Becharco's 300hp s13 build
- Becharco
What you are about to witness is a n00b attempting to turbo an s13... there's probably going to be some dumb posts so i would appreciate constructive criticism.(trolls stay quiet) there's going to be LOTS of questions, so hold on to your hats lol
Hello, So, yeah. My name is Cody and i live in southern Ontario, about 40 mins from the Windsor/Detroit border.
This is my car, before i had bought it. drove about 2 hours to get it. There it was. the kid had obviously kicked the **** out of it then parked it. so i loaded it up on a uhaul and took it home.
I talked the kid down to $250. i figured, if i buy it and get it home and its junk, ill take it to the scrap yard.
sitting in the driveway. I had no job and had to borrow money from a friend to buy it.
First thing i started on was the power steering
Then the frame.. and the floor. and took it for safety. i had to put all new breaks on it.. Calipers, rotors, pads (CPR) while doing the fronts i broke some bolts that hold the caliper onto the spindle, so i had to save them, then i put new lower control arms and ball joints on, tie rod ends and links. and got to driving it.
bought some rims, mainly for the tires, to pass safety.
fixed the hatch
after driving it for 3 months i starting having fuel pressure issues. being frustrated i bought a new car.
and the car sat. and sat. for probably 6 months until i got laid off... i went to a drag/drift event that CSCS was putting on in grand bend ontario, and it changed everything for me. seeing all those nice s13s, talking to all the owners. they never gave up on their cars.. so neither should i. i got home and cleaned out some space in the garage and parked it in there and started tearing it down.
And this brings us to today. progress is slow as its been 110 in my garage and im too afraid of sweat (lol) im going to fix the chassis first, wile i stock pile parts. im taking out the air conditioning and need to refab a rad support.
and so.. this brings us to my first question lol i aiming for 300hp. ive read up alot on what turbos will work and it still isnt clicking in my brain. will this turbo be sufficient for my motor? http://ottawa.kijiji.ca/c-cars-vehicles ... Z395665698 and thats a REAL master power turbo. (dude says its made in Brazil). no ebay junk here. i made him an offer, minus the injectors since there too small.
fixed the hatch
- Walperstyle
.48 is a little small, but power comes more from proper tune then it does 'bolt on parts'.
This is how I figured out turbo information:
http://www.youtube.com/watch?v=AasEZE3IK_w&feature=plcp
- Becharco
Well for $400 (plus shipping) he said i could have it (minus the injectors)
EDIT: i found 2 programs (ray hall turbocharging and Garrett boost adviser) the Ray Hall is recommending the Garrett GT25 and Garrett is recommending a whole whack of different turbos: GT2589R, GT2252, GT2860R, GT2871R, GT2860RS,GT2871R,GT3071R. so, it looks like ive got some reading to do. chime in on what experiences you've had with any of those turbos, and recommendations. i wasn't 100% sure on the info i put in, i put 12 pounds boost, max rpm at 6500? and mid at 3250? but i noticed that the KA24DE makes max hp around 5500. but ill leave a link for these boost adviser things here, for future reference.
Garrett: http://www.turbobygarrett.com/turbobygarrett/webadviser
Ray Hall: http://www.turbofast.com.au/TFmatch.html < from 2003 so maybe thats why the recommendations are different
- Becharco
I think ive decided to go with the GT2860R (Part# 707160-5) Which is a direct replacement for the RB26DETT.
Compressor Specs
-0.60 A/R compressor housing 2.08" 2-bolt inlet 1.5" 2-bolt outlet
-62-trim compressor wheel 1.85/2.36 47.2mm inducer
Turbine Specs
-0.64 A/R turbine housing with T25 inlet and compact 5-bolt outlet. This housing is NOT interchangeable with traditional T25 5-bolt outlets
-53.9mm 76-trim GT28 Inconel turbine wheel
Compressor Specs
Turbine Specs
- Becharco
anyone ever tried these "precision" turbos? i've never heard of them but from what im reading they're a pretty good entry level turbo....
http://www.treadstoneperformance.com/pr ... rger+375HP
Agreed.schmauster920 wrote:You should look at other peoples builds on the site, they are very common
Here is one of the higher hp applications.
viewtopic.php?t=56925&highlight=
Do some searching around on the site. You should find what you are looking for. If not post a thread in a TECH section. You will get more responses.
I think that turbo might be a little bit on the small side but it should get you near 300hp (but I'm not sure about much more). But it should be a good match if you want a fast spool setup.
And yeah, Precision is a high-end turbo manufacturer amongst only a few others. They have been getting quite popular even here on KA-T.org.
You should at least go for a T3.. a 50 or 60 trim t3 would allow you to run lower boost and hit your goals, but it would be a little laggy. It should last though. You will probably want more power later, you can crank the boost up or get a bigger turbo.
If you want no lag, and 300hp, the disco potato is a good option, but still no room to upgrade on a T2.
Reading compressor maps is a pain, but would be very very helpful if you want to learn. Check it out on youtube or google.
An important question that hasnt been asked is what are your goals with the car? You said 300hp. But you will probably want more later. If you get a smaller turbo, you will be maxing it out to get your 300hp, and i recently found out turbos dont last long if you run them too hard.
Every turbo likes being ran in a certian PSI range, go below that you could get surge and other drivability issues (havent experienced) If you run them too high, they will put out excess heat, and not give much or any HP gain. My turbo was old and tired, and didnt like 16psi for a few weeks after being driven on 8-10 for years.
- emo_tactical9
No room to upgrade from a Disco Potato?
If you really only want to do around 300whp (believe it or not, some of us do) then get a T2 series turbo. There are guys on here running better ETs in the quarter with a T2 than some guys with larger turbos. Driving is obviously to blame, but a T2 car is a hell of a lot of fun.
Either way, it is your choice. I am quite happy with my T28. There are many options for upgrading. Hell, you can even get a GT3071 with a T2 flange.
Dont know my turbos that well, I thought it was one of the largest / bb turbos for a t2 mani.
With a T3 you'd have cheaper options, stock turbos, used turbos, etc. The T2 option in the size range you want wouldnt be bad if you want to keep 300hp and get a store bought turbo. Its all about what you want / what you want to pay for.
I wasnt aware many people have the self control to stay at 300hp.
Just trying to help, i dont claim to be 'encyclopedia nissan' lol I do like to suggest some growing room since a lot of people dont think much about it.
- Becharco
Thanks for all the help guys, I found a kit on ebay from CXracing..(http://www.ebay.com/itm/180691433978?it ... 23&vxp=mtr)
except that turbo looks sketchy as f*ck. so I emailed them and asked if they would sell me a kit without the turbo. sure they will... for the same price. so i think im gunna get there kit, sell the junk turbo they include and buy that precision turbo.. just trying to find some dimensions on the flanges to make sure they will bolt up the same again, i appreciate the help, way better than any other forum im a member on
- street_240sx
- 500hpKA240sx
why tear down that truly unmolested motor. its super clean and stock setup wll hold 300hp all day..
- Becharco
Becauuuuuse it was leaking oil all over the place. and passing it through my exhaust... Im just cleaning it up outside, painting it, and putting in new gaskets. that's all. no need to worry EDIT: I'd also like to teach myself a few things500hpKA240sx wrote:why tear down that truly unmolested motor. its super clean and stock setup wll hold 300hp all day..
- 500hpKA240sx
All I read was fuel pressure problems not oil.....i was just curious
If it was smoking out the exhaust you most likely need new valve guides and valve seals, its not too expensive
This will generally make it smoke a little on startup, and if it gets worse, might smoke at idle and low rpm
- Becharco
Motor is finally home! Hot tanked, new frost plugs, honed, head got machined, cleaned, new seals, pistons got cleaned, new rings. The oil rings on the pistons were seized, answered my question of why it was smoking. Just waiting on a ring compressor and bearings and it will be going back together.
Also fabricated and welded in a new lower rad support.
Is that picture partially sandblasted? Looks really nice!
I went black with my block, it really doesnt stand out
You should put new valve seals / guides in your head if you havent already. Bad valve guides can lead to valve seals not sealing.
The exhaust valve guides are usually worn out it seems.. if original, the valve seals might be leaking a little too... doesnt mean the oil was only coming from once place.
- Becharco
I had the guy that cleaned my head put valve guide seals in it. I went with orange because id like to be able to keep an eye on how clean the block is, it will make oil stand out more. the block was hot tanked but he said it was still pretty rough when he took it out so he did sand blast it a bit. Its all about rebuild now. Ive hit a bit of a rough patch money wise so the project will be slow for awhile (not like it can get any slower now)
Ive got this addiction to stickers....
