Cheap manifolds...
- Jordan Gladman
Cheap manifolds...
Found this on a local forum, this was a guy running an ebay manifold on an SR. I've always thought the worst thing that could happen with a cheap manifold would be a crack that caused a huge leak and would require rewelding...
wrong.. bye bye GT3071RS
the little chunk that broke off went through his turbo and effectively destroyed it.
Something to concider... you might save a couple hundred on the manifold and end up losing a K.
- street_240sx
- Kamilitaryman
- street_240sx
Kamilitaryman wrote:That is why I'm going with a legit manifold...
yea but in your case the turbo will just do that on its own lol
03 evo8 gsr: stroker 2.3
- Kamilitaryman
- street_240sx
Kamilitaryman wrote:Shhh you're gonna jinx me! lolstreet_240sx wrote:Kamilitaryman wrote:That is why I'm going with a legit manifold...
i bet i just bought a turbo cheap than you. i got an airesearch one for 90 shipped hahaha
- Kamilitaryman
- street_240sx
- street_240sx
one too many crappy rewelds lolayoblack wrote:looks like that manifold was re welded at some time, it may of been the cause of the crack
- redpotatoes
WoW, that's some good damage on a T2 bottom mount manifold/turbo...something was wrong. T2 bottom mount manifold are strong enough and usually don't fail.
KA24DET GT2871R .86 Setup:
viewtopic.php?t=44222
96NismoZ wrote:+1ak_slick wrote:crack yes, but ruin a turbo with a chunk... this guy helped it with that horrid welding.
+2
..between the parts that are severly undercut and than the parts that barely penetrated, its no wonder it broke! (And I bet he welded over the original welds to "strengthen" them!) lmao!
- groundperformance
If you have a ball bearing turbo like the one pictured. You might find that option to cost just like buying a new chra. Most turbo rebuilder will not touch BB turbo and for some that does well you get the idea.zenki-des wrote:i think that was human error ive had a ssautomani bought from ssautochrome not ebay and has lasted 1.5years. plus that rear blade can replaced. none the less that sux!! hate have fix that ewww!!!
