Supakat's Thread
ReEducationThruLabor
Post by ReEducationThruLabor » Tue Oct 30, 2012 10:56 pm
Car looks sweet man, but damn can't help but get a hard-on for that 240z :idhitit:
"Don't take life too seriously. You'll never make it out alive"
s14boy
Post by s14boy » Tue Oct 30, 2012 11:26 pm
hey man whats up the cars looking great! and what rims are those?
Post by supakat » Wed Oct 31, 2012 4:01 am
Thanks guys. I am happy with the looks as well. You know I still have not buffed this car yet and it has been two years. I hope she lasts.
s14boy wrote:hey man whats up the cars looking great! and what rims are those?
These are B15 Spec-V rims. I will be selling these as soon as I find some tires for my cobra r's.
niceguy
Post by niceguy » Wed Oct 31, 2012 9:04 am
Sunlight really brings out that blue paint job, nice looking car, even better that it's fast!
Post by beercandrifter » Wed Oct 31, 2012 9:15 am
do you drive with your belt harness around town? notice you still have the stocker in there
Post by picsbypenny » Wed Oct 31, 2012 9:35 am
Most states you cant pass inspection with racing harnesses, I know this is a rule in TX which is why I kept my stockers as well as my harnesses.
Post by supakat » Wed Oct 31, 2012 10:57 am
Thanks niceguy. The harness is my main belt. The stock motor does not work. It is the least of my worries right now. In FL, we do not have inspections. :cheers:
Post by picsbypenny » Wed Oct 31, 2012 10:59 am
i hate you :/ at least im not in cali though lol
Post by supakat » Wed Oct 31, 2012 12:21 pm
Right! I wonder if I would pass emissions with the corn. I would hope so. I also stopped at the junk and got some rear z31 brake caliper bracket. The darn things cost me $23. Oh well, it was the only z31 in the yard with brakes. Hopefully I can find a deal on some 275/40 or 265/40 tires so I can put my rears on with the "big" rotor upgrade.
Post by picsbypenny » Wed Oct 31, 2012 2:07 pm
why did you go with the z31?
Post by supakat » Wed Oct 31, 2012 2:16 pm
You use the z31 bracket, s13 stock caliper, and 2004 Altima rear rotor.
Post by picsbypenny » Wed Oct 31, 2012 2:30 pm
fits on s14?
Post by supakat » Wed Oct 31, 2012 2:42 pm
Yea since s13 uses the same brakes. Just the lug is different.
Post by picsbypenny » Wed Oct 31, 2012 3:03 pm
Ohhh, I figured I should go ahead and upgrade the rear brakes since I did the BMC
I already have Z32 fronts, so I guess I got to make a trip to Nissan Heaven to get z31 bracket and hopefully Altima rotor.
500hpKA240sx
Post by 500hpKA240sx » Wed Oct 31, 2012 4:20 pm
Big Rotor, Small Pad
hahaha sounds dirty
Post by supakat » Sat Nov 03, 2012 11:42 am
Got these yesterday. 235/45. I have to save for 275/40. I am trying to sell my tranny's and other parts so I can swap these on. I may just put on the fronts and rock them with spec v rears. Not sure yet.
Super Coupe
Post by Super Coupe » Sun Nov 04, 2012 3:13 pm
Looks good.
Post by supakat » Sun Nov 04, 2012 6:22 pm
Thank you sir. I need to get center caps and real ones are a grip. I am trying to see if I can find 2.5" Nissan center caps.
Super Coupe
Post by Super Coupe » Sun Nov 04, 2012 10:44 pm
Not sure if you want just Nissan ones or what. But....
I have center caps from a set of replicas I had back in high school. I can measure them to make sure they will fit. I believe I actually used them on my 98' cobra which had the same wheels you have. You can have them for $6 gifted ( obviously free as I will be shipping them). I believe it just says the companys name on them, I would just paint over it.
LMK!
Post by beercandrifter » Mon Nov 05, 2012 6:19 am
supakat wrote:Thank you sir. I need to get center caps and real ones are a grip. I am trying to see if I can find 2.5" Nissan center caps.
well, theres always making custom ones if you cant find stock ones that dont work =)
Burnout240
Post by Burnout240 » Tue Nov 06, 2012 6:33 pm
How is the Megasquirt treating ya? Was tuning it easy and fun??
Post by supakat » Tue Nov 06, 2012 7:48 pm
It is great. I love it and am comfortable with it. Tuning is more theoretical rather than just putting in numbers in the computer. The biggest thing you need to do is understand boost timing map and visualize where you are going to be on a map when driving. It is harder for cruise/vac regions but for boost it is pretty easy. As for VE, set your timing map to something conservative and create an AFR map for cruise and boost maps. Then go out and drive. Also, to get faster results, take datalogs, run them in MegaLog Viewer and VE it. Then burn the new tune to the ecu and redo the steps. The base map is great. I tweaked mine a little bit for the timing but not much.
To sum it up, timing is the hardest to tune on this just because of the tools you use and what you understand. If you dyno tune it, your set. Setting AFR's is easy with VE Analyze. When I was tuning with TunerPro or Emanage, I needed a driver when I was tuning. Hope this helps.
Burnout240
Post by Burnout240 » Tue Nov 06, 2012 8:44 pm
Cool, thanks! I'm going to be running it on a NA car at first :)
Post by supakat » Tue Nov 06, 2012 9:28 pm
Good choice!
Post by supakat » Thu Nov 08, 2012 6:16 pm
So lately, my Profec B has been sticking. I have been hitting 20psi in first. 2nd and now third. I went and just disconnected it and am at spring pressue of 10psi. This baby is awesome for 10lbs especially with cool dense air. I am going to buy the DIY solenoid when I get a chance. I will keep the 10psi spring and run high boost setting to whatever I feel like. Of course, that will be after I buy some injectors. But for the most part, I can rock 10 psi for awhile.
Here is a long vid. Sorry for the crappy shots and commentary. It is hard to drive and record.
http://youtu.be/04Py0B8mKV8
niceguy
Post by niceguy » Thu Nov 08, 2012 6:59 pm
Good grief man! I tried watching most of it and it drove me nuts lol!!! Maybe duct tape it to your chest or something haha...it sure must be fun though, I'm still stuck in a 145whp Altima lol
Post by supakat » Thu Nov 08, 2012 7:00 pm
I am going to delete it probably. The damn phone is acting slow.
niceguy
Post by niceguy » Thu Nov 08, 2012 7:45 pm
Aw man, it's still cool when you see those clips of the tach needle hurtling toward redline so easily. I'm the same way, I'd like to record some clips with my phone or camera but I'm not spending a bunch of money on a mount just to be able to post/upload something. I'm cheap lol....Congrats on the progress and end result!
Post by supakat » Thu Nov 15, 2012 7:11 am
Thanks man. It still has room to grow as well. Aren't projects great!
I need a new camera man.
http://youtu.be/V4Zk-kmx1B8
spartanmisfit
Post by spartanmisfit » Wed Nov 21, 2012 4:13 pm
Holy ****. Great work here man. How do you feel about the intake manifold? I'm considering buying one but I have read a very scattered bunch of reviews.
Ill never go back to an sr20...
