d.p's 95 KA-T Build
Post by picsbypenny » Tue Oct 23, 2012 1:52 pm
Think I can run like 6psi with my injectors and maf to move my car 2miles with a SAFC II ?
FlatBlack
Post by FlatBlack » Tue Oct 23, 2012 2:54 pm
You can go further than that if you just stay out of boost - It's hard to resist though.
I'd suggest just unhooking your IC pipes if you were really worried about it, but you're MAF :/
89 240SX Coupe
02 GMC Sierra Z71 5.3L 4x4
03 Kawasaki 636 ZX-6R
77 Honda Trail 70 140cc swap
Post by picsbypenny » Tue Oct 23, 2012 11:35 pm
Why couldn't I get into boost?
I have a rising rate fpr I'm not using that could easily be hooked up if needed.
Post by shift_down » Wed Oct 24, 2012 5:51 am
Timing
Post by sdaigle240 » Wed Oct 24, 2012 5:54 am
if your holding off to "do it right" why sit on an upside down bar stool in the mean time? y bother tempting yourself.
with that said, ive got friends that have been drifting all season on only 370cc stock everything 7 psi. that car only sees the track though.
if you really just cant wait, id set boost to 7, base timing to 17-18 and safc to 11.0 in boost.
Post by picsbypenny » Wed Oct 24, 2012 5:58 am
Ohhhhhhhhuuhhhuuuu
EDIT, Didn't want to double post.
Here's a pic of final mock up of piping and stuff.
I pulled 90% of it out to do the BMC and installed my Tial WG too.
I stopped by one of the sponsors for the TT SBC S13 and they gave me some couplers that I was missing for the setup :)
I found myself in a small predicament though, all my t bolt clamps are 2.5in and 3in. All the piping on this car is 2.75in -.-
Wideband goes pre or post turbo? guessing post...
Post by picsbypenny » Mon Oct 29, 2012 12:38 pm
Sorry for the blurry cell phone crap.
Took a break working on the S14 to get my S13 ready for a car show. The main things I had to do was swap over the full suspension from my 'vert to the hatch, swap the wheels, and bleed the cooling system.
All theses things are fairly simple, took my friend and me about an hour to completely swap suspensions, but then it got super dark and I didn't want to piss off the neighbors by starting the car at 10pm. So I waited till Saturday after work to do the rest. I picked up the wheels from my friend and swapped them out. I lowered the car down and started bleeding the cooling system.
I start her up for the first time in weeks. started up on the second try :) keep in mind it was 76* out side. The last time I started the car it was in the 90* range. I adjusted the idle screw and kicked back the action bolts a bit since it was so cool out side. I took her around and when I saw the temp was constant I took her to the gas station to fill her up.
Got her all filled up and parked her for the night. Next morning I come out and its 57* I was fine with this cause I knew it was going to warm up a good amount. I went and got a hair cut and washed the daily since I took that to the show too. When I got back I tried starting the S13 and it was no good. I tried several times and then checked the wiring.
Normally I check the wiring with the kill switch off, but my brain wasn't completely thinking and I blew some fuses be cause I ended up shorting some things out that weren't protected very well -.-
Thinking back I shouldn't have tried starting the car with the E85. My carb doesn't like starting with E85 under like 70* I should have started it with 93 and not flooded it or blew fuses. :/
Shame on me.
Post by picsbypenny » Wed Oct 31, 2012 7:41 am
I was working on the car and told my friend to put my bumper back on while I put the some of the tools away... I came back to see this lol.
Post by supakat » Wed Oct 31, 2012 8:24 am
HAHA. At first I was like what kind of bumper is that.
niceguy
Post by niceguy » Wed Oct 31, 2012 8:57 am
It's amazing how just a set of wheels (and a drop) can transform a vehicle...Patience is a virtue when going FI, don't blow it (literally) lol...
Post by beercandrifter » Wed Oct 31, 2012 9:18 am
supakat wrote:HAHA. At first I was like what kind of bumper is that.
bumpers kinda sagging there man, think it got confused with a z32 lol
Post by picsbypenny » Wed Oct 31, 2012 10:13 am
It looked like a super crazy VIP bumper, we were laughing pretty hard.
How hard is it to remove EGR with the motor in car?
I got the block off plate, but i have fat hands.
project-c2
Post by project-c2 » Thu Nov 01, 2012 9:01 am
picsbypenny wrote:
Might want to use DEI metal zipties or hose clamps instead of plastic ties. Its gonna melt. 8) Looking good otherwise. Keep up the pics.
Post by picsbypenny » Thu Nov 01, 2012 12:27 pm
Knock on wood, but I've never had a ziptie melt on top of heat wrap.
KA-Life86
Post by KA-Life86 » Fri Nov 02, 2012 1:11 pm
picsbypenny wrote: How hard is it to remove EGR with the motor in car?
I really dont think its possible. Getting the tube out of the hot side is the real hang up
Post by picsbypenny » Fri Nov 02, 2012 1:23 pm
that was the easy part for me(sawzall)... Is it possible to pull the intake mani in car so i can pull out the rest of the EGR?
500hpKA240sx
Post by 500hpKA240sx » Fri Nov 02, 2012 1:30 pm
It depends if you have the cluster fcuk of vacuum lines still bolted to the back of the head. if those have been removed then taking the egr piping out is simple.
Post by picsbypenny » Fri Nov 02, 2012 1:47 pm
i have a ***** ton of vac lines lol
500hpKA240sx
Post by 500hpKA240sx » Fri Nov 02, 2012 2:01 pm
lol I have 3.
-IACV
-brake booster
-fpr
Post by picsbypenny » Fri Nov 02, 2012 2:30 pm
I was bored last night, threw part of my kit on from my daily. Still gotta plumb bottle and fuel lines.
Post by picsbypenny » Mon Nov 05, 2012 3:19 pm
So I'm saving money for my P&P and waiting for cars to sell; and I realized that I still hadn't hooked the brakes back up since I replaced my BMC. I looked at my spare parts box and saw my Z32 Calipers chillin all freshly rebuilt :) I called up my drunk buddy and asked what all I needed to do the conversion. He told me to just get the pads, so I did. After I installed them I quickly realized I needed lines and rotors as well. For now my car will chill hard parked until I sell some cars :(
Post by sdaigle240 » Tue Nov 06, 2012 6:08 am
back b4 i was into modding cars and realized my 240 was the ****, my EGR broke and I replaced it in the car. PITA but u can do it for sure. and just putting the block plate on is easy. haha i love that i had this car before i realized what people do to them.
prob no solid answer for this but why 2 sweet project cars?
Post by picsbypenny » Tue Nov 06, 2012 1:05 pm
So with the exception of like 2 of my friends, I'm probably the only one that makes easily over $60k. Back when I got in to 240s I picked my first one up for $300. I then got offered a coupe for cheap; so I took that too. One of my friends needed a running car so I traded my running car for his shell and payments. I was then put in a situation where I could do the swap I wanted but not exactly the money that I wanted to through at it. Same goes with the vert too, and I told myself I wouldn't let that happen with the S14. So yah, that's how it happened.
Post by picsbypenny » Wed Nov 07, 2012 9:52 am
Well the vert and red car are pending sale right now :) ( I told the guy buying the vert to join the site since he is planning on going KA-T
And my buddy welding some of my parts just sent me a pic of my pan. Love trading welding for beer lol. Hopefully my sandwich and brakes comes in soon so I can get my car back into the garage :)
KA-Life86
Post by KA-Life86 » Wed Nov 07, 2012 1:32 pm
Aw man you're selling the TT350? That's brutal, it'd be hard for me to part with a project like that
Post by picsbypenny » Wed Nov 07, 2012 1:45 pm
I'll build another one properly after I graduate college. One that's EFI with a T56 behind it :)
I came to the conclusion with my friends that the car was never going to ever run right, I twisted the chassis and ruined the firewall. Plus I can't get over certain things until I get rid of her. When it comes time, someone is going to basically give me a mint pig-nose hatch... when that happens I will do it correctly.
For now the KA-T build will keep me occupied and I gain more knowledge every time I jump into a new adventure.
Thinking about ordering this plate :)
lol because TEXAS of course
KA-Life86
Post by KA-Life86 » Thu Nov 08, 2012 7:10 am
LOL I like that. And I understand your reasoning for selling the car, trust me I do. I just know its never easy. I'm building an auto ka-t. Everyone gives me ****, I'm gonna get BCUZLZY on my plates lol
niceguy
Post by niceguy » Thu Nov 08, 2012 7:56 pm
I've grown to love tight shifting built autos....I've had motorcycles and manual cars all my life but with traffic around Memphis, I got tired of it. Now it's so much easier to eat a meatball sub and drive lol...
Post by picsbypenny » Fri Nov 09, 2012 8:40 am
My previous daily was an auto, that was nice in rush hour. Not nearly as fun to drive though.
Post by picsbypenny » Fri Nov 09, 2012 2:19 pm
So, I got a question about every ones favorite topic.... PCV >.<
That's what I plan on doing... I feel like it should work well, what are your opinions?
Just in case its not clear. PCV tree is removed and plugged. Valve Cover and PCV Block "Y" together and go to the Oil Catch Can( slightly modified with more baffles ). Fumes from the catch can go pre turbo post MAF.
