MINI VAN WITH A DIFFERENCE (video Added)
Mini Vans can be fun too !!
http://img.photobucket.com/albums/v314/ ... CF0348.jpg
Re: MINI VAN WITH A DIFFERENCE
Whoh! Very nice! Those manifolds are SICK!
Thankyou Sir,sil-coupe wrote:Whoh! Very nice! Those manifolds are SICK!
I'm sorry if my van offends people, it is a KA-T and with the spec I'm certainly expecting 450whp when its mapped in November
Thankyou for your kind words sil-coupe
Hutch
That intake mani looks like an older corolla in. Mani. Did you fab that or what? Its f'n baller status
Standard mani for the largo our intake comes around the back of the head over the tranny due to space under the seats.
The largo runs a 300zx tranny as standard too ;-)
Hutch
Hutch
sooo sweet!! any reason you wouldnt switch to a 240 style aftermarket mani? hood clearance?
Engine is under the seats, tried a xtreme mani and it was about 5" to high. Couldn't put the engine cover and seats back in.
Hutch
Hutch
I've honestly never been a fan of this style of vans but this one is flippin sweet! Good job man!
- flip240
hahaha nice!
My setup: KA24DE-T
My setup: KA24DE-T
If I'm honest, the VW T4 transporter is the common van of choice in th UK however, someone has to be different ha ha
woah thats crazy... like an old previa with the mid mount.
Good afternoon,
This is the spec list as requested and pictures.
Garrett Gt30-76r
Gas flowed and ported head
BC 264 Cams
JWT Cam gears
BC Valves, Titanium Duel springs and retainers
Cometic H/G
ARP Bolts all round
1 off Exh Manifold
Full 3" s/s exhaust system
Greddy Fuel rail
750cc RC injectors
Walbro fuel pump, Braided hoses
Magnecore 8mm leads
Irid 8 plugs
CP forged pistons
Eagle Rods
Clevite nascar Bearings
HKS induction system
Large intercooler 2.5" piping
19 row Oil Cooler mod
Aem series 2
Aem water/Meth system
Aem 3 Bar map sensor
Aem Ait sensor
Level 10 transmission
Turbo precision 46mm external waste gate with screamer pipe.
Being mapped in November, hoping to see 450+ whp
Hutch
Garrett Gt30-76r
BC 264 Cams
JWT Cam gears
Cometic H/G
ARP Bolts all round
1 off Exh Manifold
Greddy Fuel rail
750cc RC injectors
Magnecore 8mm leads
Irid 8 plugs
CP forged pistons
Eagle Rods
Aem series 2
Aem Ait sensor
Hutch
I like how the intake is a equal length with no plenum. I wonder how efficient that is compared to the plenum type we have?
1993 240sx fastback FINALLY TURBOED!!!!
T3\60-1
JGS LOG MANI
740CC INJ.
NISTUNE
T3\60-1
JGS LOG MANI
740CC INJ.
NISTUNE
Can you take a picture of the engine bay, relative to the car?
I'm having a tough time seeing where the engine is situated in the car, even though you explained it.
That intake manifold is very unique for the ka. first time i've seen it. what year is the car?
how was your powerband before turbo?
looking @ the head, it looks like you run a FWD head. Is the car fwd or rwd?
Yeah agree im trying to wrap my head around that layout. This probably isnt stateside is it?
KA in the Fray
Imagine yourself sat on the turbo, thats the exactly where the engine is I have thousands more pictures I wil try to give you a visual representation.
I tried the greddy TD06 complete turbo kit when I had the idea of putting together a Largo turbo, ended up using only the fuel rail :-/
Everything is bespoke from the exhaust mani onwards, the standard Hp was 150 with good torque. Needed the torque to move the 1.8 ton, it is booked in @ Advanced motorsport and engineering 1st November and hopefully see some good figures, will post up the dyno results asap.
Hutch
Hutch
It runs a Fwd engine setup with Rwd, the inlet mani can only be found in the Nissan Largo. I have investigated all the ka engines and the altima head is similar but not the same. Neither of the 13 or 14 variations are the same, you run the distributor off the front of the cam.
I run of the rear @ 15 degrees base timing.
Hutch
Hutch
The second Picture you can see the Transmission gear selector thats where the engine is.
Trying to upload onto photobucket but its mugging me off
Hutch
Hutch
photobucket is making me angry also as I try to get into your private gallery lol
Where are you located in the UK?
So your alternator is mounted right in front of the turbo? or is it on the other side? I see what looks like an A/C bracket.
Very interesting head design. It's like the altima's, except your upper coolant filler neck position is totally different.
The alternator is mounted on the inlet side, Air con is no longer there. thats where the turbo is now. There is a coolant filler unit on the engine and on the Radiator.
I am in the South West area, not very close to many tuning companies able to map AEM
Guess thats why im selling my other set of forgies stateside
Hutch
Hutch
Old pictures to give you a better insight into the build
Opps sorry old car 610 Hp Celica st205 GT4
Hutch
Hutch
I'm curious to see how your turbo setup will run without a plenum.
This is like, the most insane and ridiculous engine fitment and it's AMAZING what you've managed to do with such an awkward space.
Very appreciative of your efforts!
You think not having a plenum will cause problems ??? Surely equal length intake from the 60mm throttle body will let it breath ok. Equal length works well to release gasses so maybe it could be the same theory inward :-/
nice build what do you have done to your'e transmission?
LEVEL 10 TRANSMISSION as above.
Hoping it all turns out ok with that intake, if not then I will chop and weld on a plenum chamber etc
