Page 2 of 6
Posted: Wed Dec 19, 2012 5:13 pm
by supakat
Just throw in straight up lucas to hold you over. That is what I did when it started to whine.
Posted: Thu Dec 20, 2012 7:41 am
by turbo2nr
yea im just hoping this trans holds for until i finish tuning, after then i can do the vq 6sp.
hmm i may just try that lucas stuff in it.
all buttoned up and ready to go to the shop for fuel/fmic/intake mani/valve cover breather setup
Posted: Thu Dec 20, 2012 7:49 am
by supakat
Granted pure power can shear the gears but most failure is from tranny shock. Just baby it by going into gear easy then romping on it. I used Lucas cause it said you can put 50% in with existing oil. I also used thicker than 85w-140 before the Lucas. When it is cold, it would be stiff but after it warmed up, it was smooth. I also noticed my shifter was cooler than any less weight I had in their. But I used the thicker oil to help avoid tranny shock and it lasted me +3 years. I ended up blowing a tranny while n/a but I was clutch kicking and beating the piss out of it.
Posted: Thu Dec 20, 2012 8:05 am
by turbo2nr
supakat- what was the name of the lucas product you used. im defiantly going to do this once the car gets to the shop.
thanks for the heads up
Posted: Thu Dec 20, 2012 8:13 am
by bmitchell_ga
Im very intresred in the vq tranny setup. Please document it wel.l
Posted: Thu Dec 20, 2012 8:19 am
by supakat
Just regular ole Lucas Heavy Duty Oil Stabilizer.
Says you can use 25%-50% in manual gearboxes so I did and some more.
http://www.lucasoil.com/images/medialib ... zr_1_2.pdf
Posted: Sat Dec 22, 2012 7:29 am
by turbo2nr
Finally made it to Tarmac now the real work beings
agenda:
install fuel setup ( dual pumps/s.s. lines from tank/fuel ral ect)
custom intake mani insall
pcv catch can setup
v/c catch can setup
custom fmic + pipes + wiggins or vmount
custom 3.5" exhaust
new harness
aem v2 + sensors
z32 rear brakes
my wallet is going to love me
Posted: Sat Dec 22, 2012 8:36 am
by bmitchell_ga
You kept your battles
Posted: Sun Dec 23, 2012 11:44 am
by turbo2nr
thanks man! but its not my wheels is a friend of mine hes letting me use them until my new wheels come
preview of whats to come..
Posted: Sun Dec 23, 2012 12:00 pm
by bmitchell_ga
Mighty find hardware. Are you in "construction "?
Posted: Sun Dec 23, 2012 8:36 pm
by adamky
supakat wrote:Granted pure power can shear the gears but most failure is from tranny shock.
I agree that's
mostly the case. I know that kedbmx was rolling into the throttle when he sheared the teeth off of his third gear. I'm not sure about T2T. With a good clutch that doesn't slip, traction, and 550+ whp, the tranny is a ticking time bomb, even when rolling into the throttle (no tranny shock).
That Full Race mani looks so damn good with that ceramic coating.
Posted: Thu Jan 03, 2013 7:34 am
by turbo2nr
no real progress
pulled my fcon out, sad to see this go
such a nice piece.
as for now the car is siting as i wait for my v mount/fuel surge parts to come in..
Posted: Fri Jan 04, 2013 8:58 am
by 2muchboost
Tranny shock is the #1 culprit of damaged trans. If your going to make serious power/Tq then go with solid diff bushings and a clutch that will provided the minimum amount of stress on the trans. I have seen stock trans (referring to R154) hold up to some serious power as long as the stress is minimized on the trans. For those of you that may not know the R154 isnt typically recommended past 600-650 lbs/tq yet I have seen them hold up to much more as long as the driver isnt a dumb ass and the stress is minimized mechanically.
Cant wait to see her done Drew.....and trust me I know how you feel about the pockets. My standalone is about 75% of the total cost of my car when I bought it in 2002
Posted: Fri Jan 04, 2013 3:36 pm
by picsbypenny
any info on the LSX cars next to yours?
Posted: Sat Jan 05, 2013 7:14 am
by turbo2nr
white car is the shops owner's car ls2 6.0l full bolt on and tune super clean
grey car is my good friend cars it has ls1 5.7l built bottome end cammed
[/img]
Posted: Sat Jan 05, 2013 7:43 pm
by Jonas
nice build
Posted: Mon Jan 14, 2013 8:43 am
by turbo2nr
Posted: Fri Mar 01, 2013 8:37 am
by turbo2nr
^right after we RWB your 911,
slight update:
fab started on v-mount, every thing is looking awesome. Big thanks for Tarmac and damian for all the fab work!
mounts
fitment
hot side end tank
hot side turbo elbow
modifying gtx housing
wiggins weled on!
cold side end tank
intercooler weled
long way tp go..
Posted: Fri Mar 01, 2013 9:30 am
by Ponda
Drooooooool. Awesome work!
Posted: Sat Mar 02, 2013 10:08 am
by turbo2nr
stoped by the shop last night for some late nite fab and beer!
started on the rad. hard piping, Damian is the man when it comes to figuring out these damm angles and flow..
quick look of how short the charge pipe will be once the winggins are on
intercooler came out legit, ETS hooked it up!
as she sits..
Posted: Sat Mar 02, 2013 11:29 am
by picsbypenny
can we trade turbos please
Posted: Sun Mar 03, 2013 12:50 pm
by mewantkouki
Maybe I missed it earlier, but who made that intake manifold? Tanman?
Posted: Sun Mar 03, 2013 7:58 pm
by Jmoore124
Some awesome work on the v mount setup for sure.
Posted: Mon Mar 04, 2013 4:04 am
by Irresistible
Why is the hot coolant going to be going to the bottom of the radiator? Or am I interpreting the pictures incorrectly?
Posted: Mon Mar 04, 2013 7:14 am
by turbo2nr
bottom of the radiator is going to the water neck, that pipe needs to be cut down and bent..
yea this v mount has alot of r&d time in it, it should flow like no other.
Posted: Mon Mar 04, 2013 9:08 am
by Kamilitaryman
I'm loving that V-Mount! Im debating whether or not to do a mid-mount on mine. Trick is, the AC unit must go...
Posted: Mon Mar 04, 2013 9:11 am
by jholman05
Cool, interesting and unique setup. Thanks for posting the pics.
Posted: Mon Mar 04, 2013 2:47 pm
by turbo2nr
thanks everyone
what color an fittings ?
im using black nylon lines for the bay,
im leaning toward the black/red, i think the blue/red is classic but way to many colors going on in my bay with polished/purple, flat black ect..
the black and silver is nice to but kind of plain IMO
Posted: Mon Mar 04, 2013 3:24 pm
by Kamilitaryman
RED/Black imho. The red/blue is fugly and played out
Posted: Mon Mar 04, 2013 4:29 pm
by supakat
Go with colors of your country's flag.
