Abjerk's KA-T Build
Abjerk's KA-T Build
I've been lurking for quite some time now. I finally decided I should dive in and show what I'm working with. The body is a 1990 so technically this is a DE swap. It started out as somebody else's project. The car was completely gutted. I literally started with nothing. My goal is to turbo the car over winter and shoot for 400HP on E85. The current build list:
Block/Head/Transmission
1993 KA24DE
Wiseco 9:1 .020 Pistons
Eagle H-Rods
Clevite Bearings
ARP Main/Head Studs
Cometic Metal Head Gasket
PNP'd Intake/Exhaust Head
3 Angle Valve Job
EGR Block Off Plate
Spec Stage 3 Clutch
Fidanza Flywheel
Nismo Motor and Tranny Mounts
Cooling
Koyo Aluminum Radiator
ISIS Radiator Fan Shroud Kit
Mishimoto 68°C Thermostat
Exterior
Stock Chuki Aero
OEM 180SX Type X Wing
OEM 180SX Type X Kouki Lights
Fuel System
Z32 Fuel Filter
DeatschWerks DW300 320LPH Fuel Pump
Intake/Exhaust
Motoria S14 3" Exhaust (modified for S13 routing)
Nissan Q45/Z32 90mm Throttle Body
Coming home:
Ricey body kit :/
Holes? Come on...
De-riceifying it
6pt roll cage om nom
This is what I had to work with.. not much
A sign that it might live
Before:
I made the mistake of dumping those buckets... ugh
Before:
After:
After:
After:
After:
After:
After:
P&P + 3 Angle Valve Job goodness:
Shiny!
Cometic gasket + ARP studs
Coming together:
Stock cams for now:
Adding the outer components:
Finishing the timing:
Side view:
Mockup with valve cover:
Latest progress as of 9/23/12
1993 KA24DE
Eagle H-Rods
Clevite Bearings
ARP Main/Head Studs
3 Angle Valve Job
EGR Block Off Plate
Spec Stage 3 Clutch
Fidanza Flywheel
Cooling
Exterior
Stock Chuki Aero
Fuel System
Z32 Fuel Filter
Intake/Exhaust
Coming home:
Ricey body kit :/
Holes? Come on...
De-riceifying it
Before:
Before:
After:
After:
After:
After:
After:
After:
Shiny!
Coming together:
Stock cams for now:
Side view:
you could EASILY make 400whp on an hy35 e85 that costs under 300$. people make damn near 400 on 20psi 93 octane. figured id make mention, i also see 18psi before 3500 rpms, and the thing eats up ferrraris, GTRs and AMGs on the highway
I'm not too familiar with Holsets. I know OF them but nothing about running them. I always kind of assumed they were truck turbos from Cummins. I know the HX35 is pretty popular around these parts though. 93 or E85 is the plan. I'd love to stick to E85 though since its pretty common around here to the point I could get away with it. My buddy is a parts dealer so I can get a good deal on the Precision turbo which is why it was my choice.
Off topic: my tranny is junk. I plan on buying an S14 tranny Monday to mate to the S13. Both are 5MTs so they should be ok. No driveshaft swap necessary. Anyone familiar with that sort of setup?
You will be fine. All you need to do is knock off the dust cover on the s14 tranny. Don't worry about the crank sensor that is on the tranny as well,
I should still be able to get away with using my S13 94+ flywheel dust cover right? Also, the crank sensor on the S14 isn't necessary since the S13 never had one correct?supakat wrote:You will be fine. All you need to do is knock off the dust cover on the s14 tranny. Don't worry about the crank sensor that is on the tranny as well,
Yes and yes.
Ran into a snag with the S13 5speed MT:
So I picked up an S14 5speed MT (MUCH better):
Got the clutch and flywheel installed:
Mating the tranny to the long block:
Finally we got it dropped in:
However, at this point the clutch fork doesn't move.. its not engaging the throwout bearing for some reason so we will need to pull it back out and inspect it again. Joy...
Well we got everything back in. The throwout bearing wasn't pushed down hard enough on the assembly and I guess wasn't pushed back far enough on the spline.
However, it is STILL extremely difficult to move the clutch fork. We need to use a pry bar in order to move it. I know its a Spec Stage 3 clutch but is this normal?
oh yeah, good luck moving the clutch fork. thats why hydraulics are used! im assuming the motor is just on a stand and not in the car, so no pedal.
Be careful not to knock the fork off the TOB or pivot ball.
Slight change of plans on the turbo build due to some things happening in my personal life. The turbo build is now very budget oriented. However, I was just able to pickup a top mount T3/T4 SSAutochrome turbo manifold on the cheap. I know its not the BEST manifold but the welds look decent and I don't see any globs of weld that could possibly break off. Also, I will need to either CNC cut a block off plate for the external waste gate flange or hack it off and weld over it because.... I am finalizing a deal to buy a rebuilt HX35 for $250!
damn, well atleast your not pulling the plug!
be careful with that manifold! not for quality but for fitment! id be pretty surprised if an hx on that mani clears the BMC
where do you guys come up with this stuff!?!? thats a silly comment. the port size is no different than any name brand internally gated turbo and would work perfectly fine. the main issue is you cant clock the turbo as needed with the internal gate and the pressure is high.
look up search terms like "top mount" and "clearence" issues. get an idea for what turbos are not fitting and then look at that MASSIVE hx housing.
HX35 and that mani will not clear the BMC if using the stock housing which I assume since the BEP is $200 alone. You can buy the cheap cast treadstone knock off for $90 and it will work. That is what I am using now. I will be changing out to the new CX mani which places the turbo in front of the motor. Good luck.
I was hoping to hear you chime in on this! Your build has been one huge inspiration to me. Your build definitely reflects your efforts. So I have to give you props for you and your contributions here. I will look into those manifolds. In the mean time I need to sell this one I have now.supakat wrote:HX35 and that mani will not clear the BMC if using the stock housing which I assume since the BEP is $200 alone. You can buy the cheap cast treadstone knock off for $90 and it will work. That is what I am using now. I will be changing out to the new CX mani which places the turbo in front of the motor. Good luck.
Thanks man. It is pretty cool for people to say that. We have several other threads like sdaigles, schmauster, and some others who are backyard DIY'ers with good results.
Towards the bottom of this link, you will see how the housing hits with old mani.
viewtopic.php?t=49585&postdays=0&postor ... &start=500
This one shows how I ported the mani. You also need to weld shut the 3 t4 mounting holes. Some pics were moved from FB so they are dead. Will try to find them for you.
viewtopic.php?t=49585&postdays=0&postor ... &start=520
Interesting. Is this the knockoff you are referring to? I notice that the flange is rotated so as to avoid the BMC which is awesome!supakat wrote:Thanks man. It is pretty cool for people to say that. We have several other threads like sdaigles, schmauster, and some others who are backyard DIY'ers with good results.
http://www.speedyracer.com/exhaust-part ... o-Manifold
In total, all I'll need to do is just weld the T4 holes shut and maybe port the manifold holes a little bit. Seems really easy and straight forward for such a cheap manifold!
I've also noticed in some other build threads that people have a custom downpipe they've made. Is this necessary due to the HX35 being rotated away from the BMC? Or can I get away with purchasing a pre-made DP?
Yes, same mani. As for DP, it will have to be custom because no one makes off the shelve kits for the holset 5 bolt or v band.
