hpipro4 S13 KA24DE-T Build
signals13
Re: hpipro4 s13 ka-t build
Post by signals13 » Tue Jul 09, 2013 10:20 pm
Were did you get the turbo blanket?
hpipro4
Post by hpipro4 » Tue Jul 09, 2013 10:47 pm
shift_down wrote:Ahhhh this is legit! One day my setup might be this impressive! Keep it up, I'm learning a lot from this.
my build aint that impressive! lol
hpipro4
Post by hpipro4 » Tue Jul 09, 2013 10:50 pm
signals13 wrote:Were did you get the turbo blanket?
bought it off ebay lol had to modify it to fit.
hpipro4
Post by hpipro4 » Tue Jul 16, 2013 11:30 pm
my ID1000 came in! 11mm tops ill be using the aem fuel rail that will need longer spacers to fit.
injector dynamics goodness!
learning how to degree my cams but 1st i need to set my valve lash .008" intake and .010" exhaust according to BC cam card. intake side is pretty much done but exhaust side was no were near specs. i had to buy a few shims in the 2mm+ range but few needed 1.91mm & 1.93mm and the thinnest nissan carry are 1.96mm.....what to do???
Post by schmauster920 » Wed Jul 17, 2013 5:32 am
Legit build! Dont forget you can always get a machine shop to machine the shims down slightly.. might be the easiest and cheapest considering how much the shims are
hpipro4
Post by hpipro4 » Wed Jul 17, 2013 11:26 pm
schmauster920 wrote:Legit build! Dont forget you can always get a machine shop to machine the shims down slightly.. might be the easiest and cheapest considering how much the shims are
thanks
i just realized i can grind down the top of the valve stems slightly bit and go frm there. not sure why i didnt think about it before i bought 6 shims frm the dealer. oh well.....
boosted93
Post by boosted93 » Thu Jul 18, 2013 12:23 am
Damn dude you do some good work man.. love your attention to detail!! Keep it up youll be building nice **** for years to come
drunknmunky
Post by drunknmunky » Thu Jul 18, 2013 4:22 pm
I really like how clean and professional this build has gone.
You've made your project worth more and a piece of art that all of us can appreciate and I thank you for sharing it with us.
hpipro4
Post by hpipro4 » Fri Jul 19, 2013 12:13 am
thanks you fellas :bowdown:
Grant
Post by Grant » Fri Jul 19, 2013 7:55 am
subscribed, man this is one hell of a build, clean legit
foltzs14
Post by foltzs14 » Fri Jul 19, 2013 1:48 pm
Thanks for the inspiration and great job on the build.
The value of life can be measured by how many times your soul has been deeply stirred - S. Honda
wtfarpus
Post by wtfarpus » Thu Jul 25, 2013 4:32 pm
awesome job on the build man, looks amazing.
superDorifto
Post by superDorifto » Thu Jul 25, 2013 4:48 pm
wow, this is a fantastic build.
We have a ton of parts in common, and I'm real jealous how good it looks on your build. Im red, nickle, and gold - youre black, golf and silver....looks real good.
hpipro4
Post by hpipro4 » Fri Jul 26, 2013 10:41 am
superDorifto wrote:wow, this is a fantastic build.
thanks! yes very much indeed.
wtfarpus
Post by wtfarpus » Sat Aug 03, 2013 12:45 am
What was mix in the chemical bath to plate them?
hpipro4
Post by hpipro4 » Sat Aug 03, 2013 10:17 pm
wtfarpus wrote:What was mix in the chemical bath to plate them?
i use this
http://www.caswellplating.com/electropl ... 5-gal.html
wtfarpus
Post by wtfarpus » Sun Aug 04, 2013 11:11 am
thanks man
superDorifto
Post by superDorifto » Sun Aug 04, 2013 2:07 pm
i use this
Same place that I got my nickle plating kit from...super easy to deal with.
hpipro4
Post by hpipro4 » Sun Aug 11, 2013 12:11 am
not much update but finally done with valve adjustment. ordered few shims frm my local nissan dealer and took at least a week to get 6 shims. then i needed more for the exhaust side so i ordered some frm nissanparts.cc actually got them quicker than my local dealer considering their in Washington.
anyways.....decided to give this shim tool i bought frm egay!supposedly its for toyotas. at 1st, i was like...damn! this thing works awesome. till i took out the cams out and noticed it was scratching the journals. polished em with 2k sandpaper hopefully it'll be fine!
i was stuck how to switch shims around quicker and not scratching the journals. so i decided to fabbed my own bucket/spring pushed-down out of 304 stainless steel flat bar.
it bolts on to one of the cam cap bolt and pretty much press down on the edge of the bucket and shims pops off easily.
hpipro4
Post by hpipro4 » Fri Aug 16, 2013 12:42 am
valve lash all done. 008" intake and .010" exhaust.
degreed the bc264 cams. i had to advance intake 2.5degrees and retard exhaust 2.5degrees to come close to bc cam card.
i see why BC recommend valve lash to be .008" int n .010" exh, with stock setting on cam jwt cam gear, specs are almost within the cam card.
Post by picsbypenny » Fri Aug 16, 2013 3:14 pm
Can I send you my nuts and bolts to yellow chromate :)
hpipro4
Post by hpipro4 » Fri Aug 16, 2013 8:37 pm
picsbypenny wrote:Can I send you my nuts and bolts to yellow chromate :)
ya for a price! :mrgreen:
powerhouse
Post by powerhouse » Sun Aug 18, 2013 12:12 pm
WOW that's an AWSOME build
smbonn2005
Post by smbonn2005 » Sun Aug 18, 2013 2:18 pm
PM me what kind of pricing it be to get some nuts and bolts yellow chromated
Post by picsbypenny » Fri Sep 06, 2013 1:54 pm
i got a pm from you but it said deleted by user :/
mewantkouki
Post by mewantkouki » Fri Sep 06, 2013 6:01 pm
How much did those ARP exhaust manifold studs cost you? Link please?
hpipro4
Post by hpipro4 » Fri Sep 06, 2013 10:09 pm
picsbypenny wrote:i got a pm from you but it said deleted by user :/
hmmm...i dunno what it was....
hpipro4
Post by hpipro4 » Fri Sep 06, 2013 10:11 pm
mewantkouki wrote:How much did those ARP exhaust manifold studs cost you? Link please?
their not arp! their oem but i electroplated em then dipped in black chromate.
drunknmunky
Post by drunknmunky » Sat Sep 07, 2013 6:59 am
can you show us how to do the electroplating? or reference a source?
I've seen it done on youtube but I'd like to ask how you do it.
Post by picsbypenny » Sat Sep 07, 2013 7:26 am
I asked for price on every external bolt yellow chromate
