nis720 KA-T build
- nis720
Re: nis720 KA-T build
Addressed the sloppy shifter bracket issue I had with the Xcessive short shifter kit. Thanks to wannaboost.
viewtopic.php?f=1&t=60939
Here' my pics.
Here' my pics.
Still plays with trucks
http://members.cardomain.com/nis720
All anybody wants is a normal life and a cool car... most people settle for the car - Titus.
Looks great man. I just got my Mazworx/Z32 setup in this weekend. One thing I want to warn you about is that the shifter rattles/buzzes like crazy. I've searched online and it seems like it's a common gripe about the Mazworx shifter. Luckily, I have a loud stereo that I can crank up to drown it out, but it's still annoying as hell. I'd be interested to see if your does the same thing. I'm either going to try to fix mine, or get a whole new shifter. I've read good things about the Z1 Motorsports shifter. I hope it doesn't come to me having to buy a new shifter, but if I can't fix the Mazworx one, that's what I'll have to do.
- nis720
I had no idea the shifter itself has that issue. Hopefully I will be strapping the truck down on the dyno today for a tune. I'll keep you posted on how my shifter works out.adamky wrote:Looks great man. I just got my Mazworx/Z32 setup in this weekend. One thing I want to warn you about is that the shifter rattles/buzzes like crazy. I've searched online and it seems like it's a common gripe about the Mazworx shifter. Luckily, I have a loud stereo that I can crank up to drown it out, but it's still annoying as hell. I'd be interested to see if your does the same thing. I'm either going to try to fix mine, or get a whole new shifter. I've read good things about the Z1 Motorsports shifter. I hope it doesn't come to me having to buy a new shifter, but if I can't fix the Mazworx one, that's what I'll have to do.
- nis720
Minor updates. Seats back from upholstery.
First time we strapped it down I was having issues. Turns out the plug wires for #2 and #3 were switched. Took me a few days to figure out after checking just about everything else 3 times.
New setup with .63 exhaust housing and boosting 15lb (previously 12lb with JGS log mani). What do you guys think it will make?
I have no idea what it will put down, but this is definitely one of my favorite builds on this forum. That "upskirt" pic is nice! The rear wheels, tires, and stance are dead sexy.
I assume your shifter isn't buzzing like mine or you would have mentioned it..?
- nis720
I have a big hole where the shifter is at and currently don't have the carpet in it so it's very noisy and can't really tell if it rattles. It does have some play in it and I can see how it could be an issue. But reinforcing the bracket and linkage really makes shifting feel very nice and tight.adamky wrote:I have no idea what it will put down, but this is definitely one of my favorite builds on this forum. That "upskirt" pic is nice! The rear wheels, tires, and stance are dead sexy.
- nis720
Battleling some heat issues with the intake temp. This is on a conservative tune and only revving to 5500rpm. I think there's more power up top but didn't want to push it till I get the new head in and turbo cam.
- nis720
Sadly with all the upgrades (tune, better flowing header, Z32 trans and 8.8 rear end) my weaklest link once again is the motor.
Took for a spin last night and blew the motor. Motor ran untuned for 4 years with occasional pinging and I think it was already hurt. This would explain the numbers not being where we expected them.
I had just finished the trans cover.
Damn, that sucks it blew. Built motor time?
The trans cover plate looks good.
You love that he blew it up?Fash00 wrote:LOVE IT!!!
- nis720
Motor ran great for 4 years untuned. Pinging under heavy load and top end. I think that's what took it's toll on the motor. Now that I got it tuned and beefed up the trans is when it called it quits. Honestly I'm not mad about it because I did enjoy it. This also gives me a perfect chance to finally get the head completely done and install the turbo cam and solid lifters.adamky wrote:Damn, that sucks it blew. Built motor time?
I think he meant the build in general with that comment.
Here's a quick vid of the dyno pull.
http://youtu.be/sXRhVWT1MUg
- street_240sx
Yea with numbers that low. I wouldve suspected an issue. Sucks that it blew but after 4 years you can't complain
03 evo8 gsr: stroker 2.3
- nis720
Lets try this again... this time all out
Subscribed to this build. Sorry to hear about the motor; it sounds like you got some great use out of it though. That's awesome you got a hold of another motor too..... and now the fun begins :]
Are you planning on leaving the carpet out?
So before it blew what did you do for the tune? what injectors where you running? Just out of curiosity and I wish I would have done my truck up nice! I have my 240 and d21, but I daily the d21 and I have a son on the way and he cannot fit in it:( so I am selling it sadly..
Beautiful truck.
Beautiful truck.
Cosmetic Head Gasket
Eagle Rods
Stock flywheel
Spec Stage 3+ Clutch
ARP'ed Everything
Clevite Bearings
SARD 850cc Injectors
Eagle Rods
Stock flywheel
ARP'ed Everything
Clevite Bearings
- nis720
I want to put a new carpet back in... but I'm getting the engine bay repainted and the inside of the cab done too. Not sure if I will want carpet once that's done.cleantune wrote:.
I run Nistune for engine management. I ran RX7 460cc injectors for 3 years then I switched to ID1000's the last 2 years. Truck was never tuned and had some detonation occasionally. So 5 years of that took their toll, but I later found out my builder used pistons that were not up to par. Either way I got a good 5 years out of it. This build is going to be better, also redoing the head with O&J Stage II turbo cam and solid lifter conversion.Gotenks64 wrote:So before it blew what did you do for the tune? what injectors where you running? Just out of curiosity and I wish I would have done my truck up nice! I have my 240 and d21, but I daily the d21 and I have a son on the way and he cannot fit in it:( so I am selling it sadly..
Beautiful truck.
Yeah I hear you, a carpet less floor with a fresh coat of paint looks really good!nis720 wrote: I want to put a new carpet back in... but I'm getting the engine bay repainted and the inside of the cab done too. Not sure if I will want carpet once that's done.
If you went that route, would you remove the sound matting/ deadening material too?
- nis720
Carpet makes a big difference in sound. I think I'll keep it for comfort too. It is a show truck afterall with a little go.cleantune wrote:Yeah I hear you, a carpet less floor with a fresh coat of paint looks really good!nis720 wrote: I want to put a new carpet back in... but I'm getting the engine bay repainted and the inside of the cab done too. Not sure if I will want carpet once that's done.
- nis720
Going thru my garage and gathering all the extra parts I've collected over the years. Some stuff I forgot I had.
Ceramic coated EGR intake adapter (getting blocked off) and chrome hood latch.
- nis720
Update.... getting all the parts I need to get this motor done. Still waiting on the eagle rods.
Finishing up the AN conversion.
New stainless fitting for the lower intake water line.
- nis720
Picked up the motor parts from the machine shop. Ready to be put back together.
Arias pistons and eagle rods fully balanced.
Head fully done with O&J stage II cam and solid lifter conversion with upgraded springs for higher RPM.
Nice...keep up the good work man.
- nis720
Doing the long overdue repairs to the front wheels.
Adding an extra inch to the front wheels and changing offset.
- nis720
Fresh new intake
Carnage of the hurt motor.... piston #1 missing a chunk and #3 showing signs of damage too. Guess that explains the low numbers on the dyno.
Nice bro, at the very least you will now be able to push the new engine to its real potential.
Any updates on this truck? Met you a few years ago at the Fontana SouthWest Datsun Pickups BBQ, and loved the truck.
It has been a while without updates. What's the latest status on this beauty?
- nis720
Been a while since I've been to those meets. What truck were you driving?confusion wrote:Any updates on this truck? Met you a few years ago at the Fontana SouthWest Datsun Pickups BBQ, and loved the truck.
Only updates are making things shiny but not one thing completed. Just parts everywhere.adamky wrote:It has been a while without updates. What's the latest status on this beauty?
- nis720
The wheel barrels are polished, but waiting on the inners to get clear coated before i put them together.
The AN conversion is also waiting on more $$$ to finish buying the parts
New radiator waiting for AN fitting.
Gasket kit
Gasket kit
Looking good. Is that red paint inside the block, or some other kind of coating?
