500hpka240sx's build
- 500hpKA240sx
finally made a vid of the exhaust....this is what a bored and camed straight exhaust with header sounds like lol the BC 264s made it sound way deeper.
http://www.youtube.com/watch?v=WoUV7ysc ... BYBiCYXhk=
- Walperstyle
- 500hpKA240sx
just youtubed it and yea your right good hear sounds damn close it make it better my whole setup from header back only cost about 300 bucks
When he goes boost, it will quiet it down plenty. She breathes good and the turbo spool will show that.Walperstyle wrote:Too 'pingy' for my taste. I like the Blitz Nur Spec sound.
- 500hpKA240sx
i dont want a turbo lol
D#mn, I guess I never paid attention.
- 500hpKA240sx
lol its all good
- 500hpKA240sx
yea the 264s lope quiet a bit but dont have to fight it to keep it going and the power band is crazy compared to oem setup...i have a vid i need to upload of me getting on the highway but i have **** ie. so it takes forever soon enough tho
- 500hpKA240sx
my dad is the same way thats awesome makes me feel good thanks.Southern620 wrote:I really like the sound of your set up. My dad is like die hard old school muscle and he heard it and he said "that 4 cylinder sounds mean". Good work man.
and supakat said the same thing if i go turbo it will quiet it down a lot good thing im going supercharger lolturbonola wrote:i guess n/a they lope hard like that. mine don't lope that hard.
- 500hpKA240sx
- 500hpKA240sx
just got a new head and its off the the machine shop to have it resurfaced and also just bought some supertech valve stem seals that are going in it. also having my new valves matched to it....pics soon to come!
- 500hpKA240sx
pretty clean i thought
and just my baby
and just my baby
- 500hpKA240sx
did a pull coming home tonight used my phone so it was a bit noisy..
and I painted my extra oil pan ill put it on when ever i swap my head and timing cover
Your build is coming along great. Did the machine shop start work on the KA head yet?
- 500hpKA240sx
yea its at the machine shop i should have it back next week sometime and ill have it on before midnight madness hopfully
- 500hpKA240sx
something to past the time
- superDorifto
- 500hpKA240sx
Thanks guys its so much easier to have extra parts to work on being my 240 is my daily..i can actually take my time.
- 500hpKA240sx
- 500hpKA240sx
head came in yesterday and last night i pulled everything. it was extremely clean and the rings are seated so no need to change them the new head and everything is going back on and will be done tonight.
- 500hpKA240sx
well guys i got everything running and she ran so damn good and then....failure doing the 3 angle job and grinding the seat and valve down let them rise a bit higher and the cam im guessing didnt let the valve shut and seal all the way and i burnt a valve up so. i dropped the head back off to the machine shop and im having it fixed. but im posting up some pics for you guys to check out.
- 500hpKA240sx
broke a cam UUUUUGH!!!
fresh painted and cleaned oil pan
custom cam cap bolt swap to nut on stud setup
here is the stud spec. and i assure you it wasnt just something i threw in my motor i sat for awhile with a good friend of mine taking measurements just to get this special order in. the swap was about 60 bucks total with studs and nuts.
- superDorifto
- 500hpKA240sx
Ppl swap mains with studs and that's also is a journal... Am I positive absolutely not but I did put a couple hundred miles on the motor and within the mileage I put a run down the track and she ran fine.and I don't think it would hurt bc its the same size back in so it shouldn't change a thing accept a little bit stronger torque and safer application imo
- 500hpKA240sx
have to pass the time till my new cams come in compliments of turboholic I have decided to do something to pass the time so here is a pic of the antenna hole i patched
and i changed out my turn signals to clear ones
