s13 build ...56k take a nap
my goal: build a track car for only drifting
im spending as little as possible im buying everything used and getting sick deals..
all i can say cash is king lol
price of car $100 with some small frame damage
the car came with some extra parts as well so it was a win win!
so this weekend 10/2/09 to 10/4/09
stich weld as much of the car as possible
heres the pic
cars pretty straight
the bad
so what i did to fix the problem of the chassis and for the welds
Best tool to remove the glue from the panels
the sound thing was almost removed, ran out of ice
fast foward another week, i pick up a free rolling 240sx shell! from member carlosncdi Thanks i was picking up some autometer gauges and he ended up telling me hes getting out of the scene and he is junking the car... this was all over the phone, hes like the car has a big quarted dent and the roof is caved in... im like dam. can i go check it out? hes like sure ? It was missing doors and motor and wheels roof looked bad how it was caved in but we poped most it out.. so i eneded up towing the car the next day.. but lucky me i had the other 240sx switch the doors and bam old car sent to junk yard got $60 bucks for scrap metal...
it came with nice dash and free fender braces.... he did have some parts he was going to sell, so i bought them all, kazama lower control arms, tein inner and outer tie rods welded diff and rear camber arm
so i started to stiched welded the car the whole car! again.. i removed all the interior car should be ready in about 3 weeks for paint here some pic of the damage and the welds
so i did the tubes, a totally different than what everyone is accustome to ...than the normal, all i need is to swap in the motor make the holes for the intercooler piping.. goog thing is that everything will look hidden so will see how it comes out , as far as the radiator support im going to put a new one in but im going to do it so i can bolt it on so it can be easy to remove and install engine if needed
heres the paint its of a bmw m3, dont have the paint code paint was given to me like a 1-2 years ago.. still good, i was going to paint my civic that color but ended up with another color
here is the pic of my old civic its a s2000 moon rock metalic
here some pics of other things i done
ebay top mount manifold got it for cheap re-welded it should not crack
heres the motor on and the fitment with the ebay manifold not to bad
so today i did the intercooler brackets and the cold pipe
made the brackets for oilcooler and methanol pump, and maf sensor. brother and i started working on the doors engine bay pretty much done. need to convert to a 89-90 power steering i have no room for the 91 setup
heres the pic
the bad
godrifttoday
- Alonso
That manifold is going to crack,guaranteed. Not only because it is ebay junk, you rewelded it with mild steel wire.
Since you have a welder, why not just MIG your own custom manifold using mild steel sch. 40 weld els.
AWS D17.1 certified
AWS D17.1 certified
The turbo I have in the picture is blown... I just installedthe motor for mock up... I'm basically done... I need to do a couple of small things and the motor will be out do I can paint the engine bay... As far as painting my civic yes... It was my first paint job ever... If u are going to attempt it for it first time please!!! Buy or use a quality gun... It makes a world of a difference... It helps u cover up alot of mistakes that would have shown with cheap guns... So itsnake u feel like if u have a special gift lol...I did get a little bit of orange peel but I wet sanded it and it came out great... But u should have seen when I did a test spot with the cheap gun ... Omg ugly... Everyone thought I paid big bucks on painting it... But cost were appx 400 with paint supplies not sand paper and stuff like that... For the clear I used glasurit... It used in highend cars... I luckly know someone that got me a bottle for 180 instead of the normal price of 400
godrifttoday
I used a devil bliss and for the primer I Used forex i think when I get home I'll post the gun name... But u used 2 different guns though... The devil cost about 280 and th primer is 120 bucks I believe... But once u get good u can do little side jobs and what not... And for practice u se something u don't need... But honestly all u really need in my opinion is common sence and a steadY hand and u will be fine... I was on YouTube alot, seeing how other people paint so u can get an idea
godrifttoday
- wannaboost?
- redline240sx
HAPPY THANKSGIVING TO ALL i went to the junk yard today pick up a couplt things i needed it was 50% off! well i wanted to make a vented hood, i did not want to buy a aftermarket one for the reason they cost much, and i can use it for something else. so my solution was the following.... $10 of 18 gauge metal, not done yet still need to do a couple more things here what got me into drifing i was sliding an integra lol back in the day
and the hood
and the hood
godrifttoday
- Walperstyle
havent had any times to post, but i got a couple of things done i picked up a right hand drive z32 did my lines and i also just did a couple of other things im prepping the car for paint so hopefully soon. well ok im pretty good at following directions, and woking with cars but im stuck here. i posted the pic of how my lines are set up. i bleed the brakes but i only get fluid being sent to the front of the car... i get no fluid sent to the back of the car none! with and with out activating the hydro e brake. i do get fluid to the back of the port on the cnc while pressing the brakes but no fluid comes out from the side port that is going to the rear brake.. so im stuck here any ideas? and solutions?
car s13, no motor yet, z32 right hand drive brake master cylinder ( use for turbo line clearence)
godrifttoday
- slideways11
it stops the bmc from moving when brakes are apllied it actually works. firmer pedal feel too i got it from here
http://www.phase2motortrend.com/cispbrcyst24.html
godrifttoday
- TanManS14
Was the fender tub done knowing that the hood was gonna be placed like that? It prolly gets some nice air flow through there, the tub's look like they hug the bottom side of the hood pretty good, seems like it'd keep the air from randomly swirling in the aquard parts of the engine bay. Kinda neat.
well i did the tub because i wanted the engine bay to loook clean with out much stuff in there. as for airflow we shall see but like u said it does make a good point.. i started on my rear wheels
here a video
http://www.youtube.com/watch?v=YVWgh_MZ6xQ
pulling teeth!
here a video
pulling teeth!
godrifttoday
