not so legal street car build - canada
this is my build thread that will be regularly updated.
updated 13/12/2014
engine-
s14 head
Brian crower valve springs, retainers, and valves
Supertech valve seals
New exhaust valve guides
3 angle valve job
polished ports & chambers
New frost plugs , block deburred
Balanced & polished crank
CP 20 over 9:1
Brian crower h beams, arp2000
10mm arp headstuds
arp mains
clevite bearings
Fidanza flywheel
Cometic headgasket (selling and getting cosworth no doubt.)
New oem oil pump, water pump & timing set
mishimoto cold thermostat
twinscroll t4 front mount turbo manifold
aeromotive fpr & fuelab filter
Chassis - suspension - wheels
lip kit removed
frsport tail lights
Front & rear drift armour bars painted nismo silver
Tien HR series coilovers
Silvia front end conversion w hid bricks
gktech v3 tension rods
cusco ruca's
Work Emotion CR KAI 17x7 +32
early photo's vv
____________________________________
updated 13/12/2014
engine-
s14 head
3 angle valve job
CP 20 over 9:1
10mm arp headstuds
arp mains
clevite bearings
Fidanza flywheel
lip kit removed
frsport tail lights
cusco ruca's
early photo's vv
1991 sil-eighty se sold
1995 bmw 540i written off
1995 pathfinder se, sold
1995 Altima gxe, sold
Re: new member built ka-t drag unit.
just FYI i see 3 blank photos. maybe my computer but i do use PB all the time as the attachment feature is new.
i logged into my laptop and i cant see any problems even when viewing as a guest, i posted several more photo's, maybe try again
Suggestion... Dump that cometic head gasket and buy a cosworth.
i took the advice of making a weak spot, but im open to other suggestions/reasoning.mewantkouki wrote:Suggestion... Dump that cometic head gasket and buy a cosworth.
btw i did forget something, arp everything.
oh and btw, what a creative name you've managed. haha. +1ka240de wrote:i took the advice of making a weak spot, but im open to other suggestions/reasoning.mewantkouki wrote:Suggestion... Dump that cometic head gasket and buy a cosworth.
- Kamilitaryman
you've got a R32?? Why are you wasting your time on the S14???
Lol the gtr is my garage buddy's. Her ex bf brought it to a dealership after friend of his dumped some coolant into it without some kind of relief that the 26's have. idk about them. anyways blew a frost plug and brought it to a dealership, the car over heated several times on the way back from there and they have no idea what ever went wrong, didnt ever look into fixing it. just sits there not for sale haha.Kamilitaryman wrote:you've got a R32?? Why are you wasting your time on the S14???
yea lets see some pictures I love hearing bedlinered interior check out my build you might find some similarities
Cam
When posting pics, make sure you code looks like this. I edited your first post.
Code: Select all
[img]http://i988.photobucket.com/albums/af10/jake_thompson4/Mobile%20Uploads/CAM00015_zps40ddd1a7.jpg[/img]
Thanks soo much man! I was clicking the "add attachment ". yea ill post some more pictures up once I bedline the interior, likely wont be until spring though. i keep my car in a storage unit that i rent year round. no heat. most of the work gets done in the summer time
Re: new built ka-t drag project
Big progress ! Got the engine bay painted and the power brace and fenders installed today.
Straight to the pictures
Stitch welds
Stitch welds
Update
Painted my drift armor bars to match the nismo power brace, found a set of front and rear strut tower bars for 140$ going to sand em and paint them silver too. Black on black with silver
Nice build
That is going to be a heck of a idle
You think so ? All the research I've seen kelfords show the best results, I heard jwt s1's lose significantly more low end.
And does anyone know the limit of nismo 740cc's?
Or how much bigger I should go to hit 625~whp safely? Pump / c16 mix
The idle will sound great is what I mean, injectors you might have to do 1000cc for that amount of power.
yea i gotcha, was just going right off topic i guess haha. i was pretty sure id have to go bigger than 740 for my goals. things just went furthur and further with the build and now its capable of more than i origionally planned.
everyone likes a mean sounding idle . i cant wait to start her up.
Yea after all the months of prepping and building all to get to the cranking its exciting I just started my car and its awesome .
no problems upon startup? bet it made you nervous. a little electrical problem and nothing works. thats why im going over every wire in my car make sure everythigns good and all bad connectors are replaced. last guy was starting it with a screwdriver, and i got it with a hole in the block. it was pretty rough when i got it lmao
No problems just the dizzy timing, check out my thread i posted a video.
- street_240sx
off to a good start, how much power are you looking for?
03 evo8 gsr: stroker 2.3
Re: strip street ka t
600 is the goal, c16 mix, street legal sleeper
So I did a lot if research and I think I've decided on the hta3582 any opinions ?
Turbo correct?
Just noticed I hadn't posted a picture of the engine. I do realise the screw in coolant thing at the rear is pointing the wrong way lol . Opps
Yes, I'll post a picture I found online, but yeah they are pricey but they are sold with the exhaust housing and are better for power and spool. The difference in compressor wheels are insane to the naked eyesignals13 wrote:Turbo correct?
Edit: http://forums.bimmerforums.com/forum/sh ... -HTA-test-(-
Update
I decided to use stock s13 cams for now so I can swap in the 272's later on mainly to feel the difference each time rather than start with expensive 272's and never see the gains, for the same reason im starting with the stock intake too.
Anyways back on topic today I was installing cams and my torque wrench doesnt adjust as low as it claims. I broke off a cam bolt in the head. Lucky the easy out bit worked very well and called it a day at that. Next is to install the intake manifold and get an exhaust mani on order ! So excited to go back to work tomorrow. It was a long 5 weeks being laid off !
I also bought another s13 parts car ! ..i always wanted to try a supercharger ...
Happy new year everyone hope xmas treated you well
