power goals. Hey when you get the chance take a look at the progress on my build and tell me what you think. Looks good man keep it up.
- street_240sx
yay!!!! hahaAlonso wrote:with the 50 trim it'll be sooner than that...trust mestreet_240sx wrote:i have a treadstone mani which is basicly the same. but what turbo you running to spool so long? on mine with a 50trim i want to spool by 3.5-4k
Well I got board last night and thought that it would be a good idea to see how everything is going to fit. So here are some pictures.
I think that I have a close clearence issue.
Need to make a good heat sheild for this.
I need to do something with the valve cover. I have had it several different colors and polished. I just can't make up my mind, so what do you guys think that I should do with it. Oh yeah one more thing I am in need of a MAF, maybe a Z32 or something equivalent.
Oh yeah, I found some pictures of what car the turbo stuff came from.
Last edited by hersheskuirt on Tue Feb 23, 2010 11:09 am, edited 2 times in total.
