hpipro4 S13 KA24DE-T Build
Re: hpipro4 s13 ka-t build
Did you spill the beans on your oil filter relocation / cooler setup yet? I've got the same skullworks relocation block but I've been having a hard time finding a remote filter mount with 8an in and out and a built in thermostat. I was thinking greddy but I'm not sure I can get fittings to replace the -10 ones it comes with...
mocal has a pretty good one, thermostat is a separate unit however
dont have time to do a write up but this kit is basiclly what im using cept i decided to put together my own. the kit will include a how to manual. they have a forum too http://forum.caswellplating.com/drunknmunky wrote:can you show us how to do the electroplating? or reference a source?
I've seen it done on youtube but I'd like to ask how you do it.
you would need a kit like this http://www.caswellplating.com/electropl ... 5-gal.html
12v power supply that has adjustable amperage and voltage. got mine frm egay
lotz of distilled water and trial errors
having problem with the yellow chromate at the moment so prolly not a good idea. till i get things sorted then will talk business. seems pretty easy but its actually alot of work.picsbypenny wrote:I asked for price on every external bolt yellow chromatehpipro4 wrote:hmmm...i dunno what it was....picsbypenny wrote:i got a pm from you but it said deleted by user :/
yes kinda weird how it have 8an in&out. decided i stick with the 8an instead of 10an. altho, i could get 8an male to 10an male fittings but ill stick with 8an.mewantkouki wrote:Did you spill the beans on your oil filter relocation / cooler setup yet? I've got the same skullworks relocation block but I've been having a hard time finding a remote filter mount with 8an in and out and a built in thermostat. I was thinking greddy but I'm not sure I can get fittings to replace the -10 ones it comes with...
so far i bought this to use as the oil filter block. http://www.summitracing.com/parts/prm-1761
also got a derale oil thermostat http://www.summitracing.com/parts/der-25011
i plan on using an oil cooler with 8an fittings. either egay cooler or earls.
been a while since i updated the thread.....here we go....
bought some hi temp powder on ebay
i hate rust so i decided to take the s15 turbo apart and coat the turbine housing.
how it looks
also decided to coat the isis v2 turbo manifold
aluminum oxide blasted
how it looks
this is where my build stand at......
pick n pull had a labor day sale 50%off everything so i took advantage!
scored a 96 s14 ka24de unknown miles???
tear down.....
also scored this z32 calipers frm pick n pull for cheap....alredy have em but hey it doesnt hurt to have another set plus they were cheap!
parts starting to pile up again....
this another KA build is for smog purpose only. cali smog sucks! lol
how it looks
how it looks
tear down.....
Just got done reading whole thread and......wow the attention to detail is flawless. Best ive seen in a long time
found out i got another yr or so till i need smog !!!!!so im going back to building the built KA
was lurking around ebay and scored this BC intake and exhaust valves for 130shipped which i think is a steal!
i guess ill give this setrab 8an oil cooler a try. if nascar uses it im pretty sure itll work on my KA.
king bearings and NPR piston ring set for the "smog legal" KA built lol
Good stuff. Keep it up.
supakat wrote:Good stuff. Keep it up.
thanks bro! i cant wait till i get the mspnp running!
my tomei sr20 oil pan finally came after it was backordered for a few months.
just incase some1 wanted to see what tsubaki timing kit for the ka24de.
bought me a better powdercoating system. spectracoat es-02wp
not much update thats because i've been busy building my powdercoating oven.....
cheap but works like wonder...specially when i need to crank out 1000 rivets lol
Any way I could get pictures of, and possibly sources on where you found all the misc sensors and stuff for the DIgital Climate Control? you can PM it to me if you have it available. I'm looking into doing it to my hatch, just have to find the little parts.
this build is so sick, it's better than porn
google search s13 dcc and ull find eveything you need. sorry dont have any pics of sensors. bought mine complete off some1 here back in the days. try zilvia or shops that sells jdm front clips.Saxy_S13 wrote:Any way I could get pictures of, and possibly sources on where you found all the misc sensors and stuff for the DIgital Climate Control? you can PM it to me if you have it available. I'm looking into doing it to my hatch, just have to find the little parts.
this guy! lolIkera wrote:this build is so sick, it's better than porn
hpipro4 wrote:google search s13 dcc and ull find eveything you need. sorry dont have any pics of sensors. bought mine complete off some1 here back in the days. try zilvia or shops that sells jdm front clips.Saxy_S13 wrote:Any way I could get pictures of, and possibly sources on where you found all the misc sensors and stuff for the DIgital Climate Control? you can PM it to me if you have it available. I'm looking into doing it to my hatch, just have to find the little parts.
Believe me, I've done quite a bit of research. I just wanna be sure that when I find the sensors and junk that they're the right ones. I cant find any kind of write up with any kind of pictures. Its a terrible feeling
- 1991240sxhatch
i love the wiring on this build, if i feel brave enough i think i might give something like this a shot
http://zilvia.net/f/tech-talk/154426-ho ... ntrol.htmlSaxy_S13 wrote:hpipro4 wrote:google search s13 dcc and ull find eveything you need. sorry dont have any pics of sensors. bought mine complete off some1 here back in the days. try zilvia or shops that sells jdm front clips.Saxy_S13 wrote:Any way I could get pictures of, and possibly sources on where you found all the misc sensors and stuff for the DIgital Climate Control? you can PM it to me if you have it available. I'm looking into doing it to my hatch, just have to find the little parts.
hope that helps.
Nice build!! I wish i still had my s13.
I'm curious what are your plans for return line from turbo? Are you going to weld in a bung to that pan?
Cam
ill be using the xcessive upper oilpan has a pre-tapped 1/2npt. ill use a 10an to 1/2npt fititng.kacam24det wrote:I'm curious what are your plans for return line from turbo? Are you going to weld in a bung to that pan?
http://www.xcessivemanufacturing.com/on ... 145&step=4
I see I just ordered mine yesterday I did not see that bung in the pan
Cam
Wow props on the spectra coat. That's a hell of a gun. What are you intending on using to fire your oven? I ordered a bunch of infared ceramic plate style burners earlier this year. Havent had the time to finish mine yet though.
Using something similar to this(10 of them) http://www.ebay.com/itm/American-Range- ... 5d4623b892
With a PID controller, Gas valve and constant on ceramic ignitors.
ya cant wait to use it....almost done with my oven build. im building a 120v oven since i dont have an extra 220 outlet but i can easly convert it to 220v later on. for now im going to use infrared heaters. hopefully it gets hot enough.Jmoore124 wrote:Wow props on the spectra coat. That's a hell of a gun. What are you intending on using to fire your oven? I ordered a bunch of infared ceramic plate style burners earlier this year. Havent had the time to finish mine yet though.
- wesamiss
hpipro4,
Are you using the russell 697070 t2 -10 AN oil drain?
http://www.ebay.com/itm/Russell-697070- ... 1310214605
I have one but am considering not using it.
WES
yup! thats the one i have. fits my s15 t28 no problem.wesamiss wrote:hpipro4,
been a while since i updated the thread. hope everyone had an awesome christmas! 2014 here we come!
been busy building my big ol powdercoating oven. not quite finish yet but soon to be running and make some side money! haha
havent really done much to any of the two KA's im building but been buying parts after another lol....parts filing up and got no more room!
BC intake/exhaust valve guides & supertech valve seals. incase some1 needs part# for supertech valves seals vs-n7e & vs-n7i
found an xcessive intake manifold for a decent price
few goodies i got for christmas....
finally bought work emotion XD9 18x10 +18 rears & 18x9 +20 frts
freebies frm WORK!!!
other goodies i got.....go pro hero3 white edition and the bose soundlink mini(sounds amazing for a lil speaker)
Ooooooh Nice!! I love those XD-9's.
too sick, everything ive done to my car make me feel like a douchebag lol
KA24E SOHC swaggin on haters
Sweet build man, lots of care and details.
Which part of Cali are you at? I'm in So Cal Los Angeles area
