Datsun 510 ka-t build
Hey guys ive had the car for a while with a n/a ka with flat tops but then i broke a ring land and started spending money. The engine w/ turbo is going to be WAY to fast for the car for a long while. The biggest tires i can fit currently is a 195. Planning on 600-650 on race gas. 450 on 91 and meth injection
Engine:
ARIAS 8.8s .020 over
Eagle rods
BC v2 cams
Ferrea inconel exhaust valves
Supertech Intake valves
BC valve guides
Port and Polish soon to be done by Rick Kemph
Clevite mains and rods
Arp main studs and head studs
beercan v1 fuel rail
Still need a head gasket STOCK? or CLEVITE?
Pistons are above deck about 7 thousands
Turbo setup is still undecided
planning on gt35r or gtx30 if affordable, and possible hx35
Tial mvr 44 if its big enough
Custom manifold i want to do my self, Indy car style
AEM series 2 for sure
Still to buy:
Comp clutch twin plate?
Rc P&H 1000 or 1200
fuel safe 26 gallon
Cv conversion
new drive shaft
cage
bigger radiator possibly in trunk after fuel cell and widened/ extended bolt on quarterpanel/ flare
oil pressure gauge
tach
dash need to be made cf/aluminum
Current garage setup lol minus car
parts!!
deck and tdc getting checked
fresh paint in back seat and trunk
trunk and pump instal
sexy looking A1000
fresh coil overs for rear
When it was running
old engine running
Left: stock middle: first 2 right: second six
dumb a**es at supertech send me 2 valves then second six were on back order and i finaly get them and they dont match first 2!! Under cut is at different hieghts backcut angle is different along with seat width.
More to come should be running NA soon!!
Engine:
Eagle rods
BC v2 cams
BC valve guides
Still to buy:
Rc P&H 1000 or 1200
fuel safe 26 gallon
Cv conversion
new drive shaft
cage
oil pressure gauge
tach
parts!!
sexy looking A1000
When it was running
old engine running
oh man, stoked to see this thing going. absolutely love the datsun 510.
what are you going to do about the traction issue? I mean there are always 195 slicks. cant say i have seen any well done wide bodies on a 510 before
yeah im not completely sure but im thinking im gonna get some structural support added in the rear and im gonna cut the inside of the wheel well all the way around and then put a hydro jack in there and push it out an inch or two the only problem is that its a four door and then i can fit 205 55's for track days.
this is what im thinking because the standard 510 widebodies look horrible and this would add a more moderized racy look to the car.
- 500hpKA240sx
wow thats one clean datsun and a damn nice built motor
could always run shortie axles and just move tires inward if you are going to start doing fabrication. that is, if you only want it for a drag car
Can you get e85 in the area? Ive filled up at conserv near the 10..I know theres a few more.
It would be the way to go if you put some big injectors on there.. I didnt see the injector size listed. This is going to be sweet with 600hp
Might want to go with 11-12mm arp head studs and a cosworth/cometic style MLS gasket for your 600-650 goals
I really wish I could do e85. I live near the 605 and 405 and there's only One e85 station near port which is 12 miles away min plus traffic which really sucks. I mentioned getting rc 1000s or 1200s to support 6-650. I will be doing a snow performance meth injection kit most likely and I thought about the head studs but I'll only be using above 450 hp 10-14 weekends out of the year if that. I really want to use I cometic since they offer slightly thicker head gaskets than stock and my pistons are peaking out of the bore a tiny bit, but Im really concerned because I always hear about people blowing them but at the same time I dont know how many are successfull. If I do use an Mls I am definitely going to sand the resurfaced deck just to be sure, I heard 200 grit is good for about 20-40 ra.
Not to sure about how far the pistons can peak out. I do know the FSM states 1mm off block and 1mm off head max when decking.
Cosworth recently came out with a head gasket for the KA. They offer different thickness and bore sizes IIRC. Might be something to look into.
What timing kit is that? I would only use OEM. You know its going to be perfect the first time. Ebay kits are complete crap, the castings on a lot of the parts are junk. A few people here have had issues, and on a few other forums they resulted in spun bearings. They casted the tensioner hole in wrong spot....essentially blocking oil from coming out.
Have you looked into a new timing cover? Not sure if you already picked one up. But it would be a good idea. Old ones tend to cause problems when supplying oil.
Another note. People have had issues with s13 pickup tubes. I would upgrade to a s14 oil pick up tube if you can, and dont forget to replace the gasket.
Build looks very good! Keep it up.
its an osk made in japan very high quality or so ive heard. The timing cover is in good shape a new one is $450 not willing to drop that unless the cover was beat.Super Coupe wrote:Not to sure about how far the pistons can peak out. I do know the FSM states 1mm off block and 1mm off head max when decking.
and do you mean the pick up with the smaller pick up at the bottom? and thanks
A few people have sourced the front covers from $180-260. Yes OSK is good stuff.ViperGT wrote:its an osk made in japan very high quality or so ive heard. The timing cover is in good shape a new one is $450 not willing to drop that unless the cover was beat.Super Coupe wrote:Not to sure about how far the pistons can peak out. I do know the FSM states 1mm off block and 1mm off head max when decking.
The pick up in the oil pan that attachs to the timing cover. A few people have had the s13 tubes break trashing their motors.
Port and polish is done, along with valve guides. All that is left to do is file rings, do piston valve and piston head clearances, assemble the head. Then shell be ready for final cleaning and assembly.
I do have a slight feeling that the numb nuts may have installed the valve guides backwards. ie intake for exhaust, as the exhaust valves feel tighter in the exhaust guides than they do in the intake. The exhaust is supposed to have more clearance right?
Put a little oil on the valve stems so they move easily in the guide.
west covina nissan (thenismoshop) in cali sells covers for 195 shipped if your still interested. the covers are interchangable i think you just need the upper cover to match.ViperGT wrote:Well they have s14 covers for 250 but s13 is like 350-450
pretty sure you can swap the covers, have used the s14 covers on 3 different s13 blocks myself. just have to match the top and bottom. which dowel pin are you talking about?ViperGT wrote:yeah ill try that, if they are backwards do you think the valve will bind? alse the covers are not the same there is a dowel pin on the block that is different, The heads you can swap w/ correct uppertiming cover.
oh, i forgot to mention i fuzking love this project.
Finally filed rings, top gap at 21 thousandths, second ring was 22 thousands out of the box. Hopefully ill get on the valve grinder tomorrow and get my head finished!
Sounds good. Ringing the block is a meticulous process.
got the shims for the head and stems ground, put timing chain on and everything and checked piston valve clearance and piston head clearance with clay, bolted head on with 8 26thousandths feeler gauges for a simulated head gasket, 90+ thousands of valve clearance and 15-18 thousands of piston head clearance, i ordered a 51thousands head gasket from cometic which should give me 40-43 thousands of piston head clearance. right?
in a datsun 510:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
arp head, main, rod bolts
osk timing
custom downpipe
lol:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
osk timing
custom downpipe
lol:
Final assembly is pretty much done, got a new front cover, and oil pan and pickup still need to Go on and valve cover needs bolts + silicon, and spark plugs, along with intake exhaust and alternator one in car. Pictures!
in a datsun 510:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
osk timing
custom downpipe
lol:
arias 8.8 .020
eagle rods
clevite bearings
port and polish
osk timing
custom downpipe
lol:
