'95 Zenki KA-T build
wesamiss
Re: '95 Zenki KA-T build
Post by wesamiss » Mon Mar 07, 2016 12:23 pm
Kamilitaryman wrote: Image
I see some BL love there... nice. I have a few OP8 toons, all legit. xbox gt wesamiss
Love that reservoir set up. I had got the same one from eBay a while ago, but ended up not using it because it was too big.
Any updates? Has it warmed up enough to give us any updates?
WES
Kamilitaryman
Post by Kamilitaryman » Sat Apr 23, 2016 9:46 pm
wesamiss wrote: I see some BL love there... nice. I have a few OP8 toons, all legit. xbox gt wesamiss
My wife subscribes to LootCrate so I steal some of the stuff she gets. I needed a new mouse pad at work so it worked out great lol. I never really got into BL though! Watched my brother and friends play but that's about it. I'm more of a Battlefield fan.
But yes, it's finally starting to warm up so the build will pick back up soon! I noticed that you picked up another S14 and are nearly done with yours....I'm jelly.
Post by street_240sx » Mon Apr 25, 2016 12:52 am
Where did you get the cover for the dizzy?
Kamilitaryman
Post by Kamilitaryman » Tue Apr 26, 2016 1:14 am
street_240sx wrote:Where did you get the cover for the dizzy?
I think I emailed him directly about it. It took me a while to track him down too. I checked my email for ya but I must've deleted it a while ago so I don't have a lead for you unfortunately. All I remember is that his name was Wen Lee or something like that.
S14wayz
Post by S14wayz » Wed Apr 27, 2016 6:41 pm
this build is awesome :) I'm going to do the same with P/S when I get a new shell, looks soo damn clean man keep it up
My S14 Build Thread
viewtopic.php?f=40&t=59534
Kamilitaryman
Post by Kamilitaryman » Sat May 14, 2016 7:52 pm
S14wayz wrote:this build is awesome :) I'm going to do the same with P/S when I get a new shell, looks soo damn clean man keep it up
Thank you!
Changing things up a bit. Decided to ditch the top mount and go with a bottom mount manifold. I came across one I couldn't pass up. I'll let the pictures do the talking. I also ordered a set of rims, which will be used on the 350Z for a bit. Once this project is done, I'll be transferring them over. They're Volk Racing TE37V Mark-2, 18x9.5 et15 and 18x10.5 et15. They won't be here for another 2 months though.
Kamilitaryman
Post by Kamilitaryman » Mon Jul 04, 2016 8:15 pm
Update:
As I've stated before, I'm changing things up a bit. Put in some work on the bottom mount and other crap over the past few weeks. Powder coated more **** that was spray painted when I started this damned project. Installed fresh, stainless studs throughout. New oil dipstick guide, new oil feed and return. Also installed a -4AN port in the coolant drain hole, in case I need a coolant feed for future setups. Just a few more things and it's going back in for good (hopefully).
SoundEfx
Post by SoundEfx » Wed Jul 06, 2016 12:05 pm
There you go again, putting me to shame....lol
What made you go bottom mount?
Image << Yuh dun know!!
Kamilitaryman
Post by Kamilitaryman » Thu Jul 07, 2016 5:18 am
SoundEfx wrote:There you go again, putting me to shame....lol
lol - gotta keep going or it's going to rust away!
I went with this manifold for a few reasons. One of them is the fact that it's a AMS manifold. It's fully warrantied so I'm good if anything happens to it. It'll also be easier to fab/mate the downpipe to the rest of the exhaust and lastly, there motor balance in the engine bay will be improved since the weight of the turbo will be down low now.
Kamilitaryman
Post by Kamilitaryman » Thu Oct 06, 2016 6:02 am
Did some **** over my weekend. Finished up the oil plumbing by installing a 1/8 NPT -T- on the filter adapter to run the oil pressure sensors. Also mated the transmission to the motor for the 1st time since 2009, and then dropped it into the chassis with some help from friends. Booked a welder to fab up all the intake and exhaust piping. She'll be going on a trailer in a few weeks here. Getting there!
Post by street_240sx » Sun Oct 09, 2016 6:28 pm
What fittings did you use for coolant? So that will be the drain for the turbo, where will you get the feed?
Kamilitaryman
Post by Kamilitaryman » Wed Oct 12, 2016 9:04 pm
street_240sx wrote:What fittings did you use for coolant? So that will be the drain for the turbo, where will you get the feed?
A few others have asked me the same question. I bought it through Summit Racing back in 2010, but they had since updated their website and I lost my order history in the process. I just spent a good amount of time looking through my emails and I found the fitting info in one of them!!!
So, for those of you who would like to use the drain hole as a feed for cooling a turbo/wastegate, here's the fitting you'll need. You can run the return to the back of the intake manifold.
Fragola 491201-BL: https://www.summitracing.com/parts/fra-491201-bl
From what I remember, you'll need to re-tap that thread in order for this to work. My father, who's a manual machinist, helped me with this.
Kamilitaryman
Post by Kamilitaryman » Sat Oct 15, 2016 3:07 am
I knew I was forgetting to post something.....the shoes I bought back in April arrived from Japan late July. I'm running them on the Z33 for now. Once this project is complete, they're going on the Zenki :)
Post by street_240sx » Thu Oct 20, 2016 6:03 am
Hmmm wonder why you have to retap it? I have the taps at my work so it shouldnt be an ordeal. What part of the intake? I dont have a factory one anymore so i only have the heater hose, maybe tee into that for the return?
Kamilitaryman
Post by Kamilitaryman » Thu Oct 20, 2016 7:14 pm
street_240sx wrote: Hmmm wonder why you have to retap it? I have the taps at my work so it shouldnt be an ordeal. What part of the intake? I dont have a factory one anymore so i only have the heater hose, maybe tee into that for the return?
I believe we did it to clean the threads up a bit and to seat the fitting deeper into the block. You should be able to -T- into the heater core return hose.
Post by Alonso » Fri Oct 21, 2016 9:35 pm
the coolant plug on the side of the block has 1/4" BSPT threads.
Kamilitaryman
Post by Kamilitaryman » Sat Oct 22, 2016 1:24 am
Alonso wrote:the coolant plug on the side of the block has 1/4" BSPT threads.
Yup, additionally, the 1/4" BSPT has 19 threads/inch VS the 18 that the NPT has.
Kamilitaryman
Post by Kamilitaryman » Fri Dec 30, 2016 8:06 am
Sup guys! I'm back again and I've got a great update to an otherwise, old and drawn out build. I have no one to blame but myself for it since I can't keep focus on one project. Believe it or not, the Z33 I bought late last year will probably be boosted before I finish this build lol I ended up going crazy on Black Friday this year and ordered a complete turbo kit for it and plan on starting the install on that early in April. It should get done over a weekend or two and the work will resume on the S14.
So, the update:
I was finally able to link up with my welder and I'm very glad I chose this guy. He's very meticulous about his work, his welds are sexy and the guy doesn't slack. Basically, the intercooler piping got finished on day 1. The IAT bung is hidden but easily accessible on the cold side. All that's left to do is the pipe to the compressor inlet. We mounted the eBay catback and added some v-bands to it so that we can tie the downpipe into it. Most of the downpipe is finished up with some delicious pie cuts and melted together with back-purged beads (no pictures of this until it's 100% done) When I left his shop last night, we were trying to figure out if we should dump or recirculate the WG as the space is tight in there. I also mounted up the 1-piece drive shaft and found out that the stock Nissan bolts don't work with their flange. No biggie, I'll get that finished up today with some new bolts.
Here's a few pics I managed to snap yesterday :)
SoundEfx
Post by SoundEfx » Fri Dec 30, 2016 12:59 pm
Why can't people like you live in WA? lol
Keep up the pimpin' work man.
Kamilitaryman
Post by Kamilitaryman » Sat Dec 31, 2016 7:51 am
SoundEfx wrote:Why can't people like you live in WA? lol
Haha thanks! :)
The down pipe is done! Of course I would forget to take a picture of it installed but I'll get one later today after I pick the car up. We ended up not recirculating the WG as it would've been a real PITA installing the downpipe with the recirc. pipe on it. Now that all the piping is done I can focus on all the little **** and hopefully have it running real soon here!
2017 is going to be a good year!
SoundEfx
Post by SoundEfx » Wed Jan 04, 2017 11:37 am
Nicely done sir.
Now when can I ship my car to you so that you can complete it? lol
Kamilitaryman
Post by Kamilitaryman » Thu Jan 05, 2017 12:24 pm
SoundEfx wrote:Nicely done sir.
Thanks man! You sure you wanna do that? It might take me 7 years to complete it lol
SoundEfx
Post by SoundEfx » Fri Jan 06, 2017 12:17 pm
Sure, why not?
There are some shops that take longer and still do a bad job....lol
Post by adamky » Fri Jan 06, 2017 12:58 pm
I wish my intercooler piping was that short
Kamilitaryman
Post by Kamilitaryman » Thu Jan 12, 2017 2:33 pm
adamky wrote:I wish my intercooler piping was that short
I'm really hoping the short piping will help with overall throttle response. Also curious to see how well this cooling setup will work on this radiator. Hoping for the best!
bluestorm
Post by bluestorm » Wed Mar 08, 2017 6:05 am
Everything looks great!
Kamilitaryman
Post by Kamilitaryman » Fri Jun 30, 2017 12:47 pm
Well, I was going to post an update on the build but then I found out that photobucket ***** my whole build thread up. Not just here, but EVERY other build thead I have ever started. I will be looking for a solution to get this thread re-worked so that the pictures show again but not anytime soon. I'm so ***** angry I could punch a wall...
I do have one thing for you guys: it made 405hp/370tq on 11psi.
https://www.youtube.com/watch?v=QKJ3zKVHVm8
https://www.youtube.com/watch?v=Ym-SWlhGt5U
The 240 is next....stay tuned for updates. They are coming....I promise....it will be running this summer.
Kamilitaryman
Post by Kamilitaryman » Fri Sep 06, 2019 10:24 am
Hey everyone,
Well, I'm not even sure where to start. Anytime I think about my build thread here, I feel anxiety and anger, followed by resentment to the photo hosting company that is known as Photobucket. I learned the hard way of trusting 3rd parties with holding onto your priceless memories. I was able to download all of my pictures that were associated with this build, but those bastards bumped the resolution down to 800x600 on ALL of my pictures. It completely discouraged me from updating this thread as it literally killed all of my uploaded photos. Anyway, I decided to give this one more shot and I'm currently uploading my photos to a different site. I also got myself a Dell server with plenty of storage space and will be eventually setting that up to host any future pictures and not worry about this happening ever again.
To those who followed my build from the start and gave up - I apologize for leaving you hanging. This project took way too long if you ask me. I wish I could've done things differently at times, but there's nothing I can do to turn back time. While I get my photos organized and ready for sharing, I'm just going to drop one here with you until I feel like I can share the rest and give you some insight/information on context of each photo. Without keeping you guessing - yes, I finally finished the project and it idles on it's own. I'm, just waiting on a date with my tuner.
