official build thread
- 500hpKA240sx
Are those sch40 weld els? Stainless? Did you use almost all of them? Probably going to do the same thing so i can dump my JGS log.. just want to be sure what I need to buy.. What size is the straight pipe.. 1.5 or 2"?
- Forum Moderator
looks good man ... keep it up
I bet you same as all of us. 9:1. I have a feeling though racelab is building a 10.5:1 block right now.
wow i was thinking about going 2jz on the new s14 but after seeing this you make me want to stay ka, your powerband is just like a 2jz , picking up 400whp in about 1500rpm f*in insane!!
glad you stuck with it congratz on 800whp? so crank it up to 45psi and tease 1000whp??
good luck man
good luck man
R.i.p. 97 s14
96 s14 ka-t
Or you just control the boost with your foot!
- tom550
yeah but what happens when you flip off a guy. he busts out a gun and opens fire. you freak out and floor the gas. your getting away then next thing you know 30lbs hits and your flying to find that your going to a right turn so you try to hit the breaks but they just lock up and you go sliding into a brick wall total your car. then you get shot in the leg and fall down. then cop sees what just happened and comes over to see what happens. so the guy throws the gun at you and runs away. so the cop comes and thinks you were doing a drive by but wasn't looking at the road and thinks you wrecked and shot your leg. so he pulls you into his car and takes you to jail.
tom550 wrote:yeah but what happens when you flip off a guy. he busts out a gun and opens fire. you freak out and floor the gas. your getting away then next thing you know 30lbs hits and your flying to find that your going to a right turn so you try to hit the breaks but they just lock up and you go sliding into a brick wall total your car. then you get shot in the leg and fall down. then cop sees what just happened and comes over to see what happens. so the guy throws the gun at you and runs away. so the cop comes and thinks you were doing a drive by but wasn't looking at the road and thinks you wrecked and shot your leg. so he pulls you into his car and takes you to jail.
dude you think way to much.
It won't happen because I will be playing this song when I drive!
http://www.schooltube.com/video/0bb8adf ... CIAL-VIDEO
