New beginning
New beginning
Postby rtm240sx » Tue Jan 12, 2010 4:21 pm
Over the last four years, I have been putting together my setup. Began with a cheap turbo setup, but decide to to it right the first time.
ONLY REAL MEN STAY KA
rtm240sx
Postby Turbo24sxt » Tue Jan 12, 2010 4:47 pm
great looking car man .. silvermoss is an awesome color ... keep up the good work .. what is your plan for the motor?
http://www.ka-t.org/forums/viewtopic.ph ... sc&start=0
Postby rtm240sx » Tue Jan 12, 2010 4:55 pm
Full build and most likely a t3/t4 set up. Thanks.
rtm240sx
Postby pinky121388 » Thu Jan 14, 2010 1:33 am
looks good d00d. I doing the same with the T3/T4.
What you going to do exactly to motor, like what companies are you choosing to use,
92 S13 Vert
pinky121388
Postby rtm240sx » Thu Jan 14, 2010 10:55 am
I have so for the is
ARP undercut headstuds
Cometic 90 .060 HG
Felpro gasket set
Coming soon
Wiseco 9.5:1 90mm pistons
Bc or eagle rods
ARP main studs
Unsure of if I want build head, if I do most likely bc cams or crower cams bc springs and valves.
Turbo kit setup I have so far
Ebay manifold most likely to switch
Dsm 1st gen bov
oil lines
turbonetics evolution wastegate
Huge ass fmic
Need
T3/T4 .63 ar
Boost controller
downpipe
Intercooler piping
I have
S-AFC2
Apexi boost gauge
Hks pressure gauge for oil
Hks temp. gauge
greddy turbo timer
Walbro already installed
Need
Efi specialist Ecu
suspension parts
Tanabe springs
Koni shocks
Circuit sports tension rods
god speed sway bars fronts did not fit that well
energy bushing full rear subframe/diff/control arms/sway bar end links
rtm240sx
Postby TryingToTurbo » Thu Jan 14, 2010 11:26 am
The eagle rods can hold 400+ and cost much less. They are the way to go.
Also, I would try to say with .020" overbore on the pistons. most machinists will recommend not to go .040" overbore when doing a boosted ka.
If you plan on turning higher RPMs then build the head, if not, then there's no need.
Just a couple tips. Looks good so far!
TryingToTurbo
Postby TanManS14 » Thu Jan 14, 2010 2:07 pm
I always wonder about the power capabilities of eagle rods. I honestly think its far more than they say it is. I've never seen them break before. The only forged rod i've ever seen distorted was a crower, i forget what car it was in. But i know the rod bent, and he was still making passes with it, pulled the motor apart for some unrelated reason and realized it was bent lol. Idk, i wouldnt be surprised if you can get 800 out of em.
Postby rtm240sx » Thu Jan 14, 2010 4:54 pm
Yeah im most likely going with the eagle rods I haven't heard much of any bad feedback on them.
rtm240sx
Postby sloka-t » Fri Jan 15, 2010 9:39 am
and, if they ever fail, they bend instead of snapping. thats a plus in my book.
Mechanical Engineering, Florida State University
sloka-t
Re: Finally lowered now on to the motor
Postby rtm240sx » Mon Oct 05, 2015 6:21 pm
So just a sneak peek at what should be done in the next couple months, just got the car back out of storage. Should be interesting to see what it puts down at 20psi.
BW s256rs .75a/r twin scroll
FullRace manifold
Tial wg
Custom intercooler setup
Hks bov
JE pistons
Manley rods
Arp main studs/head studs
New oem oil pump
Timing chain kit
Supertech valves
Supertech valve spring kit
Crower 264 cams
JWT cam gears
Cometic .060 HG
Felpro gaskets
Injector Dynamics 1000cc
Beercan custom fuel rail
Fuel labs FPR
AEM Ems2
AEM uego
AEM boost gauge
AEM Sensors
Super damper
White bunny clutch kit
Koyo radiator
Mishimoto fans
Nismo thermostat
rtm240sx
Re: New beginning
Postby supakat » Tue Oct 06, 2015 5:23 am
Nice setup. When you get done, hopefully I will be up and running. Let's go hit the track!
Re: New beginning
Postby nissanfanatic » Tue Oct 06, 2015 5:34 pm
Which Manley rods did you go with?
-Cory
2000 Honda S2000 [ GONE ]
2009 Honda Fit Sport [ OK ]
2002 BMW 325i Sedan [ OK ]
Use Linux...
nissanfanatic
Re: New beginning
Postby rtm240sx » Tue Oct 06, 2015 6:16 pm
H-beams I got a really good deal on them.
rtm240sx
Re: New beginning
Postby rtm240sx » Sat Dec 05, 2015 11:33 am
Fully assembled, need to tap the oil pan.
rtm240sx
Re: New beginning
Postby rtm240sx » Mon Dec 21, 2015 9:43 pm
Car headed to get custom downpipe fabed
rtm240sx
Re: New beginning
Postby rtm240sx » Sat Jan 09, 2016 2:59 pm
Almost done having issues with the full race manifold with the return ps line.
rtm240sx
Re: New beginning
Postby Cute240sxGuy » Thu Jan 14, 2016 11:02 am
rtm240sx wrote:Almost done having issues with the full race manifold with the return ps line.
What issues are you experiencing? Is the compressor housing hitting the PS line bolt?
Cute240sxGuy
Re: New beginning
Postby rtm240sx » Fri Jan 15, 2016 9:35 am
Power steering line is hitting the manifold. Tried a AN fitting but since I still have a/c line I can't use it.
rtm240sx
Re: New beginning
Postby rtm240sx » Sat Mar 26, 2016 9:35 am
Almost done
rtm240sx
Re: New beginning
Postby rtm240sx » Mon Mar 28, 2016 5:18 pm
Couple snags
rtm240sx
Re: New beginning
Postby rtm240sx » Sun May 08, 2016 7:59 am
Getting tuned this week.
rtm240sx
Re: New beginning
Postby rtm240sx » Fri May 20, 2016 11:06 am
rtm240sx
Re: New beginning
Postby cham » Fri May 20, 2016 1:45 pm
What was the final numbers?
cham
Re: New beginning
Postby rtm240sx » Fri May 20, 2016 3:13 pm
415tq 431hp
rtm240sx
Re: New beginning
Postby rtm240sx » Wed Dec 05, 2018 9:20 pm
Last year my 97 kouki got rear ended, I need a chassis to swap the motor into. I looked at numerous different options and tried to find another clean kouki but they were way over priced. I already had a R32 GTR so I had lots of stock parts laying around. So I decided to buy a R32 gtst and swap out the RB20 and swap in my fully built KA. This is the process it has made.
Found the R32 GTST on Japanese Classics website decided to buy it, though I will never buy a car from them again.
The car arrived January of last year. The car seemed to be just pieced together which didn’t bother me since I wanted to track the car. Plus the RB20 ran perfect.
I contacted the the guys at Full-lock llc to help me with the swap since I was super busy with work. They pulled the RB20 the first day the R32 showed up and I sold it the next day.
A s13 crossmember was sourced.
Now we are just waiting on the a wire harness from wiring specialties, then I’m taking the car to get retuned. Since the motor was already tuned on a AEM EMS V2 @19psi on 93oct but had cold start issues and the guys at full lock found it had a broken head stud and head gasket that was starting to go which was swapped for brand new arp studs and a cosworth HG.
rtm240sx
Re: New beginning
Postby nelson240sx » Thu Feb 14, 2019 11:01 am
That is a sick swap, gorgeous R32 chassis. Its one of my midlife crisis cars : )
Does the R32 bay have more room than the S chassis?
KA24DE-T build 8/17 to current (EFR6758)
Burning corn since '09
http://www.e85forum.net
nelson240sx
Return to KA-T Picture Threads
Users browsing this forum: No registered users and 52 guests
