Wire length depends on where you decided to mount them. Then cut and crimp to fit.hpipro4 wrote:oh ok was running the same. thought you had to run acdelco or something because of the ls2 coils. does the sparkplug wires have to be certain lenghts or did you just replace the other end?
can the mspnp drive any top feed injectors that will work on the godspeed intake manifold?
are you still running the obx fuel rail?
been really thinking about switching to e85! whats your gas milage like? i dont care much about the gas milage but more concern about safety! i read e85 has higher octane rating which is good for boost but electrically conductive. did you have to wrap the stock fuel tank with fire retardant stuff? just curios what oil are you running full synthetic 5/30?
thanks a bunch
Yes, ms can run any injector. Just get injectors that you find work well with the manifold. My bosch don't have issues sealing.
Yes, OBX rail still.
I don't know about mileage since I drive only to meets, weekends, and occasional work days.
No fire retardant stuff. Just fill and go.
Oil is rotella 15w-40. If you are in colder weather, you may need to go lighter.
