shift's build-that's wassup
Re: shift's build-that's wassup
So, as far as I've read...you were overheating for about a mile. Noticed a puddle of coolant under your car, found a line leaking and replaced it. Ran it for 30 minutes with the bleed screw off and to get all of the air out and now it only overheats while driving.
When, bleeding for air bubbles, do exactly what you've been doing but rather than the over flow cap just leave the rad cap off and bleed screw open while adding fluid until its free of air bubbles. Honestly, I also do not run a thermostat but that's because I'm in FL.
If your car still overheats, I would make 100% sure there are no more leaks because I'm sure you know coolant just doesn't vanish and unfortunately if it does, that usually leads to a headgasket . I've ran into this issue and then finally noticed I had the smallest leak coming from the hole on the bottom of my water pump and replaced that and bled all the air and fixed all my issues.
If there are no more leaks, do a compression test because another instance I found a slight leak thru my headgasket which hopefully you don't have because I think I saw someone say you just recently replaced it. If you did, and didn't get your head/block decked along with the timing covers that could be your issue, worse case scenario.
Hopefully, this helps because you've definitely helped me with my timing issues and I'd like to return the favor.
I love my fiance and 2 girls goldie and jade =P
Thanks man, I appreciate you.
I tried so hard to bleed the system, but thermostat just didn't want to open. I decided to pull it out. The car doesn't over heat anymore. Problem solved until next winter
- 500hpKA240sx
- 500hpKA240sx
holy ****...how is that thing holding air?
LOL! IDK!
I'm not going to drive it until I get another tire though, I think I got my money's worth on this tire
Wow! thats amazing! I'd say its getting to the point of at least looking for tire options, but geez, hah, I would at least switch that wheel/ tire to one of the rears so if it does blow at least you'd still be able to steer.shift_down wrote:In other news!
Do I need new tires?
It blew!
I'm going to go get a used tire in a couple hours.
I need to put my front end together soon so I can buy some wheels and REAL tires.
Well I've decided to start getting the body put together. I dropped the car off to get the front end welded and put together. After that's done, I can finally get some big wheels and start having some real fun.
Yup...don't you hate when the car is down. It is a really big paper weight.
- S14wayz
shift_down wrote:LOL! IDK!
Haha that reminds me of my old tires on my s13 drove em till there was this massive paper thin buldge on the side then had to drive 30 mins in traffic on it to get new ones :p
I know, it takes the fun out of it. With all the trouble you've been going through, I'm surprised youre still keeping it going. I sometimes think its time to buy something nice and let this car go, but then I think of how much work I've put into it and I change my mind.supakat wrote:Yup don't you hate when the car is down. It is a really big paper weight.
I think eventually ill get it to where Iwant it, iit'll just take time.
So, what kind of wheel options were you looking into after the front end is all finished up at the welder?
my front fenders are +30mm wider, so Im looking for something around 10 or 11 inches wide with a 0 offset or even maybe negative. Im not good at wheel at all, so I have no idea really. I am also thinking about going with 30mm wider rear overs to get a wider rear wheel also. I was looking at charge speed since they are the only over fenders that cover the entire rear. They are expensive though, but I will pay if they are what I like.
I am still keeping my options open though, if you have any suggestions.
oh nice! I just figured I'd ask you because I've been researching wheel options and doing offset calculations myself recently, and I thought hey, maybe we could compare notes : ]
Failure is not an option. Once you give up, you fail! I will keep trucking and persevere over any obstacle.shift_down wrote:I know, it takes the fun out of it. With all the trouble you've been going through, I'm surprised youre still keeping it going. I sometimes think its time to buy something nice and let this car go, but then I think of how much work I've put into it and I change my mind.supakat wrote:Yup don't you hate when the car is down. It is a really big paper weight.
Damn Son!!!!! Jealous of the S15 front end..... How's the cooling issue coming now that the weather broke out there?
Haha thanks!
I've had the front end for a long time and finally got to put it on, I'm pretty excited about it!
The cooling issues have disappeared thankfully!
...Annnnnnnd my radiator blew up.shift_down wrote: The cooling issues have disappeared thankfully!
I arrived at school(15 miles from home) and I looked under the car and there was coolant everywhere. I looked all over the coolant system and found a hissing and steam coming out of the radiator. What could cause this you ask?
The radiator gods are unhappy with me.
AAHhhhhh... so coolant issues literally disappearedshift_down wrote:...Annnnnnnd my radiator blew up.shift_down wrote: The cooling issues have disappeared thankfully!
Hahahhaha yes!
I'm thinking head gasket with all your symptoms.
I've had that in the back of my mind also, I just don't want it to be true. I just replacedmy hg, so if it is blown again, i really domt know why that could be. Compression test will be done tomorrow if i can find my compression tester.Kisor wrote:I'm thinking head gasket with all your symptoms.
Well, hopefully its not the HG.
If it is though, HG could be a number of things, but I'd lean towards one or more of the cylinders running hot due to the coolant challenges mentioned earlier.
Some other things I would also look at would be:
- Octane rating (if this is too low, fuel mixture could predetonate as a result of heat and compression before the sparkplug fires)
- timing (for similar reasons)
- sparkplug(s) (rating possibly too "hot", possibly causing predetonation from their heat, before their spark; or their gap size)
- A/F ratios too lean (across all cylinders, making one or more cylinders too hot)
- semi-clogged fuel injector(s) (causing one or more cylinders to run too hot)
I'll have to check on all that once I get the chance.
I cold compression checked my cylinders just now:
C1: 175
C2: 170
C3: 180
C4: 175
C1: 175
C2: 170
C3: 180
C4: 175
Looks like something damaged that area of the radiator. I will have to pad it up to make sure it doesn't happen again. In the meantime, jb weld!!!
Man that's a bummer, just my 2 cents, but JB might make a proper fix more difficult. But I understand wanting to the car back on the road ASAP. I would probably try to correct those fins as much as possible too.
Did it happen workin on the car? I know it's a pain to drain it but it doesn't take long to pull the radiator. I guess the job that you're doing will determine if it's worth it.
This happened while I was driving, I found a puddle of coolant on the floor and now I know why.
Ya, I just pulled the radiator out. I probably shouldve just had it welded, but I needed a car to get to school tomorrow and this is all I have :/ Im going to try to find a stock radiator from somewhere and have this aluminum one fixed while the stock one is in the car. It's such a pain, but it is what it is.
IVe got a stock one I could ship you really cheap $20 +shipping. its already boxed up.
