Supakat's Thread
500hpKA240sx
Post by 500hpKA240sx » Wed Oct 24, 2012 9:32 pm
you plan on putting rear z32 calipers on also? btw are those iron or aluminum 30's or 26's lol specs specs specs
Post by supakat » Thu Oct 25, 2012 4:35 am
No rears for now. They are 30mm Iron.
Post by beercandrifter » Thu Oct 25, 2012 4:40 am
the rears were a pain to use due to the drum ebrake assembly, like the design of having basically a clip for the pads to do quick removal on them. I wish there was a nice 2/4 pot rear caliper with integrated handbrake that we could use on our car easily, would switch from the drum brake for weight savings alone.
Post by supakat » Thu Oct 25, 2012 5:51 am
Post by beercandrifter » Thu Oct 25, 2012 6:17 am
thats still using the stock brake caliper though, no?
Post by supakat » Thu Oct 25, 2012 6:31 am
Yea. The larger diameter rotor works like leverage. You can read it in this link.
http://www.wcengineering.com/articles/brakes.html
FlatBlack
Post by FlatBlack » Thu Oct 25, 2012 9:09 am
Do you know the weight difference between the TT rotors and the bigger units?
89 240SX Coupe
02 GMC Sierra Z71 5.3L 4x4
03 Kawasaki 636 ZX-6R
77 Honda Trail 70 140cc swap
Post by supakat » Thu Oct 25, 2012 9:12 am
You can get find the information online but what "bigger units" do you mean and front or back?
FlatBlack
Post by FlatBlack » Thu Oct 25, 2012 9:26 am
Are you doing both? Just wondering about the fronts.
89 240SX Coupe
Post by supakat » Thu Oct 25, 2012 12:03 pm
I will be doing the altima rears. I do not feel like frigging with the ebrake setup.
The only difference between rotors is the thickness and weight. They used the brakes throughout the years for on both models.
Part Number: 31126
Weight: 17.26 lbs
Brake Rotor/Disc Bore Diameter (mm): 68.3
Brake Rotor/Disc Initial Thickness (mm): 30.23
Brake Rotor/Disc Outside Diameter (mm): 280.399999
Brake Rotor/Disc Overall Depth (mm): 53.6
Part Number: 31125
Weight: 18.54 lbs
Brake Rotor/Disc Bore Diameter (mm): 68.069999
Brake Rotor/Disc Initial Thickness (mm): 26
Brake Rotor/Disc Overall Depth (mm): 53.7
Post by sdaigle240 » Thu Oct 25, 2012 12:15 pm
i hear that. i got over 300 into my z32 rears and thats used parts at good prices.
500hpKA240sx
Post by 500hpKA240sx » Thu Oct 25, 2012 7:33 pm
as far as i have read the z33 e brake cable are just the right length to fit with the z32 setup on your s13's but idk for a fact im just really anal about my car I really like things to match and plus the easiness of changing pads are really appealing thats the main reason why im sticking with my rear z32 calipers
Post by beercandrifter » Fri Oct 26, 2012 5:39 am
the z32 cables work on the s13, unlike the skyline cables that work on the s14 only
Post by supakat » Fri Oct 26, 2012 11:16 pm
Got my baby running again. Got the starter in today and after dinner, starter to modify the starter to work with z32 tranny. The way the car starts now is crazy like it is on steroids. I went to a friends house for some beer and took a video when coming home.
Hopefully tomorrow I can get some s14 seats to put in my car and get rid of those cheap seats. I am glad to be able to drive my baby again.
http://youtu.be/ZWtRCCby75w
Post by supakat » Sat Oct 27, 2012 9:18 am
Here is a new video of the starter in motion. This one cranks way faster. Couldn't be happier. Now just to find some good 275/40 and 235/45 tires.
http://youtu.be/6d0m3DccIR0
Silviadream87
Post by Silviadream87 » Sat Oct 27, 2012 11:02 am
How much did you drink lol. "ahh what's that **** called ahh oh rpm gauge" Haha awesome
Always make sure the juice is worth the squeeze!!
91 240sx turbo-first rwd and loving it
Post by supakat » Sat Oct 27, 2012 11:29 am
lol I only had 5 beers but it was 2am and you know how that goes. It its a beautiful day out today so I'm going for a cruise as soon as I go home. Days after storms past are great.
Post by supakat » Sat Oct 27, 2012 7:55 pm
I went and put some s14 seats in the car. I sprayed them black because I hate the design. I need to finish the passenger seat. I ran out of paint. They feel better than those cheap eBay seats I had in their.
500hpKA240sx
Post by 500hpKA240sx » Sat Oct 27, 2012 8:03 pm
looks good. im with you tho im not a big fan of the design i really like the 180sx design but jeez there expensive
emo_tactical9
Post by emo_tactical9 » Sat Oct 27, 2012 8:27 pm
supakat wrote:
Gotta love TS. When I rev or drive with it, I see the coolant jumping on my cluster which scares me. I confirmed with TS that my coolant does not fluctuate like my cluster says it is. I love my MS. It is awesome to have data at your fingertips.
Both of my cars do the same thing. It is the gauge sensor, it has a crappy metal tab for the harness. It is one wire. The metal tab comes loose from the sensor and rattles around, making it lose connection. I was just going to put some solder in to fill the gaps.
Post by supakat » Sun Oct 28, 2012 5:24 am
500hpKA240sx wrote:looks good. im with you tho im not a big fan of the design i really like the 180sx design but jeez there expensive
I want some Recaro's but expensive as well. These were free so they fit right into my budget.
emo_tactical9 wrote:Both of my cars do the same thing. It is the gauge sensor, it has a crappy metal tab for the harness. It is one wire. The metal tab comes loose from the sensor and rattles around, making it lose connection. I was just going to put some solder in to fill the gaps.
Yup. In one of my videos, someone commented on that or possibly on here. It is one of those things that you know it is fine but it still worries you. When I first noticed it, I was doing WOT pulls which scared me even though the temp should rise rather than drop.
slidewayzagain
Post by slidewayzagain » Sun Oct 28, 2012 4:23 pm
sensor fix is easy. snip the end off that sucker feed a little wire through tj=he hole and solder it then install regular male female connectors ( i like the round ones) on the new end and the old and no more loosy goosy.
Granted you can try to squeeze the stocker with pliers for a tighter fit
may your rods stay oiled and your nuts tight
Post by supakat » Sun Oct 28, 2012 4:33 pm
So I been driving the car all day. It is fun and feels good with the S14 seats. I just came back in from the garage setting up my e-Fans. I have it set to turn on at 185 and shut off at 175. I am just testing now to see how quick it will cool it down then adjust my settings.
Post by beercandrifter » Mon Oct 29, 2012 6:29 am
supakat wrote:So I been driving the car all day. It is fun and feels good with the S14 seats. I just came back in from the garage setting up my e-Fans. I have it set to turn on at 185 and shut off at 175. I am just testing now to see how quick it will cool it down then adjust my settings.
lol heck of a week to test temperature changes, supposed to hit 40's tomorrow
Post by supakat » Mon Oct 29, 2012 6:54 am
I know right. Oh well, at least my fans won't be on all the time. It is actually a good test to see how fast she will warm up and operating temps in the cold.
It was great last night. Windows open and awesome weather this morning. I wish it would stay like this until April.
Post by sdaigle240 » Mon Oct 29, 2012 6:58 am
nice weekend updates supa! glad shes back out there raping streets.
Post by supakat » Mon Oct 29, 2012 7:09 am
I am too. About raping the streets, I went to get corn for $3.26/gal Sunday. When I was leaving, there was this Audi 2.0T. He kind of gave me a look like ricer. So I was behind him getting on the turnpike and I see his exhaust get greyish/black. I was in second and just stomped it as well. I was on his tail in third and changed to 4th just to slow down. He pulled to the right and I just left in 4th. He never came back. This was at 10psi.
I want to upgrade my WG to a 1 bar spring and get my 1600cc injectors. So I will probably have it like, 14, 20, and 25psi.
500hpKA240sx
Post by 500hpKA240sx » Mon Oct 29, 2012 7:25 am
25 pounds all the way
Post by supakat » Tue Oct 30, 2012 2:48 pm
Saw this nice 240z by the shop.
I washed the car and then took the kids to the park. I snapped some photos of her while basking in the sun.
500hpKA240sx
Post by 500hpKA240sx » Tue Oct 30, 2012 9:34 pm
love it
