Smbonn's Track Star Street Car build
Ok well it all started with my S14 Zenki... Picked her up for a grand because the previous owner wasn't into cars and didn't know about the KA timing chain noise so he thought it was blown. Drove her the hour ride home and removed the upper guide and it was good enough for me.
I got tired of the exhaust (cut off muffler by previous owner) and replaced it with the Tanabe Medallion Cat-Back, Test pipe, and an ebay 4-2-1 header and at the same time dropped her on E-Motor Coilovers.
Had gotten XXR 962's on there for a while but decided i didnt like them and sold them.
Got some other things done but decided that I really didnt wanna go rear overfenders on this car and that's what it really needed to look good, plus i really wanted an S13 coupe so I'm looking for one. Pulled the motor out of the S14 as well so I could start tearing it down for the build.
And now where she sits right now... State of Ohio has it immobilized right now for my stupidity but that will be taken off soon and then I'll have a coupe in my driveway =)
Decided I would start picking up parts for the coupe early as it will definately be my next 240.
Unfortunately one of my triple projectors got broken in the mail... %&*# USPS...
And just need pistons and turbo manifold then the block will be going back together =)
The build is going to be:
Xcessive Manufacturing Intake Manifold
CP/Wiseco Pistons 9:1 .020" over - Depending what i can get a deal on
Eagle H-Beam Rods
Bored/Decked/Line Honed Block
Clevite Bearings
ARP Main, Head, And rod Studs
Stock crank for now, eventually will be a FCW brian crower stock spec crank
Professionally ported/polished Head
Supertech oversized valve (Inconel Exhaust Valves)
Supertech dual valve springs w/ Ti retainers
Supertech Shim under bucket Cam Followers
Brian Crower V3 cams
SLS Turbo Manifold
Holset HX35
ZEX direct port wet shot Nitrous Kit
Eagle H-Beam Rods
Clevite Bearings
SLS Turbo Manifold
Holset HX35
It will be stock crank for now with an ATI Super Damper, Eventually I'll be going to a Brian Crower crank as it is fully counterweighted so I wont have to worry about vibrations as much and can turn up my rev limiter. Pretty much wont happen for a year or so. And its gunna be tuned on an AEM EMS series 2
you know its not to late to part it out!!!!
Dude u gotta part that thing, I'll b pretty surprised if u find someone wanting to put the time into rot repair that chassis needs.
if you find the right person, someone will want to use the chassis... at thats gotta get done is chop out the rusted quarter an slap a fiberglass over fender then patch the rust hole on the rockers an cover them with a side skirt the that shell is ready to rock n roll "im asuming those are the only major rust spots"
brand new polished precision 6262 turbo and custom top mount manifold for sale! pm me
Do they put a thermostat in that one now? I poorly assumed rest of car was as bad.
Well been researching and ordered a rb20 fidanza flywheel which shipped today and changed my mind on what im tuning with. Now looking at Megasquirt's MS3 setup as it does everything i want it to for much less.
Sent the Xcessive manufacturing intake mani back to have them drill out the secondary injector holes and swap to a q45 throttle body.
Starting to get excited again for this build!
Pretty much done with the head except for the valve guides and cam gears.
Turbo mani came in couple days ago as well. Am going to have to oval a couple of the bolt holes but thats what I get for skimping a little this time. Eventually it will have a full race mani but i rly dont have the money for one right now.
Pictures will be up after work tomorrow =)
- rn240sx
Re: Smbonn's Track Star Street Car build
jeez... how do some of you guys get so damn lucky to find these deals...???smbonn2005 wrote: Picked her up for a grandbecause the previous owner wasn't into cars and didn't know about the KA timing chain noise so he thought it was blown. Drove her the hour ride home and removed the upper guide and it was good enough for me.
BTW.. congrats on the find
www.shopboldimpressions.com
06 Suzuki Boulevard S40
/\ all still current 8.30.20
where and how much did you pick up the rail? i use to see them on eBay for 50 bucks but no more.smbonn2005 wrote:Oh and i also picked up a project silvia fuel rail with bosch 1600cc injectors O.o
What fuel rail is that and injectors?
Nice. What are you going to tune with?smbonn2005 wrote:Its a Project Silvia Fuel Rail with Ford (Bosch) Performance 1600cc injectors
