official build thread
Good read, TanMan. Thanks for the link.
- TanManS14
Anytime. Honda tech has some useful stuff occasionally lol.
Have you ever had problems with paint peeling off of the bay from the evacuated crankcase air out of the catch can? Maybe this is some queer BS heersay, which for some reason is plentiful on the subject of e85, but i've seen reports of it strippin paint even just from being next to the vent filter. That's originally why i looked into pcv into exhaust. Aint tryna paint a bay and have it peel.
I have noticed a little bit of oil mist on everything around the catch can from time to time, but haven't had any paint come off. I've only put a couple thousand miles on the car since putting the built motor in though. I'll definitely keep an eye on it. I guess if it becomes an issue, you could always run a rubber hose down to the bottom of the bay somewhere and just put a filter on the end of it.
Sorry for straying off topic, ked.
Oooh, are these pistons I have of yours those pistons? lolkedbmx wrote:Yes the motor made 805whp and 657 ft/lbs on the 10mm studs and standard cp pins.
I'm trying to understand the dynamics of how a downpipe could pull vacuum. I could understand if it's through a venturi or some sort of special bung though.
Yay I feel special
And okay cool that makes sense. So to everyone, this may not work for you if you just drill a hole in your downpipe and weld on a bung FYI.
So what was needed for the block to accept 12mm head studs? You just drilled tapped and in they went? What about the oil passages? I badly want to finish my build and this is all that's standing between me and finishing.
1996 240SX SE - Sold
1998 240SX SE - Sold
2008 350Z - Sold
2013 FR-S - DD (Blown transmission)
1998 240SX - Full-Race GT3576R street/track build
2008 350Z - Sold
- Walperstyle
Any updates?
- 1991240sxhatch
Re: official build thread
so whats goin on with this beast i kinda wanna know how it turned out
ok i know its been like 100 yrs or whatever but has anyone heard anything about this car?
Ohh sounds fancy
good i thought u may have given up for that 5.0 build u talked about and will be looking forward to seeing more
- Forum Moderator
You are still alive!!!
so i guess your not going to tx2k :'(
- S14wayz
just went through the whole thread..tons of inspiration, gonna get off my ass right now and go finish porting my head! You said you used a carbide bur to cut down those valve guides? Im curious how far you can take em down? i just want to get mine some what flush with the drill press then clean it up with some rolls
hey kedbmx you mind sharing what you have been tuning with ? (pls say megasquirt) and have you done it all yourself ?
edit: just remembered another question I had while reading through the whole thread earlier, is your turbo ball bearing ?
1991 sil-eighty se sold
1995 bmw 540i written off
1995 pathfinder se, sold
1995 Altima gxe, sold
