revolutionz_s13's s13 coupe build, pic heavy (update 6-28)
Well, I finally started ordering parts for my car again. Its been sitting in storage for about the last 2 years, due to a checkbook drought , but now I have a new place with a heated garage and some decent income again. I'm going for at least 450whp on e85, would like to see 500whp, but that might be a stretch. I still need a whole grip of parts (and money) , but I think I have a pretty good start on it. On to the parts list/pics....
Powertrain
Wiseco Pistons, 9.0 comp
Eagle Rods
ACL bearings
ARP Main Studs
ARP head studs
JWT s1 camshafts
Koyo Radiator
Garrett GT3076R turbo, .82 a/r
Tanabe Concept G catback
Nismo motor mounts and trans mount
centerforce dual friction clutch
nismo 2way lsd
c's short shifter
dual 10" electric fans
Walbro fuel pump
JWT Cam Gears
Xcessive Windage Tray w/ crank scraper
ATI super damper crank pulley
Xcessive Intake Mani w/q45 flange and SS throttle cable bracket
Xcessive lowering motor mount brackets
Cometic Head Gasket
JGS turbo mani and oil lines
AEM Fuel Rail
BC springs and retainers
supertech valve seals
BC SS Valves, Std size
Suspension:
JIC flt-a2 coilovers
cusco front tie bar
Suspension Tech. F&R sway bars
spl tension rods w/ brake cooling air deflectors
spl ruca
sentra se-r brembo calipers
r32 skyline rear calipers (might sell and get ksports front and rear instead)
JIC front and rear strut bars
autopower race roll bar
tein tie rods
TechnoToyTuning subframe collars
Energy suspension poly bushings in the rest of the arms
Exterior
SSR Professor MS1 wheels 17x9,17x10 +24, 1/4" spacers on fronts
(Yes, they are 4 lug!)
front 255/40, rear 275/40
ARP wheel studs
Bomex front lip
silvia sideskirts
What I started with, about 5 years ago:
Pulling old motor, tearing it down to send the block off, sanding it down for paint:
Block back from machine shop, car back from first attempt at paint, put on suspension parts, test fit wheels:
Bunch of the parts I have sitting in my bedroom, waiting to be bolted to something...(no longer have the emanage, sold it to get aem ems)
Parts I'm planning on collecting over the winter:
Vibrant intercooler
Synapse Synchronic WG and BOV
oil cooler
One piece steel driveshaft
ID 1000cc injectors
Spec aluminum flywheel
Spec Stage 3+ clutch
Circuit sports clutch pivot
AEM Coilpacks
AEM twinfire
AEM FPR
AEM EMS
AEM Wideband
Aeroquip -6 Fuel lines
Bosch 044 inline fuel pump (fed by in-tank walbro)
Apexi boost controller
Ksport 13" front and rear brakes
I also have some work to do in the interior, and plan on stitch welding most of the car and possibly doing tubs in the front.
Shooting to get it tuned next summer, and completely finished by next fall. Still needs alot of work, but I'll be starting on the money sucking piece of metal this week, and I'll post updates as I make progress on this current monstrosity.
Powertrain
Eagle Rods
ACL bearings
ARP Main Studs
ARP head studs
JWT s1 camshafts
Koyo Radiator
nismo 2way lsd
c's short shifter
Walbro fuel pump
JWT Cam Gears
Cometic Head Gasket
AEM Fuel Rail
Suspension:
cusco front tie bar
spl ruca
tein tie rods
Exterior
ARP wheel studs
Bomex front lip
silvia sideskirts
Vibrant intercooler
oil cooler
ID 1000cc injectors
AEM Coilpacks
AEM twinfire
AEM FPR
AEM EMS
AEM Wideband
Last edited by revolutionz_s13 on Tue Jun 28, 2011 4:23 pm, edited 3 times in total.
92 240sx SE KA-T project
95 240sx SR20DET Daily
92 integra - winter beater
- street_240sx
Little update, did some work on the head over the weekend, took it all apart and smoothed out the intake runners and ports on the head a bit...didnt want to go too crazy since I dont have much experience, just wanted to smooth out the flashing from casting and take the roughness down a notch. Waiting on a some valve seals and it will all go back together hopefully towards the end of this week.
Intake mani runners before:
Intake port before:
Exhaust port before:
Intake mani runners after:
Intake port after:
exhaust port after:
cylinder side of ports after:
Intake port before:
Intake port after:
exhaust port after:
Small bit of progress here. Got some more parts, a Skullworks oil block adapter, some AEM pencil coils, an Aeromotive A1000 FPR, and a set of Supertech cam followers (lifters). I sent the head to the machine shop for a 3angle valve job, and then proceed to assemble the head. I also put the oil block adapter on and installed the Xcessive windage tray/crank scraper, and had to do only a slight amount of clearancing for the crankshaft. Im waiting for a couple more things, hopefully the longblock will be completely assembled in the next couple weeks.
Pics!
Oil block adapter:
Xcessive windage tray (pre trimming for clearance):
Just back from the machine shop, fresh ground valve seats:
Assembling the head:
Pics!
Oil block adapter:
Man, there's a whole lot of nice parts in this build. Looking forward to seeing more pics.
So finally had some time over the last couple weeks to get some more done again. Started cleaning out the engine bay and taking out stuff I dont need anymore. I cut out the battery tray too, that sucked ass. Also pulled the engine bay harness out so I can go through it and check all the wires to make sure they are good, and to add wires I need, and take out ones I dont. I also got everything to start getting the motor more assembled. I was like a 2nd christmas over the last week, a bunch of parts came I ran into a snag tonight, I need to get longer spacers made for the fuel rail, the ID1000 injectors + xcessive mani ends up with a much larger gap than what the spacers came with for the oem fuel rail. Pics!
Parts!
Cleanin a mess
Battery tray removed
A days carnage
Puttin the motor together little by little
Its gettin there slowly but surely, needs lots more time and money tho Feels good to be making progress again after a couple years of it sitting though. Comments, suggestions, and flames welcome
Parts!
Cleanin a mess
A days carnage
they come as the 14mm/48mm, you will need to use the adapter they come with which will make them 11mm/60mm...however, the standoffs that the fuel rail comes with arent tall enough, so I had to go to a hardware store, find some aluminum tube, and make some custom length standoffs, IIRC mine were 2.5"...
- Caveit77777
Is there a noticeable difference after cleaning the intake manifold and exhaust ports performance wise? Just wondering
1996 Zenki: Arias 8.8:1 Forged Pistons, AMS Sportsman Series Rods, Tial 38mm, 370cc, Fel-pro Gaskets, New Stock Crank, Nismo Thermo, Nismo Mounts, Dual Canister Exhaust, Walbro 255, T3/T4 Turbo, Mishimoto Rad, Isis Fans, HKS SSQV, SPL Tension Rods, GAB Revo Sport II Coilovers, Enthalpy Tuned... more to come
yeah, hit a prob tho and have to dissassemble the entire head. the valves sit too far into the head after the 3angle, and I cant get the valve lash within spec. I now have to take the valves out and have them machined down shorter in order to get all the clearances right...franman wrote:Nice choice going with the new AEM box! i'm sure your more than ready to get that thing going!
How do you like the JIC coilovers are they treating you right?? I am interested in a set but i want real world reviews..
- franman
Ah i've been there as well my friend! Def a pain in the ass to adjust the cam on bucket/puck set up.yeah, hit a prob tho and have to dissassemble the entire head. the valves sit too far into the head after the 3angle, and I cant get the valve lash within spec. I now have to take the valves out and have them machined down shorter in order to get all the clearances right...
I've been running JIC's for a good 4 years now and have been very happy with them, i'd recommend going with the flta2's (now i believe they are renamed fltaR's) great value coil for the price to say the least.How do you like the JIC coilovers are they treating you right?? I am interested in a set but i want real world reviews..
- Caveit77777
Lol i know that but is there SUPPOSED to be a noticeable difference in performance? haharevolutionz_s13 wrote:as far as feel yes. as far as performance, I have no idea, the motor is not in the car yet.
I dont know that there would be a huge difference in performance, but some gains from what I have read is it allows for a bit smoother airflow, and helps prevent some carbon buildup on the ports...Caveit77777 wrote:Lol i know that but is there SUPPOSED to be a noticeable difference in performance? haharevolutionz_s13 wrote:as far as feel yes. as far as performance, I have no idea, the motor is not in the car yet.
Was makin some progress in the end of May, then got called for flood duty, which is keeping me from more progress as I will be away from home until at least the middle of July...
Cut out where **** battery tray was:
Welded in new steel:
Got to work on primering the bay:
